R8 upgrade project - Page 27
Page 27 of 30 First ... 172324252627282930 Last
Results 651 to 675 of 734
Like Tree437Likes
Thread: R8 upgrade project
  1. #651
    481
    How did you know?
    Oh, you mean my wife.....
    Sent from my E5823 using Tapatalk
    FIVEDOOR likes this.
    BR
    Building a race car is easy - building a race car that can be road registered is hard.
    For any custom fabrication call Precision One Off Engineering - Sydney 02 4587 8666
  2. #652
    481
    So took the family away for a few weeks. Now I'm back I have to get the lead out.
    So sound deaden the rest of the floor.
    Put the undertray I trimmed in, stereo etc, gearshift, then start on the carpeting, as I said im no motor trimmer but I'll give anything a go....
    Finish the pedals and foot rest and put in some kick panels.
    Then start on the rear.
    Still so much to go.
    dimistyle, Shoji and J-man like this.
    BR
  3. #653
    481
    So more to the gt feel.
    Needs proper seat belts so grab some jx Suzuki Sierra belts to mock up a fit.
    Seems my south African shell has the b pillar holes for shoulder mount but no captive nut. Bummer.
    So I silver solder some coat hanger on the head of a seatbelt bolt then holesaw the pillar top and put in.
    Then mod the seat belt stalk bottoms to make a perfect fit for an R8 in the original anchorage points. Nice. Then trim up the rear carpet ready for glueing.
    Add a Bluetooth microphone to the steering column.
    Cut the front wheel arch carpet ready to glue and trim the front side wheel arch kick panels.
    Then start work on the centre console which will house the cruise control, traction control and some usb power stuff.
    Still much more to go.....
    BR
  4. #654
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,374
    Frans,
    I am puzzled for the need for a "4 lb hammer"....
    Please Explain !!!!!
    Otherwise it looks very, very nice !!!
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
  5. #655
    481
    I just went down to my garage to say hi to Frans but he wasn't there.....
    I must have just missed him?
    J-man and FIVEDOOR like this.
    BR
  6. #656
    481
    So setup a voltage divider on the vl commodore cruise control switch set.
    It will generate 4v for on / off, 3v for resume / accelerate, 2v for reset / decelerate and 1v nothing pressed.
    Then finalise the centre console with some power outputs.
    Then mod the ecu and ecu case for ethrottle and all the additional I/O's and a odb fly lead so I can put a permanent Bluetooth odb sender so I can link into the ecu with the phone.
    Then prep the rear shelf with some sound deadening ready for the ecu etc mounting.
    Plenty of wiring on today amongst other things.....
    FIVEDOOR and J-man like this.
    BR
  7. #657
    481
    Boot area today. Because I've moved one booster and in preparation for the new fueling system and tank and ecu setup a fair bit of wiring was required.
    So all new relays and alot of new harness and a dirty big heat sink for the ssr for the fuel pump.
    Everywhere I look there is wires.....
    BR
  8. #658
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    21,781
    I'm not sure you're challenging yourself enough here Brett. I think you should use all black wires
    FIVEDOOR, bowie, 27of85 and 1 others like this.
    cheers,
    John
  9. #659
    481
    Another day and the nerve centre is coming together.
    Meth injection kit arrived yesterday amongst some other stuff....
    BR
  10. #660
    Oct 2014
    Windsor 2756 NSW Australia
    422
    I am not surprised you decided on the meth injection but it took you longer than I expected.
    Do you really have to take out the rear window to change a relay ?. Maybe a lexcan rear window with a removable inspection cover.
  11. #661
    481
    The meth is only in prep for the twin charge when I add the turbo.
    So after a marathon the wiring came up like this.
    Then like this. Wiring is mostly done, finally.
    It's chocoblock full of diodes, resistors, caps, etc etc etc.
    Then setup the boost controller, which will also act as a second bypass at low throttle (I hope anyrate).
    Then finished off the rear parcel shelf speaker board.
    Ethrottle mount and new fuel tank dev next.....
