Faster Floride - upgrade project
Results 1 to 25 of 46
Like Tree21Likes
Thread: Faster Floride - upgrade project
    Oct 2014
    Windsor 2756 NSW Australia
    561
    Default Faster Floride - upgrade project
    This project was originally under a thread called “1959 Floride Restoration” started by the cars previous owner. Since it is not a restoration of an original car, I have started this new thread.
    Finally got the paint finished today so the assembly can now begin. I have to resist the temptation to get too carried away on assembly until the paint has a little time to cure.
    Springs and shocks from Mecaparts are at the post office waiting collection. I have gone for 210 mm free length fronts and standard 275 mm rears although I may cut half a coil from the rear to stiffen it up a little and lower it a tad.
    Feb 2012
    Vista SA
    986
    Interesting what you said about the rear springs. My restoration 'BARNIE' is a 1963 R8 fitted with a 16TS engine. When I took the old springs out there was a separate coil (1 turn) sitting under each spring. I reckon it was to lift the back up for rally work.
    I took it out and reassembled the suspension minus the (1 turn) coils.
    Can't wait to get the brakes finished to get it on all fours on the deck to measure the heights front and back. Friend of mine has recently done some spring mods and the R8 now measures 627 - 630mm measuring from the ground to the center of the chrome side strip, measurement taken straight up through the wheel area.
    Phil
    Phil
    Quote Originally Posted by Bustamif View Post
    Oct 2014
    561
    My R8G has a 1605 engine with forged pistons, big cam, twin 45 DCOE Webers etc but it is the R18 type with the crank pulley on the back of the motor. This makes it easier to fit the alternator at the rear instead of being at the firewall/fuel tank end.
    With all the fiberglass panels on the front of the R8G, including the guards, I found that even the meca 200mm front springs were too high for the 240 mm rears. The standard rear spring has a free length of about 300 mm.
    I used some spare race springs I had on the shelf where lower again, about 260 lb/inch made from tapered wire producing a progressive rate - softer in the first 5 mm of travel increasing as the wheel compresses, great in wet weather.
    The 200mm fronts work well on the Alconi which has all the steel panels.
    The Floride project is same basic layout to my R8g with similar engine and front aluminium radiator but no fiberglass.
    It is worth weighing everything as you do the build to ensure the weight distribution is improved. For example although the R16 motor is about 20kg heavier, you move over 20kg to the front with the radiator and associated support panel, glass bottle, jack, plus you get even more weight off with fiberglass rear panel, guards, engine lid and no bumpers. I have not bothered with glass panels on the Floride but the radiator and heater are all in the front and the electric water pump also saves a bit.
    R8philSA and geckoeng like this.
    Oct 2014
    561
    More parts fitted up today including Master cylinder and pedals. The brake switch has to be relocated when using the A110 tandem cylinder. The brake pedal is too close to the hydraulic switch so the outlet is sealed. I will fit a mechanical switch activated by the pedal movement same as the Alconi and R8G.
    Radiator in and fans being mounted. Heaps more space available than the R8G
    More space in the rear too and the oil cooler will have good airflow. The oil filter mount is an old remote mount I had from a Valiant slant 6. I used a lot of them back in the day before that style of aftermarket alloy mount became so easily available.
    The new gear shift base is one I saw on Chris Lees project here. Not sure if the grub screws to hold the spacers on the shaft will be up to the task but time will tell.
    I have plenty to do while I keep trying to find a 16TS crownwheel and pinion for the big gearbox.
    Cheers all.
    59 Floride, geckoeng and bowie like this.
    Oct 2014
    561
    Back onto the Floravelle assembly now that the Phillip Island event is over. Thanks to Bazzamac for bringing some new discs to Phillip Island I have all the bits to put the front suspension in this weekend. The brake lines and water pipes are being run then the rack goes back in and the rest of the suspension. New springs and shocks all ready to go, bushes have all been replaced and adjustable tie rods on the rack.
    bowie likes this.
    Dec 2004
    747
    can someone tell me is there any difference in a 16ts and16 tl gearboxes? as I have 3 projects that require big box's and I have a 16tl sitting here.
    LIFES TOO SHORT TO DRIVE BORING CARS!
    Oct 2014
    561
    The tl is usually an automatic so it won't work as the basis for a big box.
    Oct 2012
    600
    I have noticed that the gear lever bearing block I've used that you have also used is stopping my car going into reverse, something to check. The fix will be to enlarge the hole in the floor.
    Yours might be ok as I've also put a jog in my gear linkage to shorten the throw even further.
    Sent from my Nexus 6P using aussiefrogs mobile app
    Oct 2014
    561
    Thanks c.lees, because the floor was replaced I had the option of moving the mounting holes a little further to the side by about 5mm when I noticed a lack of range towards the reverse plane. I also enlarged the large hole for the gearstick.
    I expect there will be a bit of adjusting of the ratio to get the right amount of movement on the end of the lever. The quality of that unit is OK, especially considering the price, however I put a shim (thin washer) on the top of the bearing to take some of the play out of the housing. Adjusting the ratio will be tricky with the grub screws in the brass spacers and I can see the spacers moving with a bit of hard use. I probably wont put an undertray on for a while as the bugs are ironed out.
