R8 upgrade project - Page 29
Page 29 of 30 First ... 19252627282930 Last
Results 701 to 725 of 734
Like Tree437Likes
Thread: R8 upgrade project
  1. #701
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    18,344
    Great work, very impressive all around. May you enjoy great many miles in your beast.
    Just curious about the "nice drive", was the traction control on or off? or did you have a hand brake for company?
    Every day is a good day
  2. #702
    Simon's Avatar
    5,962
    That looks great, all pumped up looking for action! brettr (as in Rob Dickinson, not Rootes) is the Singer of the Renault world :-)
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
  3. #703
    481
    Sent from my E5823 using Tapatalk
    BR
    Building a race car is easy - building a race car that can be road registered is hard.
    For any custom fabrication call Precision One Off Engineering - Sydney 02 4587 8666
  4. #704
    481
    Plenty still happening.
    One uni decided to let it's magic needle contents come forth. 24x63.3mm is hardy spicer part number k5-a532. That's Alfa spider unis or probably better xtrail unis are 24x63mm and $15 compared to $75.
    So two new unis, and put the other sides double row rear bearing in - remember that Jose in Spain is wrong, it's 6.3mm off the hub rear face not 4mm.
    Same time checked the driveshafts on the granite top and they are both not straight. So I put 2 10s ones in that checked out as good.
    Drill out the ends and put the rubber centering stops in.
    Make a bracket for the water pipes.
    Then Friday drive to lindfield and at 530pm half way down the m2 in peak hour this happens.
    Got it home with no clutch and still the orig starter which didn't have the grunt to start it in gear so it was a full on calculated drive to the max!
    So this was a custom cable silver soldered into the Renault rod as it came when bought. So I need to make it better.
    So rummage through my stocks and find a Suzuki Sierra jx clutch cable. Easy to get a new one so cut the hook off the Suzuki pedal and weld onto the rod at 900mm between centres, make a new bracket bolted to the floor and a new clutch system was in. Temp bracket until I remake it now the size and shape is known.
    Then put in a new starter. Amazing the starter came from Melbourne off ebay new delivered for $100. So I bought the 2 available. Same time ran a second juicy 2 gauge starter cable and it starts excellent.
    Alot of tuning still going on and alot more to go in general....
    FIVEDOOR and J-man like this.
    BR
  5. #705
    Oct 2014
    Windsor 2756 NSW Australia
    392
    I would have expected the drive shafts/axles would have been something bigger. I remember seeing a larger diameter R8G axle from Meca but they dont seem to have it listed now?. I would have thought there would be something bigger than an 10S axle.
    I will be looking for axles and uni joints for the big box for my Caravelle/Floride project in the next few weeks so keep those part numbers Brett.
  6. #706
    481
    I have not destroyed an axle yet even with the turbo engine.
    These seemed both identical in their run out almost to the extent that it seemed like a manufacturer fault.
    Steve Swan reckons he has never broken an axle.
    And mecaparts still sells them I think 25 spline instead of 23 but resplining the unis doesn't leave as much around the spline.
    So far bigger shafts are not necessary unless you want to start shock loading the axles in lower gears like by having it lit up on dirt and running onto tar etc.
    My 2 cents.
    BR
  7. #707
    Ipswich, Queensland.
    1,769
    Although not having the power of your turbo, I never broke an axle either, but I did break 13 standard gearboxes.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
  8. #708
    Jun 2011
    Brisbane Qld
    18,344
    Respect
  9. #709
    9,322
    I knew you'd done a few, but 13.... Did you keep the bits out of interest? It would be worth retrieving energiser springs from the synchro units, of all things. Brett's done quite a job, hasn't he.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Peugeot 306 XT 1995 (daughter's)
    CitroŽn CX Pallas 1980
  10. #710
    481
    Aussiefrogs was so alarmed at Alan's breakage qty it went off line.
    FIVEDOOR, COL, J-man and 2 others like this.
  11. #711
    Mar 2013
    hampton victoria australia
    508
    I thought it croaked
    Andrew
    Quote Originally Posted by brettr View Post
    brettr and J-man like this.
  12. #712
    481
    Had some oil leaking from being forced up the dizzy drive shaft so I tapped the two drain holes and put M6 nipples in them and plumbed them to the catch can.
    Oil tight again!
    bowie likes this.
    BR
  13. #713
    481
    Then during the week each day going to work and back the quality of shifting is getting worse and worse.
    I put it on the hoist and I just can't understand why, everything looks ok.
    Then one morning I can't even get reverse. So after alot more investigation I find it.
    You couldn't really even see the crack until I flexed it.
    This is definitely a warranty claim through Renault.
    Slowly ironing out all the bugs......
    FIVEDOOR, bowie and J-man like this.
    BR
  14. #714
    481
    Finally put M5 nutserts around the inspection panel. Then put in another air tube into the intercooler. It ran up to 52deg max IAT after a good run today at the peak heat of the day showing 39 outside - IC spray was disabled.
    Engine was running at a rock solid 88, no matter what was being done.
    J-man likes this.
    BR
  15. #715
    9,322
    I put it on the hoist and I just can't understand why, everything looks ok. Then one morning I can't even get reverse. So after alot more investigation I find it. You couldn't really even see the crack until I flexed it. This is definitely a warranty claim through Renault.
    Slowly ironing out all the bugs. Sent from my E5823 using Tapatalk
    There's a first time for everything! Never seen that break before. Great job by the way!!
    Renault 4CV 1951
    Renault R8 1965
  16. #716
    7,774
    You can see the shoddy factory weld, it doesn't even go around the entire tube. Though it seems one weld is holding up fine, the other only penetrated halfway around, but the metal plate looks like it gave in to fatigue.
    Given these were welded manually, you can understand why they didn't bother too much.
    On the other hand, that was 50 years ago or so. Hmmm, half a century. Geez.
    ACHTUNG ALLES LOOKENPEEPERS
  17. #717
    9,322
    Geez indeed....
    Renault 4CV 1951
    Renault R8 1965
  18. #718
    Jun 2011
    Brisbane Qld
    18,344
    The failure is caused by flat changes into third to wheels stand the beast.
    J-man likes this.
  19. #719
    481
    Wish I had that much hp!
    I was going to build a bigger meth tank for above the pump but have given in temporarily to simplicity. Just bent up some stainless steel 3mm brackets and mounted the tank it came with.
    Then fill it full of Boost Juice and get to tuning.....
    BR
  20. #720
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Telopea. Bruz.
    2,595
    Oh you weren't kidding about the boot juice hahaha.
    J-man likes this.
  21. #721
    481
    Then these arrived.....
    Some new rears. 7" for the 205's will stop the bagging and reduce sway to a minimum.
    Will cut down the 9" rear guards to suit.
    COL, FIVEDOOR and bowie like this.
    BR
  22. #722
    Aug 2002
    2,595
    They are bloody beautiful, who made them?
  23. #723
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,227
    They are Madin Wheels.
    Mad'in Wheels - MadinWheel
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
  24. #724
    481
    They are just madin's courtesy of mecaparts.
    And only a paltry 853 euros delivered.
    Oh hang on, I was using the conversion from paseo's, I just looked at the euro conversion and suddenly feel unwell.
    And to answer ceenines question of will it ever make it to the road this has been done in the last month or so as a daily driver.
    J-man and bowie like this.
    BR
  25. #725
    7,774
    Hmmm. Blue car - yella wheels? Got to see this one, brett. You might end up excommunicated by the fashon brigade for unholly colour mix.
