It's bloody hot in Melbourne at the moment and there is no sign of abatement.
To the point.
Internal fan not working.
But remove it and solid wire 12volts and voila! It goes-flat out.:headbang:
Now I know what you're thinking! It not the $180 electronic controller because on professional advice I bought and fitted a new one.
On checking the 4 pin connector this is what I am getting
1 orange = 0 volts
2 black = earth
3 brown = 0 volts
4 red = 12 volts
On pin 1 & 3 as I slide the fan spees control across it full range (ignition ON)
ther is no voltage change as I would have expected.
I suspect a fuse, but as I don't have a handbook/manual does anyone know the position of the fuse and its value?
A friend who should know about these things suggested a power transistor that may have gone to lunch. But where is it on a 405 and is there an easy test?
How likely could it be an issue with the slider control (series 2 405) ?
Any other thoughts?
Please!
Predicted temp tomorrow 40 degrees in the shade!
To the point.
1 orange = 0 volts
2 black = earth
3 brown = 0 volts
4 red = 12 volts
Any other thoughts?
Please!
