403 key switch
  • 1 Post By Peter Chisholm
Thread: 403 key switch
    Feb 2012
    MUDGEE/NSW
    118
    Default 403 key switch
    I have started resto of my 1961 403 and am having difficulty removing the starting key barrel. I have removed the 6mm stud and pushed into the hole near it which I I assumed Would release said barrel. Having to remove the barrel because the backing plate holding the wires is loose.Any advice appreciated.
    Sent from my SM-T550 using aussiefrogs mobile app
    SWOTR
    3,435
    I think you have to have the insert the key into the lock and have it in a certain position before the barrel will come out.
    Dano likes this.
    Feb 2012
    Malaysia
    164
    yes Pete is right, there are two mechanism needs to be depressed before extraction.
    1) steering lock
    2) the bottom mechanism ( don;t know the name)
    If my memory is correct, the key is turn 40 degrees before this can happen. Hope you understand french.....
    403 key switch-20180419_224623.jpg 403 key switch-20180419_225024.jpg 403 key switch-20180419_225050.jpg
    Simon's Avatar
    6,117
    The key needs to be in the Garage position, before the sprung plunger can be pushed in allowing the lock to be removed.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
