1977 GS 1220 Pallas
Results 1 to 16 of 16
Like Tree10Likes
  • 2 Post By AxGT
  • 2 Post By sparkey
  • 1 Post By AxGT
  • 2 Post By AxGT
  • 2 Post By AxGT
  • 1 Post By AxGT
Thread: 1977 GS 1220 Pallas
    Fellow Frogger! AxGT's Avatar
    Apr 2001
    289
    Default 1977 GS 1220 Pallas
    For last year or so, I've really been wanting to do up and enjoy an older car. For those who know me, it was pretty obvious that it was going to be a Citroen of some sort, the only real question was which one?
    After a brief dalliance with a Renault 10S, my Dad (KenW) has always had Citroens, and his first Citroens were his GSes.
    I don't have any photos of his first GS, (it went before I was born), but the two I remember was his 1977 Green GS 1220 Pallas, and his Brown GS 1220 Club
    This was his Green Pallas on the Indian Pacific, when they were moving back to Brisbane from Perth - around 1981
    This is his Brown Club underneath the family home soon after we'd moved in and had the place lifted - this would be 88-89.
    After a bunch of thinking, Dad let me know that BruceH had a menagerie of GSes at his place, so we had a chat, and I went to look at this.
    1977 GS 1220 Pallas-greenpallas-back.jpg1977 GS 1220 Pallas-greenpallas-front.jpg
    Looking at the chassis numbers, it was the next car off the production line after Dad's, so I guess that means it was meant to be.
    A deal was done (for the car, and a half cut with an engine that turns over), and a date was organised to get the car and the half cut to KenW's place as I'm still in the process of getting a double garage organised at mine.
    Apr 2001
    289
    So, a few weekends after, I buttered up a mate with a ute, hired a trailer, and went and picked the car and a half up.
    Managing to mostly dodge the rain, we got the car delivered, then the half cut
    Here it is, sitting in its temporary accomodation
    Now, the parts ordering begins.
    Apr 2001
    289
    I've had a bunch of parts arrive lately, so I've been itching to do some work on the car.
    Previously, we'd determined that the motor in the Pallas was seized, but we'd started the motor in the wreck (with the distributor from the Pallas, and a jury rigged fuel system).
    I booked today off on leave, and tee'd up Dad to spend a day on the car. My aim was to pull the busted motor out of the car, pull the running motor out of the wreck,
    and then get the running motor into the car.
    Started off by taking the front end off the car - it all comes off with a collection of 11mm bolts and nuts. Milwaukee M12 cordless wrench came in super handy for this.
    The picture shows the front upper frame, headlights, and the two side bumpers. The bottom section comes off with a few 13 mm bolts, and then you've got great access to the engine.
    We got the gearbox supported, brought in the crane, fought with the gearbox nuts (universal joint needed to access the bottom two), and voila
    Ran the engine down to the shed in the trailer, retrieved the HP hydraulic line from the pump, and the fuel pump, and put it in the corner; we'll pull the ancillaries off it at some stage and see what else is salvageable.
    After an early lunch, we attacked the motor in the wreck.
    This was more of a pain to remove than the one in the car, as we hadn't got the front cut high enough, and it was fairly unstable.
    It also had its exhaust manifolds and front pipes - one of the joints was easy enough to remove, it had had LHM (hydraulic oil) sitting on it.
    The other needed an angle grinder.
    Once past that, with a bunch of swearing, we got the gearbox nuts and engine mount bolts out, and swung it out.
    Before it could go into the other car, we needed to get the front exhaust sections connected. There is a Y piece which sits under the gearbox, and access was pretty awful.
    Still, much easier to do with the engine out. I also changed the throwout bearing to the one from the wreck, it was much better.
    I've got a clutch kit for it, but I'll save that for another engine in/out.
    Then, it was a matter of trying to get the engine attitude matched to the gearbox,
    Having the exhaust manifolds and pipes in added another dimension of fun , but finally, got it home.
    Next job is to put new timing belts and tensioners on this engine, get the fuel pump on it, hook up the hydraulics, and see if we can get it to start and pump up!
    forumnoreason and Bruce H like this.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,848
    Then the fun really begins - I am a bit worried about my grass my the backyard. Hopefully this engine only runs on two cylinders.
