Eurocars P/L - Peugeot
This website is for sale. Click for details
Perth French Car Festival - 17/10/10
Canberra FCD - 06/11/10
Go Back   aussiefrogs > Marque Forums > Peugeot Forum
Thread Tools
Old 8th Feb 2007, 12:09 PM   #1
Ren25
Fellow Frogger!
Ren25's Avatar
Member#: 1075
Default Hdi Particulate filter
I know this one has been alluded to in another post but I thought it neede one of it's own.
Does anyone know the story about the supposed secret container with the magic elixer on Hdi's that cleans the particulate filter?
It seems to be a bit of a mystery.
__________________
Mike
00 Pug 406 HDI
07 Cit C3
Ren25 is offline   Reply Reply With Quote
Old 8th Feb 2007, 01:37 PM   #2
phantom
Fellow Frogger!
phantom's Avatar
Member#: 9685
Default
yep sure do
fire away!
phantom is offline   Reply Reply With Quote
Old 9th Feb 2007, 11:34 PM   #3
littlebig
Fellow Frogger!
littlebig's Avatar
Member#: 8915
Default FAP Info
Go straight to the source. http://www.peugeot.com.au/PEUGEOT/AU...i_work_00.html
__________________
John
"Life's too short to drive boring cars"
______________________
Now .....
307 XS HDi Touring
and Then .....
505 STI '83
504 ti '74
504 Special '78
VW - '59 Beetle, '79 Kombi, '85 Caravelle
Subaru - '96 Impreza, '98 Outback, '01 Outback
littlebig is offline   Reply Reply With Quote
Old 10th Feb 2007, 12:12 AM   #4
Ren25
Fellow Frogger!
Ren25's Avatar
Member#: 1075
Default
And as far as I can work out that tells us diddly squat
__________________
Mike
00 Pug 406 HDI
07 Cit C3
Old 10th Feb 2007, 01:41 AM   #5
Stuey
2000+
Stuey's Avatar
Member#: 372
Default
I thought it had a heater element that simply more completely burned the particles.
__________________
PEUGEOT 405 Mi16
Stuey is offline   Reply Reply With Quote
Old 10th Feb 2007, 04:55 PM   #6
r5e
r5e's Avatar
Member#: 8892
Default How does the particulate filter work?
OK, this matter has been discussed at length in my own forum. The DPF(Diesel Particulate Filter, or as Peugeot say - FAP, which is the same thing in French) is commonly an excuse that manufacturers are using to tell people not to use biodiesel, hence my interest in it and the discussion in my forum on how it works and why they say this. Hopefully from this perspective, my understanding of it may answer your question.
In the bad old days (not long ago in Oz - prior to Jan '06), distillate (which we call "diesel") had quite a high sulphur content, up to 500ppm. The European specs demanded less sulphur of 50ppm, so finally Ultra Low Sulphur Diesel (ULSD) was introduced here, allowing many of the Euro manufacturers to import their cars to Oz.
Sulphur in the exhaust, apart from causing acid rain, makes it very hard for emissions reduction technology to work, as it clings to and fouls such things as catalytic converters and DPFs. So, now that we have ULSD we can start to use such technologies.
When diesel is combusted, there are unburned particles of soot present in the exhaust. These exit your pipe as smoke. The size of the particles vary and are not very good for health. The very small particles are the worst kind and recent studies are showing them to be very dangerous. A DPF is great, as it traps these unburned particles so they don't end up in the atmosphere or lungs.
So, how does it work? Very simply it has a mesh screen that traps the particles. It also has a sensor which measures the pressure/airflow to tell how blocked it is. When it reaches a certain measured point, it will heat the filter to burn off the particles stuck in it.
How does it burn off the particles in the filter/self purge? Simply by raising the temperature. It does this by injecting extra fuel into the engine, thus raising the exhaust temperature to a point where it is hot enough to burn the particles. There is a slight penalty on fuel economy when this happens, but it is worth it overall.
I hope that sheds some more light on it for you. If you were curious as to why they say DPF and biodiesel don't mix, it's because biodiesel burns much cooler, so the temp at the exhaust is about 100° cooler, so it will have difficulty getting hot enough to purge the filter. However, what they don't mention is that biodiesel has significantly less particulates, so the filter won't need purging. This is a bit of a simplification, but it gives you an idea anyway.
There has been a lot of discussion on this matter here, which may also explain the DPF a bit further, if you are interested.
__________________
www.biofuelsforum.com - Australian Forum for biodiesel.
www.sydneybiodiesel.com - Sydney Biodiesel Users Group.
www.biofuel.org.au - Australian Biofuel Users.
r5e is offline   Reply Reply With Quote
Old 10th Feb 2007, 08:57 PM   #7
Stuey
2000+
Stuey's Avatar
Member#: 372
Default
Thanks; now that you've written that I do remember reading about it in CAR magazine a while back.
__________________
PEUGEOT 405 Mi16
Old 10th Feb 2007, 11:02 PM   #8
Ren25
Fellow Frogger!
Ren25's Avatar
Member#: 1075
Default
OK so I'm dumb, spell it out to me. Does this mean there is no magic elixer, but we are just puting more diesel into the PF to "burn it out", or what? We are getting a lot of technical guff here but no real answers to the question put.
Forgive me but I am just a simple Pug D driver.
__________________
Mike
00 Pug 406 HDI
07 Cit C3
Old 10th Feb 2007, 11:14 PM   #9
littlebig
Fellow Frogger!
littlebig's Avatar
Member#: 8915
Default FAP, PEF, whatever ...
