It's always worse than it looks
Results 1 to 25 of 25
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    384
    Default It's always worse than it looks
    Back in the days before the crash of 2010 I had a thread about the refurbishment of my 1963 Peugeot 403B, this is a re-creation
    I bought a 403 that had been a daily driver, but was taken off the road because of a smoky engine, and that's a story worthy of another thread.
    The interior was pretty good, but it had very rusty doors. It didn't appear to have any other rust. Yeah right!!
    I am gunna get another 403 on the road........one day
    Jun 2002
    Gunbower
    384
    Default It begins
    I had some good doors, so I decided to fit them and give the car a paint job.
    First step was to remove the sill covers, thats when I found this.
    It's always worse than it looks-100_0313.jpg It's always worse than it looks-100_0314.jpg
    Passnegr side sub-frame rear jack point
    It's always worse than it looks-100_0312.jpg It's always worse than it looks-100_0327.jpg
    Passenger side floor
    Jun 2002
    Gunbower
    384
    Default Some repairs needed
    I started work repairing the sill (inner and outer)
    I cut out the rear section
    made up a repair section
    and welded it in
    Then cut out the front section
    and repaired the inner sill
    Jun 2002
    Gunbower
    384
    Default Front floor
    The passenger side front floor was a bit thin
    So I cut it out and made up a repair section
    and welded it in
    Jun 2002
    Gunbower
    384
    Default Next
    came the sub-frame
    It's always worse than it looks-100_0340.jpg It's always worse than it looks-100_0343.jpg
    It's always worse than it looks-100_0344.jpg It's always worse than it looks-100_0345.jpg
    Jun 2002
    Gunbower
    384
    Default Then came
    the rest of the sill
    Jun 2002
    Gunbower
    384
    Default Driver side
    After removing the drivers side sill cover I discovered it was worse than the passenger side.
    It's always worse than it looks-100_0351.jpg It's always worse than it looks-100_0352.jpg It's always worse than it looks-100_0353.jpg
    so the cutting and patching continued.
    It's always worse than it looks-100_0359.jpg It's always worse than it looks-100_0360.jpg It's always worse than it looks-100_0361.jpg
    rear jack point
    It's always worse than it looks-100_0354.jpg It's always worse than it looks-100_0355.jpg
    Jun 2002
    Gunbower
    384
    Default After the rust
    With all the rust work done, the car was off to the painters where it was stripped of all trim , glass, door handles and lights and scaped back to the original undercoat..
    It's always worse than it looks-100_0439.jpg It's always worse than it looks-100_0438.jpg
    The replacment doors were also stripped back and prepared
    Jun 2002
    Gunbower
    384
    Default Some assembly required
    After the car came back from the painters, with it's fresh coat of 2 pack, the job of putting it all back together began. New window tracks and door seals all round.
    It's always worse than it looks-100_0507.jpg It's always worse than it looks-100_0555.jpg It's always worse than it looks-100_0554.jpg
    It's always worse than it looks-100_0550.jpg It's always worse than it looks-100_0551.jpg It's always worse than it looks-100_0552.jpg
    The assembly took ages
    Jun 2002
    Gunbower
    384
    Default The next phase
    After all the body work was re-assembled
    It's always worse than it looks-100_0642.jpg It's always worse than it looks-100_0643.jpg
    The front and rear sreens were re-fitted
    Next came the task of getting the car roadworthy.
    Page, AZ
    79
    Fantastic pics and very inspirational! Just in the nick of time as I'm about to start on a major push to get my Dee painted/derusted etc...
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,042
    Quote Originally Posted by iron oxide View Post
    DS Chassis...Hmmmmmm...yep that is a good place to test your rust repairing skills!!
    Cheers Gerry
    PS ---Great work on the 403. They look like very well made repair panels. Care to provide some how to notes??
    Fellow Frogger! Binky's Avatar
    15 Credibility st. Nth Fitzroy, Vic.
    227
    Very impressive!
    I was proud of my 504 buttress panel repair, but your work leaves mine for dead!
    ...I guess we've all got to start somewhere though...
    I'm just glad to see another 403 saved!
    Congrats
    5,312
    Quote Originally Posted by PCOATES505 View Post
ID:	9633 Click image for larger version.
ID:	9634 Click image for larger version.
ID:	9636 Click image for larger version.
ID:	9637 Click image for larger version.
