Hi Chris,
If you are using silicone make sure it is neutral cure - any acid residue from the normal silicone will corrode right through the reflectors. Might be worth looking at the high temp stuff they use for oxygen sensors, though it's not cheap.
I will be interested in your results, as my GS lights are not that good!
Paul
Paul
