This website is for sale.
Click for details
#1 |
So after I sold the v6 project to james504
There was only one option left for the cti. Lets go back to the basic’s T16 world . The engine that I will build for this car, will brake all my records in engine building .. The parts that I have ordered for this project look like this .. 87mm woessner special coated & forged pistons .. compression 8.0:1 special rods 158mm (gti6 158mm) T16 (152mm) ARP Rod Bolts I will try to make a mix out of 2 engines for this project 1x engines 2.0l xu10j4 rs (306 gti6) 1x 307 HDI 2.0l 136 hp .. why the hdi runs a compression of 17 bar with 1.3bar turbo Pressure.. fully forged steal crank very strong build ..8 counter weights. Gti6 engine best xu Block to use, for a conversion . best cylinder head flow, 2 separate cam boxes, no big oil surging dramas. bigger oil and water holes ..i can add oil and water houses for the turbo to the block Inlet Manifold 4x52 or 55 mm quad Throttle body’s in air box Exhaust build up one .. I will use water/water cooler not a big intercooler. Like T16 standard Bellingo Hdi Gearbox / custom made clutch 300mm Brembo brakes. Front 266mm rear front 306 coil over suspension rear build a coil over system up that’s my roughly plan .. I have nearly everything what I need to build up this project , the only thing what I miss is time… there are nearly endless other projects what needs to be finished first ..but in the nights I will start to build up the engine. this time I will top the 441hp .. so this parts I will use.. ![]() ![]() ![]() ![]() so guy’s what u think ?
#2 |
Sounds insane magic, hope to drop down and see it when it's done. Best of luck with the build.
![]() -Chris |
#3 |
If I ever meet you Magic it will go something like this!!
http://www.youtube.com/watch?v=VQauQ6f72Zk Stu
2002 Scenic RX4 (France) 1996 Ford XH Ute (Australia) 2006 Husqvarna TE610 (Italy)Never trade the thrills of living for the security of existence........ |
#4 |
2000+
![]() ![]() ![]() ![]() Join Date: Mar 2003
Member#: 1270
#5 |
![]() ![]() ![]() Join Date: Oct 2007
Member#: 10956
Just a couple of things Magic:
a) You're a crazyman. b) Those conrods look gorgeous. c) You're a crazyman. d) What's required to fit the 307 crank in the XU block? (relax, I'm only asking out of curiosity). e) You're a crazyman. f) Try to eat & get some sleep once in a while. g) 441+ hp? ..... You're a crazyman!
#6 |
428.9
That's a serious looking set of conrods!
![]() Good luck with the project.
'05 Clio 182 Cup '88 205 GTi - Sold"The 288 GTO from the mid-Eighties, a car so manly you needed a handlebar moustache just to open the door." |
#7 |
After watching Magic work (building my new motor) I've learnt a lot and have the utmost respect for his knowledge.
I'm looking forward to seeing this motor, just wish I could have something like it in the rally car (although I doubt I could afford the parts). Looking forward to seeing him build a rally car and have some fun too!!! Cheers |
#8 |
This took 5 years....
![]() ![]() ![]() ![]() Join Date: Sep 2003
Member#: 1717
Formerly owned 405Mi16. Now pugless! It doesn't matter who you vote for - the government always gets in!
#9 |
Portmans benefit friend
Best to you Magic!! Sounds like a fun project!! Probably will end up being the quickest CTi in Aus!.(edit meant quicekst CTi in world??)!! - Chris
"...skinny little Nancy Callahan... she grew up, she filled out..."
#10 |
![]() ![]() Join Date: Feb 2007
Member#: 9769
looks good. jus wondering how did you source all the parts as i am interested in getting a start with sourceing parts 4 a 306 project?
thanks
I'm here with all of my people
#11 |
PM me
![]() ![]() ![]() ![]() Join Date: Apr 2006
Member#: 7682
That looks awesome Magic! I hope you'll put up a detailed account of the build
Good luck!!!!
#12 |
This car will be incredible.
98 GTI-6
#13 |
![]() ![]() ![]() Join Date: May 2004
Member#: 2659
Sounds awesome, think you should put it in a nice Mi16 body, then it would be the closest thing to a real T16 we'd ever see in Aus.
Ralph '93 Mi16 serII EMI16
#14 |
Wooowwww guys Thanks for that.