    Now I know why you folk call 'em headlamp buckets! (pics 4 + 6)
    Bet you don't get that thing finished by Christmas.
    Mike.
    Started out with nothing, still got most of it left.
    Jun 2002
    Gunbower
    384
    Default Rofl
    I thought the plastic wouldn't rust, but it was too big for the hole.
    cheers Pete
    Jun 2002
    Gunbower
    384
    Default justifiably
    Quote Originally Posted by Binky View Post
    Very impressive!
    I thought you did a bloody good job too!!
    cheers Pete
    Jun 2002
    Gunbower
    384
    Default Easy
    Cheers Gerry
    When you have the tools, I had the use of a friends workshop with a guillotine and folder.
    This was hand bent around a piece of pipe, then the edge bent in the folder. I later went along the other edge with a flanging tool
    Flanging tool
    3,042
    Flanging tool
    Availability of tools is a significant factor. I make do with clamps and bars for use with an I beam edge to bend metal with planishing hammer and dolly. Aviation snips and metal blades in a jig saw for cutting. I have been able to make some fairly complex small panelsm but these tools introduce distortion when making long straight pieces. A Guillotine and a folder would be heaven. I once saw a diagram on how to make a folder out of cheap steel sections available from any local steel merchant. Wish I could find it now!! Keep up the good work.
    Cheers Gerry
    Northern NSW
    1,048
    Great work Pete, what kind of welder are you using? TIG?
    Greensborough, Victoria
    359
    Pete good to see this thread back and the images. It like getting a whole comic at once.. instead of the weekly installments.
    Jun 2002
    Gunbower
    384
    Default If only
    Quote Originally Posted by luthier View Post
    All the work was done with a MIG, I don't think my eyesight is good enough to use a TIG.
    Sometimes when I am welding I do the most perfect looking weld.................right next to the join that I was welding. Wish I had young eyes again.
    cheers Pete
    Jun 2002
    Gunbower
    384
    Default Should I
    continue the engine rebuild here or start a new thread??
    cheers Pete
    3,042
    cheers Pete
    Put it in here so that it is easy to find and that we all know to which car it relates.
    Cheers Gerry
    PS I found a set of plans for a Sheet Metal Bending Brake. Some people may be interested.
    http://www.millerwelds.com/
    Click Do it yourself tab-----welding projects------scroll to bending brake and click!!!!!!
    Let me know if anyone makes one!!!!
    Fellow Frogger! sideways_505's Avatar
    Perth W.A
    390
    Very nice work!
    403s can rust all right! Mine came with $4200 worth of receipts for work done just to the sills! Then there's all the rust in the doors and boot and engine bay and.......... That I have to fix.
    I wish I had the tools you do, I'm slowly building the collection, haven't even got a MIG yet though.
    Thanks for sharing.
    Hayden
    Jun 2002
    Gunbower
    384
    Default Smokey motor
    [QUOTE=PCOATES505;903585]Back in the days before the crash of 2010 I had a thread about the refurbishment of my 1963 Peugeot 403B, this is a re-creation
    I bought a 403 that had been a daily driver, but was taken off the road because of a smokey engine, and that's a story worthy of another thread. QUOTE]
    After getting the body work finished I set about getting the car roadworthy. The car had been serviced and repaired by a prominent Melbourne service centre and had buckets of money spent on it in its 5 years as a daily driver, until it was taken off the road because it was blowing so much smoke. The previous owner told the mechanics about the smokey motor, so the motor was removed and repaired, which consisted of one s/hand piston, new rings, new big end bearings. After re-fitting the motor continued to blow smoke and after 1500 miles the owner gave up and took the car off the road. It sat in the street for 2 years, until I rescued it.
    Going through the mechanicals to get it roadworthy, I was appalled at the standard of work that had been done. The brakes on the car had been reconditioned twice, so all should have been well.
    I re-rubbered all the wheel cylinders and replaced the master cylinder, but found this in the back brakes
    A staple stuck in the handbrake, which had worn out the front shoe, this was done on both sides.
    The front wheel bearings were done up so tight that when the hub was turned you could feel the balls trying to rotate, they felt square!!. Steering rack boots were shot, tie rod ends needed repair and the king pins needed new thrust washers. The owner had complained about knocks in the front end. The front shockers were so stuffed I couldn't rebuild them, so they went in the bin and I rebuilt some replacements.
    Next is was time to deal with the smokey motor
