R8 upgrade project - Page 28
Page 28 of 30 First ... 1824252627282930 Last
Results 676 to 700 of 734
Like Tree437Likes
Thread: R8 upgrade project
  1. #676
    It's how I roll...Brisbane
    31,978
    Quote Originally Posted by brettr View Post
    I was a little worried about putting this FuelLink in as the car wouldn't be standard anymore and I might be frowned on by club members
    The only standard I'm seeing here is a very high one Brett. Staggering really.
    You do realise you are making the rest of us look pretty average..? But keep up the good work anyway.
  2. #677
    481
    Just trying to live up to my black sheep standard 59f.
    Meth injection / ic spray pump and tank in and plumbed and wired....
    It's a 300psi pump!
    Sent from my E5823 using Tapatalk
    R8 Dream, J-man and bowie like this.
    BR
    Building a race car is easy - building a race car that can be road registered is hard.
    For any custom fabrication call Precision One Off Engineering - Sydney 02 4587 8666
  3. #678
    481
    The CAS was tired and the Nissan disc has too fine a resolution at 360 slits to use it running off the oil pump / cam drive as there is definitely backlash. This was generating a unstable rpm signal sometimes showing max rpm of over 14k.
    So change it over to an AEM 24/1 wheel. Rpm is rock solid now.
    Then extend the obd port to the front to make it generally available to plug into.
    Then using it I setup the HUD. Nice.
    Big day tomorrow, I mean today.
    J-man likes this.
    BR
  4. #679
    Fellow Frogger! Ceenine's Avatar
    Devonport, Holiday Coast
    383
    Default Complexity
    All this technology is fine, but will the vehicle eventually proceed down the road?
    2014 C5 2.2 HDI Limited Edition Sedan
    2007 C5 2.2 HDI Hatchback
    2007 C4 1.6 HDI EGS Sedan
    Peugeot Mi16 Series 2
  5. #680
    383
    If it does I would like to see it in Targa Tasmania. I would hate to see all that technology and expertise wasted.....or against a tree for that matter!
  6. #681
    481
    Neither would I!
    More console work.
    Seats, seatbelts, fire extinguishers.
    A quick polish and a new top windscreen look.
    All done and running for tomorrow if I can wake up!
    BR
  7. #682
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    21,791
    Incredible effort Brett. Your ability would probably give those folks at NASA a good run for their money. You both make rockets!
    Where's the dashcam so we can all come for a spin?
    cheers,
    John
  8. #683
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    2,826
    yeah do a skid
    Ceenine likes this.
  9. #684
    Oct 2014
    Windsor 2756 NSW Australia
    426
    It probably has traction control too. But that wont let it skid
  10. #685
    481
    Yes but can turn the traction control on and off, but I haven't done the front and rear wheel speed sensors yet, I've just interfaced a gps module to the ecu currently for speed signal in.
    So pull the new old tank.
    Make a base.
    Make a backing plate, lots of curves and stuffs.
    Fold a cover up.
    Test tape it up ready for a some tacking and then the end caps.
    Test fit.
    Tank is behind the front axle centreline too. More tomorrow.
    BR
  11. #686
    4,038
    Still got the original wiper motor?
    KB
  12. #687
    Fellow Frogger! Ross's Avatar
    Auckland NZ
    382
    Hi Brett
    A couple of things you probably have already thought of.
    1. Being a wide narrow tank you will need lots of baffling inside (or explo-safe foam) to avoid the fuel sloshing around
    2. I always put a small pot in the lowest point in my tanks and take the pickup tube off that to avoid fuel starvation on those long sweepers.
    Ross:
    1989 Alpine GTA Twin Turbo
    1963 Renault R8
    1996 Peugeot 106 S16
    1967 NSU Prinz 1200TT
    1989 Peugeot 205 GTi
  13. #688
    Oct 2012
    573
    What's the tank capacity? I don't suppose you have a drawing?
    Sent from my Nexus 6P using aussiefrogs mobile app
  14. #689
    481
    No drawing sorry, was going to and offer to see if others wanted one but thought probably not worth it.
    I just have the cardboard templates now.
    With foam etc should be somewhere between 40 to 45L.
    And yes Ross foam is ready and it's in tank pump so no pickup tube as such but the pump has its own surge pot pickup. And this tank was made on your advice behind centreline so consider it your design!
    BR
  15. #690
    Oct 2012
    573
    Well I need a tank and I'm sure others would want one. A CAD model could be made from the templates easy enough. Then if there is a bulk order we pass it over to an aluminium fabricator who does automotive work.
  16. #691
    Oct 2014
    426
    Hi Brett,
    I see you have a tube style fuel level sender. An installation tip you may already know for those senders in a foam filled tank is to heat tube of correct diameter and push it into the foam to make a clean cut. It avoids the need to "cut" a hole in foam which can also create very small bits of foam residue inside the foam structure that can find its way into lines and filters etc.
  17. #692
    Oct 2014
    426
    [QUOTE=c.lees;1532696]Well I need a tank and I'm sure others would want one. A CAD model could be made from the templates easy enough. Then if there is a bulk order we pass it over to an aluminium fabricator who does automotive work.
    Sent from my Nexus 6P using aussiefrogs mobile app[/QUOTE
    I think Brett knows a guy who is an aluminium fabricator, his business is called Precision One Off Engineering - Sydney 02 4587 8666. He does CAD drawings too
  18. #693
    481
    Details of the pump setup.
    BR
  19. #694
    481
    And it will be something sort of like this. Bout 5mm filler cap to bonnet.
    BR
  20. #695
    481
    Tank is foamed and buttoned up ready to go. Just checking line routings. Have calibrated this sender to the Renault gauge so 240-33 to 350-0.
    J-man and R8 Dream like this.
    BR
  21. #696
    481
    So tank done and in final. Its about 45L.
    Then cut and shape and fold a cover.
    Trim to shape and pinchweld. No injection pump or lines or wires visible. Nice.
    FIVEDOOR, J-man, R8 Dream and 2 others like this.
    BR
  22. #697
    481
    Change the door graphics with some matt black roundels to suit the matt black stripes.
    Finish the insulation off. Makes the car feel more solid while driving actually.
    Matt carbon wrap and new rubber top pinchweld for the tank cover.
    J-man, FIVEDOOR and R8 Dream like this.
    BR
  23. #698
    4,038
    Great Stuff. That tank looks sensational with the carbon wrap.
    I was thinking "why bother, the aluminium will look nice" but the wrap looks much better.
    I was planning to carbon wrap my dashboard, I think you've just sold me.
    KB
  24. #699
    Oct 2014
    426
    Great fuel tank solution for an R8G upgrade. I agree the carbon looks better than the ally for some reason.
    Funny how builds can go, I made a carbon fibre dash then painted it in wrinkle finish to make mine look like an old R8G .
  25. #700
    481
    Up at the Hunter for the French car day at nightingale winery.
    Nice drive through peats ridge road and through to Wollombi.
    Apparently mg club is coming for a mini battle of Waterloo.
    Should be a good day! Here's the events mascot pic....
    I suppose they will be making bagels?
    R8 Dream, FIVEDOOR and J-man like this.
    BR
There are currently 2 users browsing this thread. (0 members and 2 guests)
