I found it in a shed in Wellington, it had been in storage since 1971
It was covered in dents and scatches from things being stored on it for many years but the shell was almost rust free
So I have started on building another Dauphine race car. I am hoping it will be lighter and stiffer than number 1 and, as I will be using an R17 based motor and R16tx 5 speed box, I am hoping it will be faster than number 1.
First job was to get some mates around and strip the shell completely (and I mean completely) which we achieved in one day.
Second job was to build a rotisserie jig so I could work on the underneath easily (see photos)
Next job is to remove the front cross member and replace with a R8/R10 one. They are stonger and have the correct mountings for the longer top arms.
After that I will send it off for either dry stripping or chemical dipping and then off to have a roll cage fitted.
Could take a while - I think probably 2 years unless something happens to number 1 in which case it will get fast tracked.
Ross
Ross