    Ken W
    Jul 2017
    4
    Looking like good progress. Hereís mine packed on the truck ready to head to dads for a bit of TLC, Ken will know where 1977 GS 1220 Pallas-img_1542873882.821899.jpg
    1000+ Posts Bruce H's Avatar
    Apr 2001
    1,198
    Glad you got further than I did
    My latest project (the big blue one) has left me stranded in Sydney today
    Bruce H
    Now 99 Xantia SX x2; 96 Xantia SX; 76 GS Club Estate x2; 76 GS Club; 74 GS Club; 88 VW T3 Reimo
    Before: AX Gti; BX 19TRi Estate; CX 2200 Super & Pallas; CX2400 Pallas; CX 2400ie Prestige auto; DS3 DStyle; GS Pallas; GSA Club; Xantia Image Estate; Xantia Exclusive; Xsara VTR R4; 1.4 Special Estate; Virage; R16TS
    Contact for the Australian Citroen GS GSA and Birotor Register http://australiancitroengsgsaandbiro...com/index.html
    North Brisbane
    1,848
    So that's where you are Bruce,
    I hope you are stranded in a nice part of Sydney and that it gets sorted easily and quickly.
    Cheers, Ken
    Fellow Frogger! sparkey's Avatar
    Apr 2005
    366
    Looking good AxGT - the rear shot of the GS suggests it already looks great
    Used a trolley jack to remove my GS engine and ended up putting it back in with 2 people carrying it into position and me pseudo guiding it. The engines are really not that heavy. With the flywheel removed I was able to lift mine onto the workbench unaided.
    Look forward to more progress. Had a great day up in Brissie recently with Bruce/Graham & your dad's collection
    Bruce H and graham66 like this.
    '73 & '74 GS Break
    '00 Xantia Break
    '78 504 GL - gone to good home
    '69 ID19B - if wasn't for mortgage would still have, '74 DS23 Pallas
    '74 Renault TS , '69 Renault TS - last seen forlorn at Taminda wreckers
    Apr 2001
    289
    Bit more progress today
    The aim of today was to get the timing belt and tensioners changed on the car.
    First job was to undo the starter dog on the front of the engine, which needs a 42mm socket. They're pretty elusive, so luckily a 1 3/4 imperial socket works out to 44.something mm - which is close enough.
    To do this, you need someone to jam a screwdriver into some of the starter teeth, while someone else uses a breaker bar with a big pipe on it.
    Once that is undone, you can remove the starter dog, the fan, and the alternator drive belt.
    Then, removing the fan shroud gives you this:
    Once we could see all the timing marks, we marked them with chalk (couldn't find the paint pen), and rotated the engine until they were all in the position shown in the manual. At that stage, we removed the tensioners, and pulled the belts off.
    The tensioner bearings were absolutely stuffed. I'm glad we didn't run the engine long when we tested it!. One of them barely rotated. We pressed the tensioners out of the old bearings, and inserted them into the new ones, the popped on the new belts.
    This image shows the starter dog, the two drive sprockets from the crank, and the left hand tensioner.
    Then, we were all done:
    Last step was to put the fan shroud back on, but in the meantime KenW managed to drop a socket down under the inlet manifold , so we'll wait till we fish that out with a magnet before putting the front back on.
    Bruce H likes this.
    10,380
    Lovely. Far too few GS examples left. Hope all goes really well.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Apr 2001
    289
    Got a bit more work done on this.
    KenW spent some time stripping the wreck in the shed, and we've got it down to bits we want to keep
    We'll keep the sub-frame, gearbox, exhaust, and the suspension arms and cylinders. The fluid blocks in the bottom arms are much better than the ones in the car, so
    we'll move the arms across completely.
    The rest of the body got dumped in a trailer, and disposed for free at the transfer station
    Next job was seeing if we could start the engine.
    The car has a mechanical fuel pump driven off the drivers side camshaft, but we were a bit dubious about how well it pumps, so I grabbed a Goss electric pump,
    both to clear out any residual fuel from the tank, and to start it up in the mean time.
    I connected the pump up, and fired it up - it was pumping, but the tank was empty.
    Poured some fuel into the tanks, and heard splashing noises under the car...
    You can see the pipe from the filler into the fuel tank is missing quite a bit of rubber.
    Still, the car was starting today. I rigged up a fuel feed from the Jerry can, and after
    some issues getting 12V on the "Run" position of the ignition switch (worked around with an alligator clip from the positive terminal to the coil) this happened!
