R8 upgrade project - Page 30
Page 30 of 30 First ... 202627282930
Results 726 to 740 of 740
Like Tree440Likes
Thread: R8 upgrade project
  1. #726
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,803
    Hmmm. Blue car - yella wheels? Got to see this one, brett. You might end up excommunicated by the fashon brigade for unholly colour mix.
    Check this out Schlitz, it will change your mind
    1965 Renault 8 Gordini for Sale | Classic Cars for Sale UK
    FIVEDOOR, JohnW and Shoji like this.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
  2. #727
    482
    Um the current set is yellow too! They've been on for 6 years already.
    I've never been worried about what others think.
    Personally I think there is nothing worse going to a car show and it looks like someone has gone mental with the ctrl c and ctrl v keys, but each to there own!
    So I started working this week on perfecting the cold start routines in the ecu. It's pretty close now to firing on the first revolution and settling immediately into a nice idle.
    I'm going to change the intercooler to an air to water and run the radiator up front then it will be ready for a dyno session.
    Checking the torque app this morning after 35ks to work in the traffic and it's showing under 8.9L per 100. I think by the time I get to a final tune it would be under 8 and also I wasn't driving it like an old lady either!
    Sent from my E5823 using Tapatalk
    J-man likes this.
    BR
    Building a race car is easy - building a race car that can be road registered is hard.
    For any custom fabrication call Precision One Off Engineering - Sydney 02 4587 8666
  3. #728
    Mar 2013
    olinda victoria australia
    635
    Very nice display, although Mr Plod could have a lot of fun with that print-out.
    They have developed an annoying habit of downloading one's computer data after an indiscretion
    Got a bit of a fright when scrolling through my GPS, to see it had archived "maximum speed achieved" . Oops
    Andrew
  4. #729
    482
    External TPMS in.
    Works very nice, pressure and temperature, and alarm settings for both.
    Shoji likes this.
    BR
  5. #730
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,255
    I've seen some teams with those things. How quickly do they adjust / refresh?
  6. #731
    Oct 2014
    Windsor 2756 NSW Australia
    522
    The reading is real time instantly. On a left hand bend you can see the RHS pressures rise as the working side tyres warm up under load. Some basic production cars have them too, the new Hyundai i30 comes to mind.
  7. #732
    8,555
    I've been looking at those things for a while, but was wondering how reliable they are. What I am concerned about is that they need to keep the pressure chamber open to the sensor somehow, hence a failure point introduced in the system, and I am not sure what you'd do if the seal failed. Does the sender have its own valve, or does it just rely on slightly depressing the tire valve to read pressure?
    ACHTUNG ALLES LOOKENPEEPERS
  8. #733
    482
    Chris is right it's a live feed.
    I've used it to settle on my running pressures. If I run 26 front and 31 rear and do semi-normalish driving then I get a pretty consistent 2 psi rise all round and virtually identical temperatures all round. So seems like a good split.
    And yes Schlitz it depresses the valve stem.
    And i wouldn't worry about introducing a weak point into the system as that is the sole domain of French car manufacturers.
    BR
  9. #734
    Brisbane/Australia
    1,972
    Tyre pressure monitors were also available as standard on some Renault models.
    This is a JA Scenic, no doubt other models have the feature available too.
    Doesn't tell you the actual pressure but if good/no good.
    Renault_scenic_owners_manual_2000 2.11.pdfRenault_scenic_owners_manual_2000 2.12.pdf
    Attached Files Attached Files
  10. #735
    482
    So been sitting for 7 months while I moved house amongst other things.
    Was sidelined from a leaking radiator, about the only part still from when I bought the car.
    Using a Nissan 300zx radiator for stock as it's dual row 56mm thick, crossflow, and 600mm wide so fits in between the sway bar mounts.
    Sent from my G8441 using Tapatalk
    bowie and J-man like this.
    BR
  11. #736
    622
    Quote Originally Posted by brettr View Post
    Welcome back Brett!
  12. #737
    4,286
    ‘Bout time buddy, we’ve been sweating on an update.
    KB
    JohnW likes this.
    KB
  13. #738
    482
    So it came up like this which replicated my old 600mm x 150mm counterflowed radiator.
    But no matter what we tried we could not get a weld seal on the centre seam tops on the opposite end to the pipes
    BR
  14. #739
    Oct 2012
    600
    The fin sections are some strange 1000 or 2000 series aluminium as the tubes are fusion brazed on. This is what I'm led to believe anyway.
    I had luck with 4040 filler rod sticking it to the tanks which were garden variety 5005 (structural butter).
    I was originally going to do something like what you have attempted but couldn't work out how I'd get the non pipe end to seal. If you don't get it right first time there is no way to go back and fix it.
    Sent from my Nexus 6P using aussiefrogs mobile app
  15. #740
    Oct 2014
    522
    When I did the Floride radiator I repeated the R8G setup with a core from Paul Weel (PWR) in Qld rather than go to a cheaper offshore alternative.
    I figured that if they have set the standard in Australia for race car applications and now have a big share of the race scene in USA it should be OK to use their core in my Renault 4 cylinder stuff.
    They did a thick core to my specs similar to the A110 factory unit and we welded the tanks on to our own design.
    The setup was initially track tested on a 37 degree day at Eastern Creek and kept the temps around 85 degree while putting a gap on most of the Clios and a couple of Meganes.
    I know the PWR stuff is more expensive initially but it saves a lot of time, stress and drama in the longer term and you have direct access to their engineers if you have any issues with design or thermo performance.
    Apart from the improved efficiency with a PWR core they are designed to withstand a lot of vibration and heat cycle stress so they are not likely to split or crack and are easy to weld.
    R8 upgrade project-tri5d9c.jpgR8 upgrade project-tri53c0.jpg R8 upgrade project-tri79c9.jpg
