76í GS Pallas resurrection Project
Like Tree6Likes
  • 5 Post By grayhood
  • 1 Post By sparkey
Thread: 76í GS Pallas resurrection Project
    Jul 2017
    7
    Default 76í GS Pallas resurrection Project
    I thought I better put some progress up if the GS I saved from what I was led to believe was the scrap heap.
    Most of the work this far I must confess has been carried out by dad in Stanthorpe. My job has been to track down the missing pieces.
    1st picture is the car turning up at my place.
    A bit of the history on the car, in its last guise it was known as OGS760 and has enormous amount of history spanning back to the 80s. I believe it to be a 1220 Pallas and mid 2000ís it had a GSA 1300 fitted to it.
    When I received i was told it would run so with a new battery a couple of wires and a couple of cranks it spluttered into life....and about 40 seconds later all corners left into life. Have to take that as s win. Now after removing box after box of interior parts/ trim parts etc etc I found the steering wheel and what vaguely resembled a seat and took it for a quick spin around the cultersac.
    It should be pointed out at this point although it ran and stopped the interior had been completely stripped, doors gutted and key barrel in multiple containers in 30 odd bits, who new there were so many pieces in a barrel. One heck of a jigsaw
    A few months down the track and a impending house move and limited room at the new place, GSy got another reprieve in being relocated to Stanthorpe.
    Sorting out the parts 1.
    2.
    3.
    Cleaning up the steering wheel, seems to be like most GS wheels I have seen
    One very blocked filter found here
    Paint prep begins. The car was pretty straight and it looked like the owner had carried out a fair bit of prep
    Door being prepped
    Starting to take shape
    Looking good with some colour. At this stage itís all painted white though the original thought had been to two tone it at some stage
    All the screws sorted into piles. Somehow I managed to remember where most of these came from due to a previous ill fated resurrection attempt of another GS.
    It should be noted that this all turned up at dads late November. Iím guessing this has kept him well entertained these last few months
    Rear screen fitted
    Test fitting on near rear lights ( they were still in the box)
    Red oxide 1.
    Red oxide 2
    Looking pretty finished paint wise. Next step windows ...how hard can that be
    Running repairs of window mechanism
    Left door components being fitted up. I do remember at this point in time mentioning about a colour change and that handles etc would need to come off. I do remember that the reply was somewhat along the lines of you can do that yourself and that i would require small long monkey arms
    Dash fitup underway
    The boot looking quite finished
    Some aftermarket trimming
    At this point in time ...excluding labour of course...the car really hadnít cost much at all. The hope had been to get it ready for rego and try and keep it under $1k. I had thought I had pick up a great set of versastein tyres ( Iím sure I spent that wrong) but they cracked in fitting them to the rims
    The dash looking like a dash once again
    What goes here
    This does
    Notice the small bolt pile now
    Wheels being prepped, notice anything different
    Some interior red bling
    A nice 3/4 body shot. At this point in time the body is mostly finished. Still need to chase down a stone tray. Thanks to Stef I have a trailer full on bits including seats that should make there way south to continue the build this week. Thought it wonít make the Cit-in in WA I am hoping it will make the All French Day in July in Brisbane...as long as I can keep the parts up to dad Iím sure we are in with a chance
    Oct 2018
    au
    39
    Now that's a mission
    Fellow Frogger! AxGT's Avatar
    Apr 2001
    294
    So, on tyres - Tyroola have the Nakang CX668 for a pretty good price - that size corresponds pretty close to the 145SR15 size they had stock.
    https://www.tyroola.com.au/nankang-c...823d92761.html
    Jun 2016
    Newcastle NSW Australia
    119
    Iím impressed. Thatís a magnificent effort and a great outcome so far.
    Fellow Frogger! sparkey's Avatar
    Apr 2005
    371
    Great job there grayhood (& your dad)
    You may miss out on Citin but there is always the 50th GS anniversary in 2020
    Last discussion I had with organiser in '17 was commencing roughly Mildura up to Broken Hill & onto Qld border
    graham66 likes this.
    '73 & '74 GS Break
    '00 Xantia Break
    '78 504 GL - gone to good home
    '69 ID19B - if wasn't for mortgage would still have, '74 DS23 Pallas
    '74 Renault TS , '69 Renault TS - last seen forlorn at Taminda wreckers
    Jul 2017
    7
    So looking like a nearly finished project now
    Next few jobs
    - get indicators working
    - fit horn
    - replace lower front control arm silent blocks with bushes and whatever else we find here
    - tyres
    -whatever else crops up then some 6 digit plates hopefully
    IMG_1556447198.029396.jpgIMG_1556447213.219878.jpgIMG_1556447229.277462.jpgIMG_1556447239.465753.jpg
