Firstly I need to give credit to Frans for all his hard work, machining and ideas in putting this together. Thanks Frans.
We initially talked about this gearbox and diff after the first targa (2002). It was obvious that we needed more top end in those long fast stages. With current gearing and 13" rims the car is getting 24km/1000rpm in 4th which equates to 168kph at 7000rpm red line. With this upgrade I was hoping for a 10% increase in top speed (185kph). I think we started work on it about mid 2003 so it has taken a while.
It is a standard R16ts gearbox and diff inside a R8/10 housing. Nothing new about that but what is different to others I have heard of on this site is that we have used equal thickness spacers on each side. That required much machining of the diff and the cups that hold the diff bearings.
The second biggest problem was the universals. I ended up having the standard yokes re cut with a new internal spline to match the R16 out-put shafts. I then fitted BMW crosses which are much stonger than the originals but because of their size do restrict up and down movement a bit (no problem on my car due to the stiff springs)
Other wise this was a fairly straight forward project. Total cost was only about $150 for the spline machining and about $200 for the crosses.
I hope to install it over the next week or 2, I will let you know how it goes.
Photos attached hopefully
Ross
Ross
