R8 upgrade project - Page 31
Page 31 of 32 First ... 21272829303132 Last
Results 751 to 775 of 790
Like Tree486Likes
Thread: R8 upgrade project
  1. #751
    512
    Surge / pump unit heat shielded and ready to install.
    Sent from my G8441 using Tapatalk
    FIVEDOOR and Reidar like this.
    BR
    Building a race car is easy - building a race car that can be road registered is hard.
    For any custom fabrication call Precision One Off Engineering - Sydney 02 4587 8666
  2. #752
    512
    And installed.....
    Simmo1 and J-man like this.
    BR
  3. #753
    Oct 2014
    Windsor 2756 NSW Australia
    614
    OK, so more torque on the way. Would a gearbox cooler help the gearbox internals survive a little longer?. Worked for Porsche at Le Mans in the early days before they built bigger boxes.
    You are probably already making the fittings and the pump is on the way.
    J-man and Shoji like this.
  4. #754
    Oct 2014
    614
    Just to clarify, I know that input shaft has no signs of excessive heat, I was thinking more in terms of more volume of oil with some spray bars to direct oil to where its needed. That pitting on the input bearing shaft looks nasty.
  5. #755
    512
    Hey Chris,
    When I had the Ca18det in the car I had some problems with the hydro centre release bearing, you would let go of the clutch and nothing, then all of a sudden whack. Same as side stepping the clutch.
    That bearing you could actually see individual needle roller imprints in the race. Like it had them hammered in on the one place. That's obviously the main failure cause. Nothing to do with the supercharger or driving style, obviously.
    Also Steve swan would be guilty as the same as the rest of us for putting in the used bearing with 100k on it already. They look and feel great.
    If you've raced bikes you know that a bearing with even the slightest marks, just colour, will fail when loaded up for a while.
    All the other bearings felt great but had colour. I just turned a blind eye and reassembled it!
    For boost I'm going to put on a turbo and blow through the supercharger to twincharge it. It will compound boost.
    Throttle body stays where it is. And I'll use the gfb boost controller and a blow off valve to limit total boost to about 22psi.
    Before the new intercooler max boost on a cold day was around 12-14psi.
    Engine is 8.3:1 so I think if the charge temp is under control then 22psi should be fine.
    I can use a second water to air intercooler cooling on the same circuit.
    The water / meth injection will help too.
    Then there's the crankshaft, but I'm sure the Renault engineers forsaw twincharging on an 807 so I feel confident about that.
    BR
    FIVEDOOR, 21571, J-man and 1 others like this.
    BR
  6. #756
    512
    This is another pic of it, you can clearly see the momentary needle imprints...
    That would have quickly started its demise.
    BR
  7. #757
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    23,289
    " I had some problems with the hydro centre release bearing, you would let go of the clutch and nothing, then all of a sudden whack. Same as side stepping the clutch"
    Sounds like a cool launch control feature Brett
    FIVEDOOR likes this.
    cheers,
    John
  8. #758
    512
    Engine is all back in.
    FIVEDOOR, J-man, R8 Dream and 1 others like this.
    BR
  9. #759
    Apr 2002
    Montmorency
    55
    Hi Bret
    You might find the roller marks relate to the number or spline teeth , this is the weakness when transmitting significant extra power.
    On the UN 1 gearboxes Albuns make a single piece input shaft and cluster to upgrade the power upgrade to 400hp.
    May be worth looking at for the 330 transaxle for your application
    Rob Sealey
    R8 Dream likes this.
  10. #760
    512
    Ta rob.
    And more fans.
    BR
  11. #761
    512
    New air feeds...
    BR
  12. #762
    512
    Had the infrastructure to run a meth water nozzle on the intercooler so set it up.....
    BR
  13. #763
    512
    Installed a second fuel cooler....
    BR
  14. #764
    Oct 2014
    614
    Sneaky place to mount the EWP. I think the Alpine stickers take a little from the Gordini originality though.
  15. #765
    Jun 2018
    Norway
    128
    Amazing Just a question regarding the fuel cooler. Where did you get it and how much does it cool the fuel? Have a few thoughts fitting one to my car eventually.
  16. #766
    512
    It's just a Derale an6 connector cooler. $70 on ebay.
    I'm running it by cause the fuel gets heated as it goes through the fuel rail and it is plumbed back through the regulator to the surge tank so I just like the thought that it can try and get back to ambient temp along the way.
    BR
  17. #767
    Fellow Frogger! 21571's Avatar
    Apr 2013
    Geelong
    180
    Didn't think any fuel could possibly make its way past the fuel rail. #boost
    Sent from my SM-G973F using Tapatalk
    J-man likes this.
  18. #768
    512
    So had the insanity harness apart and added in another pwm controller for the new surge tank fuel pumps.
    And another pwm controller for the ic water pump and fans.
    Plus rewired a few channels and setup a gearbox temp sensor.
    R8 Dream and bowie like this.
    BR
  19. #769
    512
    This is the new setup in the old tank compartment.
    Uncomplicated....
    BR
  20. #770
    512
    Harness for the fuel pressure and fuel temp sensor and goes down to the oil pressure and temp sensor.
    Wiring insanity is over, this is the neatened view.
    COL, J-man and R8 Dream like this.
    BR
  21. #771
    Littlehampton, S.A.
    23,289
    Looks pretty straight forward Brett
    R8 Dream, BIGRR and Simon like this.
    cheers,
    John
  22. #772
    512
    Add a temp sensor to the gearbox to go to the ecu.
    BR
  23. #773
    512
    Mod up the intercooler water pipes, were being pinched.
    BR
  24. #774
    512
    Roll away.....
    FIVEDOOR and bowie like this.
    BR
  25. #775
    512
    Rolled to fit a 7" rim!
    J-man, Simmo1 and bowie like this.
    BR
