Eurocars P/L - Peugeot
Old 1st Sep 2002, 12:03 PM   #1
Simon
Simon's Avatar
Member#: 41
FREE Fuego Fings
They've just gotta go!
Seven original Fuego alloy TRX rims and tyres (tyres in varying states of illegality). Pick them up for the future when these are likely to be really hard to obtain when Fuego's are restored by originality freaks.
ALSO
1982 Fuego short motor (minus head, A/C compressor, clutch). Full history known, early service history documented, genuine 180,000k's. But the PO stored the motor in a damp atmosphere so the pistons are stuck etc. However the flywheel is unmarked and the block is not corroded.
Located in Adelaide.
Grab 'em before Mr Sims does!
2005 Renaultsport Clio 182 Cup
1969 Renault 8 Gordini 1300
1964 Renault R4
1963 Renault R4 Van
Simon is offline   Reply Reply With Quote
Old 1st Oct 2002, 09:58 PM   #2
The Gonz
The Gonz's Avatar
Member#: 951
Simon, I note you're also in Adelaide. Can I pick your brains so I can get to know my "new" '85 Fuego a little better?
It appears to miss under hard acceleration and it sounds as if it's even backfiring when pushed at around 100.
I've seen lots of posts about Fuegos running rich. Do you think this is what's happening or is it more likely to be something like the vacuum advance?
I would love to find a cheap workshop/service manual for one, by the way.
The Gonz - Creator of the Counter Terrorist Steganography Search Engine
and Australia's first tactical Electronic Surveillance vehicle - the SNIFFR.
Fuego: Spanish for "Fire" - Gotta love it!
See how the Plip lives!
The Gonz is offline   Reply Reply With Quote
Old 2nd Oct 2002, 02:02 PM   #3
Simon
Simon's Avatar
Member#: 41
Could be a multitude of different things that cause the missing. While Fuego's have been known to run rich, it's unlikely that would cause it to miss through the whole range. I'd be checking the simple things first like plugs, leads, distributor cap, connections to the coil and electronic ignition. After that things get a bit more in depth.
For a manual see Castle Motors at Norwood, the parts section (ex- Jacques Thoridnet) may have a Haynes manual, failing that try the Motoring Bookshop in Gouger St or phone Caravelle Imports in Melbourne.
For repairs try Olivers & Skinners at 350 Hampstead Rd Broadview.
If it still fails to respond after the above, pick up my FREE short motor, it should make the car sink off the Largs Jetty much quicker!
Simon
Quote:
The Gonz:
1964 Renault R4
1963 Renault R4 Van
Old 2nd Oct 2002, 11:57 PM   #4
The Gonz
The Gonz's Avatar
Member#: 951
hehe...thanks for the info - must get out to Largs Bay one of these days...
 Dashboard
Currently Active Users Viewing This Thread: ( members and guests)
View Who's Online
Forum Jump
Contains New Posts
Forum Jump
Copyright
Contains New Posts
All content is © to aussiefrogs.com PTY LTD 2009
ABN 14 126640024 & the author of threads/ posts
Thread Tools
Powered by vBulletin® Version 3.8.5 - Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.vB.Sponsors
