R8 upgrade project - Page 32
Page 32 of 34 First ... 2228293031323334 Last
Results 776 to 800 of 829
Like Tree537Likes
Thread: R8 upgrade project
  1. #776
    528
    Trucks and the stones they flick up, a nice big star to repair....
    Sent from my G8441 using Tapatalk
    BR
    Building a race car is easy - building a race car that can be road registered is hard.
    For any custom fabrication call Precision One Off Engineering - Sydney 02 4587 8666
  2. #777
    Simon's Avatar
    6,203
    This really is an amazing build! That rear parcel shelf full of electronics is something else!
    J-man likes this.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
  3. #778
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    23,521
    Can you imagine Brett trying to sleep with all this whirring over in his head
    cheers,
    John
  4. #779
    Oct 2014
    Windsor 2756 NSW Australia
    645
    I believe those whirring noises go away if you have a good red wine with dinner.
  5. #780
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,298
    Quote Originally Posted by Bustamif View Post
    I think you really mean
    "I believe those whirring noises go away if you have a enough red wine with dinner"
    FIVEDOOR and JohnW like this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
  6. #781
    528
    New slotted brake rotors for our cars on eBay? Wtf?
    https://www.ebay.com.au/itm/Front-RD...ery!2759!AU!-1
    BR
  7. #782
    11,231
    Never seen them before.....
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Citroën CX Pallas 1980 (moved on to new custodian)
  8. #783
    Oct 2014
    645
    Quote Originally Posted by brettr View Post
    The photo does not match the description. Maybe I have missed something but they are only 7 mm thick solid discs with gas grooves machined in. Pretty much the same as early Formula Ford style.
  9. #784
    528
    Today's tasks, final an volt channel going in for an oil pressure sensor.
    BR
  10. #785
    528
    Assembly ready to go.
    BR
  11. #786
    528
    So I made some new supports to push the rear of the guard out to make the tires not so out from the actual car.
    But that pulls the guard forward more than an inch.
    So am modifying the rear of the cars body where the rear panel mounts.
    Hope it will all sit OK!
    BR
  12. #787
    528
    Finished, more curved, fits well.
    Brianbcs and 59 Floride like this.
    BR
  13. #788
    528
    A bit cleaner now with the 7" rims on.
    7" rear with A048's and 6" front makes the car handle quite nice.
    59 Floride and FIVEDOOR like this.
    BR
  14. #789
    528
    Today's tasks.
    The solid state relay probably doesn't have the specs to keep up with the ecu which leads to a fuel pressure dip, it's momentary but enough to baulk the engine on full throttle.
    So am going to wire this aeromotive controller into the ecu's pwm output and see if I can make it work....
    FIVEDOOR likes this.
    BR
  15. #790
    528
    And also tappet clearances today. Pretty lazy 8000 k's since rebuild and I haven't had the rocker cover off.
    Still looks cool though an 807 with roller rockers!
    Simmo1, FIVEDOOR, J-man and 2 others like this.
    BR
  16. #791
    Fellow Frogger! 21571's Avatar
    Apr 2013
    Geelong
    218
    Bit too late to get entered for this year, but fancy a trip to Geelong next year Brett? Be great to see your beast run a 1/4 mile.
    https://geelongrevival.com.au/
    J-man and Shoji like this.
  17. #792
    528
    Default oil pressure....
    That looks like a great day in geelong! Ive got a spare 5th gear set that i'm looking at having some new outer gear clusters made for about 18-20% rpm reduction.
    Just make the outers, machine out the original centres, freeze the centres, heat the outers, drop them on square then just a tiny bit of tig in a few places.
    I think Shoji was recently talking about oil pressure issues on an 807 so thought i would share my recent proper results.
    So it was good to get the modern oil pressure sensor in and wired / setup in the ecu.
    The electro-mechanical sender and old gauge didnt inspire confidence - it read quite low at hot idle, just off the bottom marker - i didnt even know if they were a matched pair....
    Good news is the proper readings now:
    Hot readings-
    23.9psi @ 812rpm (idle)
    Rises very quickly to:
    52.9psi @ 1892rpm
    And i was always taught 10psi for every 1000rpm:
    63.2psi @ 6273rpm
    Its a high volume oil pump rotor with the 5mm spacer i made with the standard pump body.
    I did modify the relief valve adding from memory about an 8mm spacer to increase the relief pressure.
    Also has mods to restrict the centre cam bearing flow and mods to various passages etc in the head.
    The high volume rotor must be the reason the pressure jumps very quick.
    And my oil pressure is almost instant. I run Penrite race synth full zinc no shear 15w/30 and 15w/50 mixed 50/50. I like that oil (not enough to put in my cooking though).
    Remote filter is upside down so can never run out and it has an adv obviously. Oil cooler itself is as low as possible so minimal syphon effect.
    All that being said i have seen an 807 that had not run for a few months and would not prime itself upon being started and running. The pressure never came up. I had to use the old outboard motor prime bulb into the galleries to get it to then start working.
    Attached is some ecu log screenshots - look in the parameters list and you can see the logged values for oil pressure. And yes it was a hot night so only 26 odd pounds of boost on the MAP.
    You can also see the AN4 GP temp - the gearbox runs at 60 deg - that's with an hour of vigorous tuning on it.
    JohnW, Simmo1, FIVEDOOR and 1 others like this.
    BR
  18. #793
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,191
    Hi Brett. Those roller rockers would be easier to adjust than the standard ones? Would love to know more about them if you wouldn't mind. Off the shelf for our 807's?
  19. #794
    528
    Hi Shoji,
    There was only 2 sets ever made in a custom run so i cant help you there im sorry - but i can share the noise they aide in making while testing launch control setup in my private work car park.
    J-man and bowie like this.
    BR
  20. #795
    Jan 2012
    Mandurah WA
    1,191
    Wow!
    Who has the second set?
    J-man likes this.
  21. #796
    11,231
    Quote Originally Posted by Shoji View Post
    Wow!
    Exactly the right question!! Nice looking top end, isn't it...
  22. #797
    Jan 2012
    Mandurah WA
    1,191
    If another run of these were to be made I would be in and I'm sure others would too.
    I don't like the fiddly original ones. It is a special tool for these or it's a pain with ordinary tools.
  23. #798
    Oct 2014
    645
    I believe the supplier for those rockers is RAU Rocker Arms Unlimited Rocker Arms Unlimited
    I doubt they have any off the shelf as Brett says however you may be able to convince them to do a batch. They sure look good!
  24. #799
    528
    New years res redo the guards to something better for the 7 inch rims.
    One slice and a final shaping stretch.
    bowie likes this.
    BR
  25. #800
    528
    Stitch weld...
    BR
There are currently 3 users browsing this thread. (0 members and 3 guests)
