Mi16x4 Restoration
Results 1 to 25 of 41
Thread: Mi16x4 Restoration
    7,448
    Default Mi16x4 Restoration
    I started the restoration process on my Mi16x4 today. The paint has started to peel, the mechanicals tired and there's some rust in the firewall. The car was originally LH drive and converted here in Sydney in the early '90's. The firewall wasn't painted properly so cancer has unfortunately started. First stage of the restoration process is to remove engine/gearbox/transfer case and get the engine bay sand blasted so I can see the extent of the rust. No better place to start then at the front and work towards the back. All pretty much standard Mi16 at this stage, the only notable differences being the transfer case dipstick and the clutch cable, which comes in from the front, rather than the back.
    Another pic is one taken underneath, looking towards the rear. Sorry about the phone quality. You can see the fuel tank on the RH side of the driveshaft. The third pic is taken from behind the first muffler and O2 sensor looking forward. I added the sensor when I changed over from 2 row to 3 row management. It was impossible to get the bung any further forward at the time. Note there's no cat. under there, as it was a private import.
    Attached Thumbnails Attached Thumbnails Mi16x4 Restoration-mi16x4-engine-bay.jpg   Mi16x4 Restoration-fuel-tank.jpg   Mi16x4 Restoration-driveshaft.jpg
    Fellow Frogger! SilverGTi_6's Avatar
    Apr 2005
    839
    VERY cool.
    Love to see more shots as things progress. What are the plans? Restore to standard original? Crazy motor? T-16?
    Would love to have driven one of these. Must be super rare in Australia.
    Lotus Evora
    Peugeot 308 GTi
    1966 Volvo 122s
    Clio Sport Cup 182
    Previous
    Lotus Sport 111, C4 VTS, RCZ, 205 GTi, Volvo C30 T5-R, Honda S2000, 206 GTi180, Lotus Elise 111R, 205 GTi 6, Manual 406 coupe, 306 GTi 6, 405 MI16 (twice!), 505 GR
    7,448
    It's one of those cars that needs to be original to be worth anything. Having said that, there are faults and inadequacies in the original car that can be improved upon. In the short term, I'm going to put aside the original engine/gearbox/transfer case. I'll put in a 2L engine & custom spare gearbox/transfer box to drive around in, then restore the originals. The original ratios aren't that great, luckily I have spares. You can't add heaps of hp as the transfer case is a weakness. This was resolved with the T16 but you can't mix and match T16/Mi16x4 parts. I have a new, original set of seat cloths, so it should look very sharp once it's finished.
    Fellow Frogger! frog's Avatar
    Feb 2006
    600
    Great to see a thread and some pictures on this one!
    How do you find it compared to 2wd Mi16's to drive, apart from the D6C?
    Does it feel a bit heavier?
    Would you notice much power loss through the drivetrain when driving it vs. a comparable 2wd Mi16?
    What is the power ratio front to back? 50:50?
    Sorry for the twenty questions.
    If only someone had a BX 4x4 in australia.
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    919
    Nice work Peter.
    You have some new motivation since you started playing with your 205 I hope.
    I vote improved standard resto.
    205GTI - 8 valve, single cam coolness.
    7,448
    Quote Originally Posted by frog View Post
    Definitely not as brisk due to extra mass and driveline losses but is lighter to steer as the ratio is 53% front: 47% rear. Bigger top end due to slightly big cams. It has a lower 5th gear to help keep it on the boil at freeway speeds.
    Apr 2005
    839
    Think you are definitely doing the right thing with resto. Great stuff.
    How does she corner in comparison to a standard mi? I would imagine the rear suspension setup would be quite different?!
    Lotus Evora
    Peugeot 308 GTi
    1966 Volvo 122s
    Clio Sport Cup 182
    Previous
    7,448
    It still out handles most cars on the road, even 20+ years on. Compared to a normal Mi16, it's completely neutral until the end. The rear suspension is same as BX but with only one sphere.
    Apr 2005
    839
    Great stuff!