Check out this URL for some the PSA schematics and explanations. Hope it helps. http://www.peugeot.com/tradition/inn...chnologie.htm#
Click on HDi Diesel Engines, then clik on 'P' in the Automobile glossary. Then, click on PEF (Particle Emissions Filter) in the glossary word list to get the good oil from Peugeot.
Happy clicking!
__________________
John
Now .....
307 XS HDi Touring
and Then .....
505 STI '83
504 ti '74
504 Special '78
Old 11th Feb 2007, 12:26 AM   #10
Ren25
Fellow Frogger!
Ren25's Avatar
Member#: 1075
Default
Happy clicking!
Excuse me mate but where exactly are you coming from?
__________________
Mike
00 Pug 406 HDI
07 Cit C3
Old 11th Feb 2007, 09:36 AM   #11
SLC206
sans witticism
SLC206's Avatar
Member#: 1730
Send a message via ICQ to SLC206 Send a message via AIM to SLC206 Send a message via MSN to SLC206 Send a message via Yahoo to SLC206
Default
Quote:
He's a little confused perhaps.
Try this link to go there directly:
Particle Filter Technology
Anyway, the previous post by r5e, whilst excellent, left out a bit of vital information. The magic elixer is injected (when the clogging is detected to be of sufficient levels) to bring down the temperature required to combust these soot particles, and then the extra fuel is added, creating the combusting environment which eliminates the particles.
That is, the mixing of the magic elixer, extra squirts of the diesel injectors and the soot particles, results in a high temperature combustion process that clears all the soot out of the particulate filter and "regenerates" the particulate system, all controlled by an ECU.
__________________
Regards,
Simon
2007 207 GTi
2004 206 GTi180 2000 206 GTi 1995 306 XT
www.peugeotclub.asn.au
SLC206 is offline   Reply Reply With Quote
Old 11th Feb 2007, 12:23 PM   #12
Ren25
Fellow Frogger!
Ren25's Avatar
Member#: 1075
Default
Now we are getting somewhere! So we have to take the car to a Peugeot
dealer? Or can someone else do this servicing? I'm a little wary of actual dealerships as I think we pay a lot for the bling.
__________________
Mike
00 Pug 406 HDI
07 Cit C3
Old 11th Feb 2007, 05:47 PM   #13
SLC206
sans witticism
SLC206's Avatar
Member#: 1730
Default
What does your manual say about the whole thing, Ren?
I'm not even sure that the '00 406 HDi uses that particular system (unless you're referring to another car).
__________________
Regards,
Simon
2007 207 GTi
Old 11th Feb 2007, 10:25 PM   #14
littlebig
Fellow Frogger!
littlebig's Avatar
Member#: 8915
Default A French conspiracy?
Hey Mike, it's OK mate. There is no conspiracy. The PSA HDi gear we have bought with our hard-earned is clever, clean and economical. Do we really NEED to know more than that?
Well, curiosity ....
Yes there is an "elixer". And 'hands off' cause it is 'at the back'.
Yes, there is a "shot of fuel" when the filter is causing back pressure.
Yes, the engine burns really hot for a few seconds, causing the soot to combust cleanly.
And it is all managed by computers, and we don't even need glow plugs any more.
I love it all!
__________________
John
Now .....
307 XS HDi Touring
and Then .....
505 STI '83
504 ti '74
504 Special '78
Old 11th Feb 2007, 10:37 PM   #15
littlebig
Fellow Frogger!
littlebig's Avatar
Member#: 8915
Icon9 Confused???
Quote:
Thanks for the direct link. My browser didn't give me that info, so, yeah, I admit it ....... I'm
__________________
John
Now .....
307 XS HDi Touring
and Then .....
505 STI '83
504 ti '74
504 Special '78
Old 11th Feb 2007, 10:43 PM   #16
LeePower
Fellow Frogger!
Member#: 2576
Default
I love it all!
The HDI still has glowplugs, needs a outside air temp of arround minus 2 or 3 degree C to make the ECU require there use though.
__________________
2003 Pug 206 GLX TU3JP with ABS that works in the SNOW
LeePower is offline   Reply Reply With Quote
Old 16th Feb 2007, 06:33 PM   #17
littlebig
Fellow Frogger!
littlebig's Avatar
Member#: 8915
Default No glow to slow .... just turn the key and go.
O.K. I stand Corrected.
No glow plugs as in "turn-the-key-and-wait-for-the -light-to-go-out-or-you'll-burn-the-bloody-things-out" glow plugs.
__________________
John
Now .....
307 XS HDi Touring
and Then .....
505 STI '83
504 ti '74
504 Special '78
Old 17th Feb 2007, 02:38 AM   #18
Trevor G
Fellow Frogger!
Member#: 9760
Default
You're right :-)
The particulate filter (FAP) was introduced to 2005 diesels by pewjet and sitrone. So the 406 doesn't have one :-(
Trevor G is offline   Reply Reply With Quote
Old 17th Feb 2007, 04:59 AM   #19
Ren25
Fellow Frogger!
Ren25's Avatar
Member#: 1075
Default
Quote:
Originally Posted by Trevor G View Post
You're right :-)
Well thank God for that.
__________________
Mike
00 Pug 406 HDI
07 Cit C3
 Dashboard
Currently Active Users Viewing This Thread: ( members and guests)
View Who's Online
Forum Jump
Contains New Posts
Forum Jump
Copyright
Contains New Posts
All content is © to aussiefrogs.com PTY LTD 2009
ABN 14 126640024 & the author of threads/ posts
Thread Tools
Powered by vBulletin® Version 3.8.5 - Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.vB.Sponsors