    You can see the jury rigged fuel pump on the left hand side, and the slow drip of hydraulic fluid where we forgot to tighten up some of the at the bottom next to the left hand exhaust.
    forumnoreason and GreenBlood like this.
    tweed heads
    1,428
    That sounds a lot like mine did when the ,bottom blew out of the hot box under the inlet manifold ,fixed with a couple of welch plugs in the tubes, coming up from the exhausts ,ok for wormer climes ,maybe not for colder pugs
    Ici.
    2,408
    that sounds pretty damn good, I'd have MORE cardboard below though : )
    out of curiosity how easy would it be to plonk th emotor in minus the exhaust and add the exhaust after?
    Apr 2001
    289
    hindsight is always 20/20 regarding more cardboard
    w.r.t the exhausts, getting to the exhaust clamps at the back near the gearbox would be a real pain with the engine in.
    Bruce undid them with the engine in, maybe he can comment
    Apr 2001
    289
    Slow progress over the last month or so, due to waiting for parts, and trips to the US.
    Anyway,
    Fuel filler pipe and other bits (drive shaft boots, and a few seals) turned up, as did some new fluid blocs for the front suspension arms.
    These go in the lower arms, and provide noise and vibration insulation.
    Also got a parcel from Greece, with a new mechanical fuel pump. (Old one was sus).
    Got the new fuel filler pipe on the car, and poured ~15L of fuel into the tank.
    Went to prime the electric pump, and the electric pump didn't really get quieter. Pulled the fuel line off the carburettor and tried to primed the pump again, and just got a few drips
    of very varnishy old smelling petrol.
    Went back and consulted the manual, then hopped under the car to find this
    The filter itself was ancient, and the pipes were cracked and broken when i went to remove the filter. No wonder it couldn't get any fuel from the tank.
    Hit up Repco, and grabbed a suitable filter, and some new 6mm line.
    Emptied the boot, and got to the tank access panel
    Got a new length of line onto the fuel feed pipe, then hooked up the electric pump to pull some crap out of the tank.
    Pulled out about 5 litres - the first bit was pretty yuck, but after that it cleared up pretty well, so attached the new filter and then plumbed up a new bit of line from the filter
    to the under-car line (nylon).
    New Line & Filter #2.jpg[
    After that, the pump primed easily, and the car started right up!
    While I was doing this, the old man was working on his Citroen Xantia, fixing a rear suspension leak.
    I think I had the easier job...
    GreenBlood and Dave like this.
    Apr 2001
    289
    So, this happened today:
    The clicking you can hear every second or so is the pressure accumulator. Its busted in that video, but we've put a non-blown sphere on it, so at least that is fixed.
    Felt great to see it moving under its own steam. I've really been working to get it to this point, as I wanted it mobile before I moved it down to my place.
    I'm building a double garage with a hoist so I've got somewhere to work on it, but that won't be ready for a few more months.
    Back to the beginning of the day.
    The first bit of work involved pulling off the front covers, as we'd heard a slight scrape, while the engine was running, and we also had leaking hydraulic fluid from the HP pump
    After removing the front cover, it was clear that the oil pump was scraping a bit. I'd messed up putting the washers back on the spacers, and had them in the wrong order,
    meaning the oil pump pulley was occasionally touching. Easy to fix. In the following photo, the oil pump is the large toothed wheel at the bottom of the engine
    For HP pump, luckily we just needed to replace a seal. I took the solid line out, put a new seal in, and re-inserted the line. All good. In the photo above, the high pressure pump is the horizontal block at the bottom of the left picture with the metal line coming out of it.
    After that, we put some more fluid in the hydraulic tank, pushed some wooden blocks under the wheels, started it, and set the suspension to high. The car lifted itself off the stands and blocks we had it sitting on, so we pulled them out of the way, and drove it off. Easy!
    After it warmed up, I dropped the oil and changed the oil and filter. Ended up changing the passenger side intake cam cover too, as it contains the oil filler; the one on the car was full of rust, and it had dumped a bunch of crud into the top of the cylinder head. I cleaned it out as best I could, but it really confirms that this engine is coming out and apart sometime soon.
    All in all, a great day. Photo below is the GS, and my other flat 4.
    Few more parts to order after today, but the car is mostly working
    frog likes this.
