Here's the background.
Having not been able to give Zaphod the TLC he deserves for a long time now, I've been planning some quality time with him for a while.
Just recently, when cold, first thing in the morning usually, the steering has felt "lumpy" as if it was being fed from a pulsing supply. This would clear after a couple of Km so it was just noted in passing.
I've also been having the odd issue with rear suspension height. (Varying while sitting at the lights, all by itself!)
A bright thought struck me yesterday (and you could well ask why it took so long) that perhaps the main accumulator was flattish. Listening to the cycling of the pump seemed to add weight to this, it was cycling around 15 seconds or so. Also, the big red lights would go out quite quickly after an overnight inactivity. Both symptoms of a low accumulator.
So this morning I put the beast up the drive, depressurised and removed the accumulator. It tested at just under 300 psi, about 21 Bar. Spot on in the diagnosis I thought! I then proceeeded to dig out my spare accumulator which tested at 550psi (38B) which, while lower than the nominal spec of 62 bar is above the minimum specified of 30 bar.
In it went and after a bit of other minor works, such as repairing a leaking return hose on the LH strut and adding some grease to the strut shafts, I fired it all up, bled the regulator and cycled the suspension.
So far all good, cycle time around a minute or less so the accumulator is obviously doing its thing.
So let's go for a drive. What's this? The steering is awfully heavy. Yes, I now have what we used to call "Armstrong" steering some of the time. (as in unassisted). It seems to smooth out once you're driving, but is heavy on rapid turns and at parking speeds.
Can it be that my HP pump has gone (partially) to God? I've noticed a bit of a racket from the pump when swinging the steering wheel and on that basis I took the precaution yesterday of acquiring a spare pump from the esteemed Mr Cavanagh of French Connection (grovel, genuflect) so I can prove the point by swapping it I suppose.
I'm just curious that this appears to have happened quite rapidly, given that the car drove fine yesterday with no overt signs of heavy steering. I just don't see how changing the accumulator could trigger a failure in the pump? Perhaps the extra load of charging to a higher pressure has clackered out an already marginal valve or two? I'm guessing the suspension side of the pump is working fine as there's not obvious issues, but the P/S comes from the multi cylinder part as I understand it.
So does anyone have any bright ideas before I go and tackle the swap?
Cheers, Pottsy
Cheers, Pottsy