    Lotus Evora
    Peugeot 308 GTi
    1966 Volvo 122s
    Clio Sport Cup 182
    Previous
    1000+ Posts Poo-Go's Avatar
    Sep 2003
    1,420
    Great stuff, Pete, keep us up to date!
    James.
    Care factor = -273.15șC
    8,398
    .. it's completely neutral until the end......
    There is something mildly disturbing about the way you say that, Peter.
    Jo
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,352
    Moments? probably oversteers like any good old pug!!!
    Cam
    98 Xantia CT
    94 205 Gti Classic #9
    92 405 Mi16
    87 205 GTi Race Car
    1,708
    Its that 5th I want in my 205. keep up the good work its well worth it. Most impressed with your efforts.
    7,448
    Those 0.81:1 5th gears are hard to come by in Australia. I think diesels used them, so are more available in the UK.
    Here's something you may have not seen before. There is additional bracing between the gearbox and block where the flywheel inspection panel would normally be.
    I thought I should do a compression test before dropping the engine out. As suspected, there are problems:
    210, 210, 90, 215. With a slurp of oil it still only picked up to 120.
    Attached Thumbnails Attached Thumbnails Mi16x4 Restoration-gearbox-support.jpg
    12,256
    owen would be pleased to see the car returning to former glory
    great work peter
    1 x '98 306 GTi6
    Dec 2010
    Sydney, AUS / London, UK
    3
    Excellent stuff peter!
    Glad to see a few people are mad enough to renew one of these old beats. Have you considered changing the internals in the transfer case to the ones this guy is selling http://atdperformance.com/topic1/index-en.html ?
    I'm currently going through mine and fixing all the problems + cutting the rust out while I'm still in the UK and intend on bringing it back to Sydney when I eventually move back. Got a few spare transfer boxes to bring back as well
    Used her in anger last week for the first time since I bought her a year ago... 3 inches of fresh snow on the road, Porsche's struggling to stay in the straight line - brilliant fun Quite a strange sensation feeling the viscous-coupled diff working it's magic up a snowy hill.
    Anyway, best of luck! Hope you don't find any evil rust!
    Nov 2003
    Bondi
    3,352
    Quote Originally Posted by pugrambo View Post
    great work peter
    Well said. I agree
    Cam
    98 Xantia CT
    92 405 Mi16
    87 205 GTi Race Car
    7,448
    An uninspiring but therapeutic day removing bits in my quest to remove the engine/gearbox/transfer combo. I didn't need grit blasting to find these holes however. They both go into the cabin. There's also hints of rust on the LH inner guard.
    Attached Thumbnails Attached Thumbnails Mi16x4 Restoration-firewall-rust.jpg   Mi16x4 Restoration-rh-inner-guard.jpg
    7,448
    In the picture below you can see that the radiator support panel has taken a hit. It was quite hard to remove the middle bolt. Luckily Santa Claus had a new one in his bag! I can now safely cut this one out.
    Attached Thumbnails Attached Thumbnails Mi16x4 Restoration-radiator-support-panel.jpg
    1000+ Posts pgti6's Avatar
    May 2001
    1,612
    A great resto project Peter. I hope the tin worm hasn't got too far into it. Will you keep it the same colour?
    BTW-mine's got a slight bow in it too. Probably some clown using it as a jacking point.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Feb 2012
    Los Angeles, CA, US
    1
    Subscribed! Really excited to see the progress on this.
    Member JoshD's Avatar
    Oct 2003
    Hobart
    31
    Big job Peter, I'll be watching this real closely! Good luck with it all
    7,448
    Quote Originally Posted by pgti6 View Post
    I think the only way to tackle the job is with a rotisserie. Definitely keeping the standard colour. I found a sticker with "RAPS" on it. Could this be the code?
    Fellow Frogger! deltone's Avatar
    Perth
    390
    Nice one Peter, she is going to be a good one!!
    205 GTi T16
    205 CTi
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,863
    What country did the car originally come from? Odd - how there is rust in the guards!
    Good luck with the resto - last time I saw it was back at the AFCD in 2005!
    2005 Renault Clio 182 Cup
