Greeetings all
well I'm back at Mum's place and have taken over the garage yet again. This time it's to replace my dying starter motor and while I'm at it the engine mounts. Funnily enough when Craig posted his thread on replacing his starter motor a while back mine started sounding very sick.. to this point in time where I have to give it a tap tap tap to get it to work.
Anyway, I sourced a new Valeo fron Darrin in the UK and Richo very kindly rebuilt a couple of engine mounts for me.. as I feared they're so shiny they're too good to use.. they make the engine bay look like a pig sty!
I dived into it this afternoon and have taken a few pics for others reference as my D Special has the 4 into 1 exhaust manifold.. so not quite as involved as a double manifold.
Only 2 of the manifold studs came out with the nuts, the rest were very easy... likewise the clamp for the single down pipe. Once they were out of the way access was much improved. I now know what you were talking about Craig with the lower bolt on the starter motor...AGGGHHHH!!! I managed with my 1/4 drive and flexible elbow.. somehow..once it cracked they all undid easily.
I ended up removing the engine mount with the bracket attached.. you can see the height discrepency when compared with the new one.. Managed to get it back in before I ran out of light.. lovely weather up here so will carry on tomorrow.
Matthew
Matthew
