This website is for sale.
Click for details
#1 |
Tadpole
![]() Join Date: May 2004
Member#: 2655
I am modifying a 505 2.2 for gas. I've run this engine for 150,000 km with gas research carby and no problems but nowhere near the performance of my XN1 2 litre 404 ute with similar Gas Research. I,ve done some porting of the new 2.2 head and got GTI pistons which have a crown ( the old ones didn't)
What is the cam timing of a 2 litre Fuego? I roughly checked the GTI pug cam at 12-45 50-8. The cam in my ute is 26-60 60-30 and 9.8 compression. This is what I want. Is the Fuego close to that? The 2.2 as I ran it is a low revving slug. |
#2 | |
Administrator
Quote:
Inlet Opens:17dg Inlet Closes: 63dg / Exhaust Opens 63dg Exhaust Closes 17dg Probably a bit closer. Why not talk to the Gas research blokes....The Dourvin engine is pretty "normal", and should respond well to the same cam profiles that others have used in their 4 cylinders...... I'm sure people have run hot escorts and the like before on straight gas... |
#3 | |
Tadpole
Member#: 2655
Quote:
The douvrin valves are well suited to gas. There has been no valve recession over the 150,000. The chrome rings never bedded in properly though and the engine was never smooth so a balance is in order this time. Chris |
#4 | |
Administrator
Quote:
There can be a HUGE amount of difference between a "hard driven when new" Dourvin and a "run it in slowly" Dourvin....This is going to sound like an exageration, but it sometimes feels like the better part of 20hp
Previous Thread
Next Thread
Dashboard | All times are GMT +10. The time now is 10:37 AM. |
| Thread Tools | |
Home
New Posts
Register
