macquered said:I think that even if the jack failed it still could have been the nature of the hydraulic system that causes an accident. Occasionally if I had to change a rear tyre you would have to raise the car to the highest position, then jack it, then as you were getting the wheel off then the rest of the car would sink to the lowest position. While it was lowering itself there always seemed to be a lot of movement where the jack was as the load shifted.
When the front height controller failed on my BX (at speed too!) I couldn't even jack it up to have a look underneath. The front spoiler on the 16v prevented me from driving it up on my ramps.
I found a traffic island nearby that I could slowly drive up onto (it was sitting on the bump stops) and then safely get underneath.
The way it was parked though, with one of the rear wheels cocked up in the air, looked like it was the scene of an accident. Even the police came around to check that everything was OK
fully sikXTC said:There is alot of movement there in some of those Citrons. (click to View)
- xTc -
- xTc -
Alan S said:.......which is the reason they specify a correct jacking procedure.
Suspension on highest, jack under, collapse suspension, remove wheel when it it has properly settled and has been checked for stability.
Alan S said:In the case of a height corrector's sway bar being loose, it would be getting a bit paranoid using that as a "common fault" as I've had hydraulic Cits for 22 years and never had a problem and know many more who haven't either, in fact yours was an almost extremely rare case which could have been avoided if it had been attended to as soon as the symptoms began to show.
Alan S said:However in the case of loss of fluid or the like which needed the car to be jacked, a scissor jack will lift it high enough for the Cit jack to be put under it or better still a trolley jack so that stands could be fitted.
- xTc -
macquered said:Is that procedure in the owners handbook? How do you fully collapse the suspension in the GS for example, when you don't have a low lever setting?
pugjet said:... dunno if its george 1/8 but i remember some cit af bloke who lived around the aspendale area - a stone's throw from seaford. think he owned a silver bx 16v.
Yes, redgum posts are great..they are the 5''x5'' ones I was talking about, corner fence posts from where I gerw up in Brisbane. Heavy as too.Kenfuego said:I always keep a supply of redgum blocks cut from old fence posts, they are solid, don't split or crack and its easy to flat pack them in a stable pile that wont collapse.
robo said:That was me who had the bx 16v now have a vts . I'm still here and so Is George 1/8 Heard from him today...