I Didn’t except this reaction from the forum. cheers for that . @jonnybabe d) What's required to fit the 307 crank in the XU block? (relax, I'm only asking out of curiosity). I had a Vision few mounts ago, and this week I replaced a sump of a 307 Hdi so I saw the crank in the block, this even motivated me more to go this way. The ew10 hdi engine is based on the xu 10 block. So I hope I can swap same parts. or I even use the diesel block and fit the rods and pistons in it. I don’t know yet , I have to measure all first .i hope it work out for me on same way. @rexxus let me taste blood with the rally sport , and I turn to a vampire the need for blood. @pommy360 looks good. jus wondering how did you source all the parts as i am interested in getting a start with sourceing parts 4 a 306 project? thanks after 16 years building 205 cars, I know what works and what doesn’t work. And I swear of made in Germany, so when you need same thing let me know, maybe I can help you @emi16 Sounds awesome, think you should put it in a nice Mi16 body, then it would be the closest thing to a real T16 we'd ever see in Aus I own 2x 405 T16 I bought one for petert but the car never made his way to AU. So when u want one let me know, is even cheaper that you think, the car. I wrote why I build it, but I deleted it, think will go to much in off topic and emotions. Let me say this, when you see the tears in the eyes of a Kawasaki zx9 or Yamaha r1 driver you know what I mean . when u have a totally hided weapon, that’s my world thanks all for that hear a video of the German Racewars 2005 i won it with the 205 CTI T16 in 2 classes http://de.youtube.com/watch?v=EdhJ7GG7HGQ
#15 |
![]() ![]() ![]() Join Date: Jan 2007
Member#: 9685
MEHRANG is it??
308 hdi touring (Mr) 207Gti Series 2 (Mrs) |
#16 |
2000+
Member#: 1270
Your dreaming if you reckon you'll beat an R1 or Kwaka.
Do you reckon you could do a mid mount in a 205 Magic? |
#17 | |
Quote:
The zx9 runs a 10.6 sec on 402m .. on a VW event I managed to run a 11.1 sec On a rolling start they don’t have any more the traction advance.. Any way you don’t cant image 441hp in a 850 kg car , so I understand your position very well. No I cant build a mid mount 205, no need for that.
#18 |
Member#: 9769
ok thanks magic ill keep that in mind. are most of the parts from germany anyway. is there any websites i could check out to see what there've got?
#19 |
2000+
Member#: 1270
Magic I reckon that the bike would win but I for one would love to watch that 1/4 mile drag.
I'll just have to buy a mid mount! |
#20 |
I took yesterday the HDI engine apart to check the parts inside,
It didn’t impressed me at all ..so I took the gti6 block to my Mate the engine builder, to overbore the engine. i had my relaxing day today , so I did a dummy build with my son. To check the clearness, And measured the hole lot again up.. I can’t write it down how good all is. ![]() both cranks the top one is GTI6 fully forged crank , with 8 counter weights the button one HDI fully F…d Cast crank with 4 counter weights so again the gti6 wins ![]() for my test fitting I used the old gti6 bearings .. ![]() no mercy ![]() ![]() ![]() married ![]() ![]() Tomorrow I will pull all apart, and send the crank, rods, pistons, flywheel , clutch, and crank pulley to balance all up I will take 1.5kg off from the Flywheel .. The cylinder head comes then next week .. I have a Special plan for this as well It is now 4 years ago that I build a T16 engine , and today I felled my heart is beating in the right rhythms again .. sorry for this big posting, i all ready took photos out..
#21 |
2000+
Member#: 1270
That's the ducks nuts.
Send me down a motor magic! |
#22 |
Member#: 10956
#23 |
I will quote my engine hear , so you guys get a idea how much it will coast a engine like this
My engine was a Citroen vts (gti6)with 28tkm with manifolds, air compressor, alternator, starter 3500$ Pistons rods . 3700$ Haltech e 11 2300$ Quad throttle bodies 2400$ Gearbox with quaife 2500$ new build gearbox Turbo Gt/30 rs 1600$ Exhaust & manifold 2000$ Water/Water cooler 1000$ T 16 part Brakes Brembo 2000$ with disc and pads Custom made coil over 2000$ Clutch kit 700$ Engine overhaul 1000$ gaskets, overbore, etc Cams (cat cams) 1000$ Waste gate & houses. Water pumps & dyno tuning , wiring stuff, etc 1500$ With out to listed all 24700$ and I do all by my self, so I don’t need to pay same one. And for what maybe 400 to 500 hp. Is it worth? Must decide everybody for him self, my advise ,never do this. i did it 4 years ago, and now i do it again. now I don’t need to write emails or pm’s any more, how much coast a T16 engine..
#24 |
![]() ![]() ![]() ![]() Join Date: Jan 2004
Member#: 2060
everyone snaps back to reality!
Awesome work Magic. It's good to see the insides of engines. Also makes me really want a GTi6 again...
HA ... volvo 760 v6 All gone now ![]() 2001 306 XSi mmm...Diablo Red 1983 505 STi. Has a slight drinking problem ![]() Past: '99 306 3-door. 83 kw of raw power
#25 |
Magic, you are so clever!
Here to learn....somthing......anything... ![]() 1990 Peugeot S1 405 Mi16 Lux Pack 'Pug-016' 1990 Peugeot S1 405 Mi16 1993 Peugeot 205 Si 1988 Peugeot 205 XLD 1972 Peugeot 504 Ti1990 Nissan S13 Widebody Rb30det
Previous Thread
Next Thread
Dashboard | All times are GMT +10. The time now is 10:29 AM. |
| Thread Tools | |
Home
New Posts
Register
'88 205 GTi - Sold
