I am about to import some competition parts from www.shenpar.com if you need anything, we can save some money by sharing the freight cost. You can either talk to Bob of Shenpar directly and let me know as well.
Shenpar motorsport provide very good advise on all suspension setup and engine mod advise.
Example of Parts they have at their site.
Peugeot 205 Competition Parts
Con Rod bolt/nut - chrome/moly £ 18.00 ea.
Sump Baffle Kit £ 145.00
Uprated oil pump spring £ 5.00
Oil Cooler Kit £ 130.00
Piper 4 branch exh. Manifold £ 180.00
Piper Exhaust System (stainless) £ 259.00
Piper Exhaust System (mild steel) £ 198.00
Magnex Exhaust Manifold /System £ 382.00
Magnex Exhaust System (with H/R Engine Mount) £ 275.00
Ashley Exhaust Manifold £ 150.00
Ashely Exhaust System £ P.O.A.
Inlet Manifold (Carbs/Throttle Bodies) 8 valve £ 130.00
Inlet Manifold (Carbs/Throttle Bodies) 16 valve £ 165.00
Engine Mounting Set (Hard Rubber) £ 88.00
Solid Lower Engine Mount £ 35.00
Ramair Direct Induction Kit £ 100.00
Cerametallic clutch plate (200mm) sprung or solid £ 150.00
Cerametallic clutch plate (16valve) sprung or solid £ 150.00
Steel Jointed Gearchange Kit 5 speed £ 100.00
Quaife L.S.D £ 490.00
Gripper L.S.D £ 550.00
Powerflex Anti Roll Bar Bush Set £ 21.50
Powerflex Front Wishbone Bush Set £ 49.50
Heavy Duty Front Wishbones £ 95.00 ea.
Rose Jointed Adj. Front Wishbones £ 295.00/pr
Gaz coilover,top adjustable suspension (adj.rear)kit £ 495.00
Bilstein Tarmac/Gravel Coilover Kits £ P.O.A.
Bilstein Front inserts Tarmac/Gravel £ 80.00 ea.
Bilstein Rear Shock Absorbers Tarmac/Gravel £ 80.00 ea.
Torsion Bars 20/21/23mm sets £ 300.00
Rear Stub Pin Disc/Drum £ 30.00
5 pos. Brake Bias Valve (lever / screw type) £ 65.00
Brake Bias Pedal Box £ 220.00
Hydraulic H/Brake Kit £ 48.00
Fly Off Handbrake £ 33.00
Aircraft Hose Brake Kit £ 10.00 per hose
Roller Bearing Suspension Top Mounts £ 100.00/pr
Quickshift Gearchange £ 45.00
Vertical Handbrake Lever (WRC type) £ 100.00
High gear steering rack £ 165.00
High gear steering rack kit (splined or flat) £ 100.00
Rose jointed Track Rod Ends £ 55.00
Wheel stud conversion £ 48.00/set
Polypropelene Sump Guard Kit 12mm £ 185.00
Polypropelene Sump Guard Kit 6mm £ 130.00
Polypropelene Tank Guard Kit 12mm £ 145.00
Polypropelene Tank Guard Kit 6mm £ 99.00
Solid Rear Beam Mounting Kit £ 35.00
Fuel Filler Protection Plate £ 30.00
Mudflap Kit £ 30.00
Rear Shock Absorber Protection Flap Kit £ 30.00
'Bike Carbs.' Conversion Kit £ 695.00
FSE Fuel Regulator £ 65.00
All Prices exclusive of VAT and Carriage.
Top of Page
General Parts
Terratrip 202 Plus £ 149.00
Terratrip 303 Plus £ 195.00
202 Plus + Remote Disp £ 208.00
303 Plus + Remote Disp £ 254.00
Probes (any fitting) £ 21.75
Clubman I/Com £ 79.00
Clubman H/Set £ 24.00
Professional I/Com £ 99.95
Professional I/Com Headset £ 27.50
Professional Practice H/Set £ 37.50
Terralight VA 18" £ 25.00
Terralight S 18" £ 25.00
Proffes.Navig.Footrest £ 27.50
Plumbed Fire/Exting £ 125.00
Hand Held 2k Fire Exting £ 55.00
F.I.A. Master Switch £ 24.50
Twin Carb Throttle Link £ 57.50
Silverstone 15"Gravel £ 80.00
Silverstone Tarmac 15" £ 85.00
Motordrive Club Seat £ 99.50
M/Drive Pro Seats from £ 195.00
'Bike Carb' Conversion £ 695.00
Mudflap Kit £ 30.00
Top of Page
General Parts