    J-man likes this.
    BR
  12. #662
    Apr 2002
    Montmorency
    51
    Hi Brettr amazing job mate, I would like to see the G do it's stuff.
    Rob
  13. #663
    481
    Ta Rob, I cant wait to turn the key again as well so I can see how many things I miss wired...
    So strip some old graphics.
    Remove the old spot bar as I broke one.
    Add a new set spot lights, and put on some original style gordini stripes, but in mat black because in the eyes of the RCCA I'm the black sleep.
    Remove the fuel pumps and add a fuel cooler.
    Run the meth line, looking mostly neat underneath.
    Mount the charcoal cannister for the fuel tank under the front.
    It's got to be running for next weekend! Better get a move on!
    J-man likes this.
    BR
  14. #664
    Oct 2014
    422
    It is all very tidy now despite the extent of all the mods. The underside looks good, especially since it gets driven around some semi rural roads.
    What sort of sound sound deadening/sealer did you spray on the underside ?
  15. #665
    481
    Bm. Just a rubber based one from supercheap.
    First this stupid hoodlining....never again. Worst job I've ever done.
    Then ethrottle mount dev and meth nozzle. It's all done....
    FIVEDOOR, J-man and JohnW like this.
    BR
  16. #666
    9,717
    I take my hat of to you for all this work! Thanks again for sharing it with us so thoroughly.
    I reckon tackling the roof lining is the icing on the cake for effort. I'm sure it is a horrible job unless you do it all the time. Did you buy one (they are available) or take the even harder route and start with a roll of cloth?? I freely admit paying for that to be done to my 4CV.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Peugeot 306 XT 1995 (daughter's)
    CitroŽn CX Pallas 1980
  17. #667
    481
    I bought one from mecaparts John. The rear bow from my old one is longer than the other bows, is that right?
    The whole thing just doest fit nicely and I did a crap job.
    It looks like an big old ladies saggy panties.
    BR
  18. #668
    9,717
    I do sympathise! I've no idea regarding the bow lengths I'm afraid. I'd have thought all the R8/10 range had the same roof but maybe they changed the structure internally? Simon might know.
    I've had a few bows in the workshop for many years as a source of good steel rod though....
    Renault 4CV 1951
    Renault R8 1965
  19. #669
    481
    So mount a clutch switch for launch control and cruise control disengage for the ecu.
    Then the ic spray and meth solenoids and ic spray nozzle in the forced air tube, still need to make the cover around the ic.
    Mount the ethrottle body / meth nozzle.
    Finalise the boost controller valve.
    Lots to do tomorrow, hope to turn the key, will mod up the legacy tank for the moment.
    J-man likes this.
    BR
  20. #670
    548
    My God!
  21. #671
    481
    Put in the rear windscreen with a new seal. That was not fun.
    Wire the obd port in and permanently attach a Bluetooth obd sender.
    Dodge up the old fuel tank with some new brackets and mount the Bosch 044 main pump and lift pump etc in the front boot. 044 runs off the 100A ssr via pwm provided from the ecu.
    Mount and setup the FuelLink. Will take any ohm reading sender and reshape to any ohm gauge. Has a full calibration routine for accurate needle readings plus outputs from average sampling so a rock steady needle.
    I was a little worried about putting this FuelLink in as the car wouldn't be standard anymore and I might be frowned on by club members.
    Add an air filter setup to the ethrottle.
    Have started the car and begun tuning the ethrottle.
    Lots to accomplish by Sunday morning!
    J-man and bowie like this.
    BR
  22. #672
    Littlehampton, S.A.
    21,781
    Not sure why Brett, but the word "Insane" comes to mind!
    Keep the shocks/surprises coming. I've learn't to expect the unexpected with you
    cheers,
    John
  23. #673
    Mar 2013
    hampton victoria australia
    568
    Now that you're almost finished, could you build one for each of us?
    Amazing job
    Andrew
  24. #674
    481
    Almost finished?
    BR
  25. #675
    481
    I'm still soldering right at the moment!!!
    BR
