piercing punch
Results 1 to 21 of 21
Like Tree4Likes
  • 1 Post By GreenBlood
  • 1 Post By 59 Floride
  • 2 Post By 59 Floride
Thread: piercing punch
    It's how I roll...Brisbane
    33,698
    Default piercing punch
    Does anyone know where I can get hold of a set of piercing number punches like this, just in case I ever need them..?
    33,698
    bump, anybody..?
    8,244
    Quote Originally Posted by 59 Floride View Post
    bump, anybody..?
    Every workshop needs one of these. . .
    https://www.ebay.com/itm/Ideal-Model....c100036.m2109
    Graham,
    I know you like original but you could achieve a result on a flat bed router with a cad/vector file. . .
    08 C5 X7 HDi very Noir
    33,698
    Wow, never seen one of those before. Don't know if I really want one bad enough to part with $3K tho.
    I wonder if I could do the piercing via the acid etch process, I reckon I could.., thinking, thinking..
    8,244
    Trick would be to stop the process before the acid leached under the resist - of course you could do it, you're the Master!!!
    FIVEDOOR likes this.
    33,698
    Thanks for the vote of confidence GB but I'm still a mere grasshopper compared to you.
    I'll have a tinker and see if I can formulate a process that works.
    1000+ Posts Peter C's Avatar
    SWOTR
    3,791
    Come on, a man of your talents should surely be able to design and construct one of those thingoes. Just think of the challenge!
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,281
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    9,236
    Just use a normal set of punches, bash them hard on a soft surface, then sand away the back. You will have to modify a little bit the numbers with circles/closed contours to leave support tabs for the interior contour though, but not that hard. A dremel with a thin cutting disc should make easy work of it.
    ACHTUNG ALLES LOOKENPEEPERS
    11,186
    Wow indeed! I love what I learn here. Thank you Mr Greenblood.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Citroën CX Pallas 1980 (moved on to new custodian)
    11,186
    bump, anybody..?
    Very distinctive style, those numbers....
    33,698
    Quote Originally Posted by Peter C View Post
    Thanks for the suggestions. I'm hesitant to acquire anymore machinery or major pieces of kit, I'm really just trying to finish what I have on the go ATM. I'll try the acid etch process and see if I can get a result.
    33,698
    Quite, when you study the style of font used by Renault on these diamond badges they do look quite bizarre, I guess it was Regis way of avoiding counterfeiters.
    1000+ Posts fnqvmuch's Avatar
    port douglas
    1,089
    i assume 2 is to 5 as 6 to 9?
    grandC4picasso RHB, [email protected] , EGS6Sp, B58, MY 2012-2013 (?)
    9,236
    Etching Aluminium is a bitch and given the thickness is quite considerable for the process I would say it's risky.
    Now there's not that many numbers and the metal is thin and soft so I would not discount just copying the numbers in the correct order on the workpiece and filing them by hand with a watchmakers' needle file (or a bunch of them). A filing machine would be great here.
    SWOTR
    3,791
    What about a drill, a dremel and a stencil of some description? No sharp corners, though.
    11,186
    Not sure about ACID leaching with aluminium.... Does alkaline leaching work on ally? I reckon the drill/Dremel/stencil is the go, so you can reproduce the unique lettering style.
    33,698
    The plot thicken somewhat, compare these images from different decades and there are subtle differences across the fonts. granted 6 & 9 are the same but 2 & 5 are distinctly different..
    33,698
    Acid etching definitely works on Aluminium but the hydrochloric needs to be kept cool or it will totally devour the workpiece.
    Here's an etching I did some time ago, it only took about 7 goes to get it right.
    11,186
    The good thing for you, if you were thinking of an older lozenge plate, is that the 1934 ones are a standard European number font by the look of them.
    Very impressed with the acid etching example!! How do you get such sharp edges? Not to mention an even depth. I guess the answer is "7 prior attempts..."!
    33,698
    I did write a paper on the process for future reference and I'll email it to you when I find it. Perhaps I'll conduct an AF workshop on the process sometime,
