I have just completed construction of a sphere testing rig. It is set up for LHS, so if you have an early D in central Vic come and test your spheres for free.
roger brundle
castlemaine
roger brundle
castlemaine
DoubleChevron said:Especially on cars you need to dissable in order to check the sphere pressure (eg: CX/GS rear spheres).
DoubleChevron said:Roger,
I have been thinking about making pressure tester for a while. I have the parts around the place to make about a dozen of them. My only concern is just how do I hook the pressure guage on. Obviously it goes straight into the regualtors output, however how do we create a flare the other end of the line in order to fit the guage ??
I guess I'll have to go upto the local "hose" place and find out
DoubleChevron said:We don't have to worry about 'overpressure' as the regulator will simply cutout if you pressurise to high and return the fluid back to the reseviour.
STALLED said:How much does the regassing of a sphere cost and how long do they generall last for?
Cyas Stalled
