Marks Mi16 Rebuild
Page 1 of 5 12345 Last
Results 1 to 25 of 105
Like Tree22Likes
Thread: Marks Mi16 Rebuild
    1,360
    Default Marks Mi16 Rebuild
    This has been on the cards for a long time now. Many items have been purchased and put aside for the big day. So, as it happens, before Christmas I had some fun on the freeway late one night and since then the car never really ran the same.
    So from my spare engine (xu9j4) I have sent the head away which I am now told is ready to collect. I have taken 0.5mm off combining this with a 0.7mm cometic gasket should get me a good compression ratio based on other posts I have read. A PeterT cam is also under way.
    I won't post long winded texts with this job so keep an eye out for photos.
    First I had to make up some brackets for the radiator to incorporate the oil cooler so I went one further to drop the radiator 60mm and add some Davies Craig cooling fans. This was a mock up before I disconnect everything.
    lozenge and bowie like this.
    1,360
    Quote Originally Posted by PugMonkey View Post
    Oh yeah, remember these? Not quite ready for them yet....
    frog likes this.
    1,360
    My job for tonight is to tidy up the loom (unwrap and wrap) then split it into three parts.
    1. Gauges to dashboard (already done when I put the twin cam in...)
    2. ECU
    3. Main harness for the car body.
    I have a Haltech ECU to install but I want to do this after the engine is running so it seems easier to slit the loom now (and when the engine is out and disconnected) rather than later.
    1,360
    So the engine that's in the car is swinging on two mounts thus ready to come out (tomorrow job) $800 for the head so I'm wondering if now I should spend some on the bottom end to tidy it up - but that wasn't the plan.
    I also picked up the head today. I have triple cut seats, resurfaced .020" (bloody imperial measures....) some water jackets repaired and some plunge cuts.... All sounds good with all valve stem oil seals replaced.
    I'll wait till the cam comes back before all of the lifters go back in. I'm still waiting on oil spray bay o'rings.
    When I get both blocks side by side I'll do some measurements and determine which one to use.
    CEyssens likes this.
    1,360
    Must have picked the hottest day so far to get it out although it only took an hour.
    FIVEDOOR, CEyssens and PeterT like this.
    1,360
    I'm using ct14 as a Degreaser but it still struggles again the caked on grease. What are other people using? I will be cleaning / rebuilding the cv joints and will most likely use petrol or kerosene for that but is there anything between the two?
    Also now the engine is out I finally got to check the timing to see if the belt had slipped and it was spot on. The three guide pins lined up beautifully.
    7,414
    That stuff is only 8g/L. I use Kenco, which is 36g/L (from memory). Kenco use to bite into your hands once, but they've tamed it down a bit. For CV joints, a pre-wash in kero is probably still easier/faster.
    1,360
    Thanks Peter. I bought it for the high alkaline salts. That's ok ill get some kenco too. I was reading another post where you suggested to put a xu9j4 head onto an xu10j4rs block. Is this something new that's done?
    7,414
    You can do. That's what Parry, Adrian and I all have in our 205's. It just depends on what you have, where you've spent money etc.
    1,360
    All I have spent money on is the head, cam (you have), head gasket and head bolts.
    7,414
    Head gasket and head bolts are different for XU10.
    1,360
    Cleaning and re-grease cv joints. A good dose of kerosene does the job.
    7,414
    You need to completely pull the outer CV apart, in order to clean it properly and inspect for wear.
    Oct 2003
    613
    Ditto. If you don't pull them down and repack them, there won't be any grease on wear surfaces and they will do major/catastrophic damage within 1000km. Youtube should have vids on how to get the birfield joint apart. Once you tap it off the shaft you rock the cage and the bearings will come out. Rollers needs to be taken off the tripod joint and needles individually cleaned. If you do it properly you won't have to touch them for over 100K km.
    1,360
    Ok thanks for the info. Now how to remove and replace a new bearing onto the drive shaft. This one has about 1mm play so shouldn't be too hard.
    7,414
    Warm up that retaining ring with an oxy torch. It will then fall off. Then support under the bearing and press it off. You will need a long tube, matching diameter of inner race, to push the new one on.
    1,360
    Haven't got an oxy and LPG probably won't do the job so I might get it done by a cv guy.
    Did the needle roller bearing on both shafts. Easy as....
    FIVEDOOR likes this.
    7,414
    At least I know you can count to 99.
    1,360
    Haha I was going to mention for the OCD community that each arm has 33 needle rollers....
    1,360
    More work last night. Took the head off the engine that I will be rebuilding. Head gasket was as good as gone. Still a nice hone pattern in the cylinder wall so I'll do some measurements tonight to see if I can put some new rings In as well.
    1,360
    Whilst I was attaching the liner holders I found that the head bolts were really hard to turn so I withdrew them and ran an 11mm tap through the threads. Wow the crud that cam out was amazing. Murphy stuck hi head up though.... The last thread had a helicoil in it and whilst tapping the thread, I was actually winding the helicoil down. Does anyone know how I can get it back up?
    Spent the rest of the day cleaning the box and block.
    7,414
    I see you have an 8V sump fitted with a spacer block. If the pickup hasn't been extended, there will be a lot of wasted oil floating around.
    Measure the top of the helicoil and compare to the other threads.
    9,107
    1.9 8 valves have the spacer block.
    7,414
    Not that sump. That's from a DFZ, which has the same overall height as a DKZ/DFW/D6C sump + spacer.
    1,360
    Yes Peter I have your pick up extension. Sump has a trap door (deeper than the 8v) and a windage tray (mounted on your brackets) so I'm sure it's from something else. Engine holds over 7 litres of oil without oil cooler.