    A small setback yesterday when I was about to put the rack in I saw that the rack mount was facing the wrong direction, that explains why one rack in the pile of bits with the car had been cut with a hacksaw, apparently to fit it to the rack mount. I removed the mount to turn it around and found an odd selection of washers and spacers had been used to somehow try to get the rack into the correct position! I should have taken the rack mount out before I painted the car, it was the only removable part still on the car and I assumed it was OK.
    A shame to see that someone in the cars past life took to the rack with a hacksaw to make it fit!
    Faster Floride - upgrade project-dsc07044.jpg Faster Floride - upgrade project-dsc07045.jpg Faster Floride - upgrade project-dsc07047.jpg Faster Floride - upgrade project-dsc07048.jpg
    The holes they drilled in the rear crossmember to mount the suspension arms were 40 mm (1.5 inch) from the correct position !
    Scary to think things like that can be on the road.
    Dec 2004
    747
    The 16TL I have here is a manual 1.4ltr non cross flow.
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,598
    Peter J,
    · Promote
    Yahoo! Groups Tips
    Did you know...
    Want to share photos of your group with the world? Add a group photo to Flickr.
    Best of Y! Groups
    Records Records Help
    1 - 20 of 82 First | < Previous | Next > | Last
    Tables > Renault Gearboxes
    Actions
    336-?? 11/38 3.46:1 17/38 2.24:1 23/34 1.48:1 28/29 1.04:1 n/a 9/34 3.78:1 R16 TL, R16TS - Listed in Renault Data EditDelete
    336-?? 11/38 3.46:1 17/38 2.24:1 23/34 1.48:1 28/29 1.04:1 n/a 8/34 4.25:1 R16TL, R16TS - Listed in Renault Data EditDelete
    336-02, 03, 06, 07, 10 13/47 3.61 n/a 2.25:1 23/34 1:48:1 31/32 1.03:1 n/a 9/34 3.78:1 6/12 2.0:1 R16, R16TL - Crown wheel needs moving to other side to use in europa EditDelete
    336-08 13/47 3.61:1 n/a 2.25:1 23/34 1.48:1 31/32 1.03:1 n/a 9/32 3.56:1 6/12 2.0:1 Early S1 – Reverse: Left and Down EditDelete
    336-11, 13, 20, 23, 30, 37, 40, 42 13/47 3.61:1 n/a 2.25:1 23/34 1.48:1 31/32 1.03:1 n/a 9/34 3.78:1 6/12 2.0:1 R16, R16TL, R16TA, R16TS - Crown wheel needs moving to other side to use in europa EditDelete
    336-14, 15, 24, 25, 44, 45 13/47 3.61:1 n/a 2.25:1 23/34 1.48:1 31/32 1.03:1 n/a 8/34 4.25:1 6/14 2.33:1 R16, R16TL, R16TS - Crown wheel needs moving to other side to use in europa EditDelete
    336-26 13/47 3.61:1 n/a 2.25:1 23/34 1.48:1 31/32 1.03:1 n/a 9/32 3.56:1 6/12 2.0:1 Late S1/Early S2 – Reverse: Right and Down EditDelete
    336-46 13/47 3.61:1 n/a 2.25:1 23/24 1.48:1 31/32 1.03:1 n/a 9/32 3.56:1 6/12 2.0:1 Mid S2 – Reverse: Right and Down EditDelete
    336-56 13/47 3.61:1 n/a 2.25:1 23/24 1.48:1 31/32 1.03:1 n/a 9/32 3.56:1 6/12 2.0:1 Late S2 - Very Early TC EditDelete
    352-11, 13 13/47 3.61:1 19/43 2.26:1 25/37 1.48:1 31/32 1.03:1 n/a 9/32 3.56:1 6/13 2.17:1 TC, Special, R15TS, R17TL - Shift Rear Entry
    From the Lotus Europa people. Not sure how accurate.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Perth, WA
    1,598
    Peter J,
    I am lead to believe that the 8/34 diff is the R8/R10 type and is not suited to the 16TS type motor for the same reasons as the 330 is not suited, too light. Early type box.
    Ray
    Ray geckoeng
    Oct 2014
    561
    Peter J, my response was April 1st inspired.
    And Ray, that CWP you sent for my big box unfortunately had a bit too much wear on the shaft to support 4th gear. Send a pm and I'll give you the specs.
    Cheers.
    My Supermodel 63-1092's Avatar
    somewhere! Pilbara, Bowen Basin, Melbourne?
    10,661
    Now I understand the colour scheme, happy easter this coming weekend.
    John
    Александър Кристоф Шанел
    Fellow Frogger! nauli's Avatar
    Oct 2017
    Perth, WA
    287
    Bustamif, what is the colour you've painted the car?
    1969 Alpine A110
    Oct 2014
    561
    The blue is a custom mix prepared for my race team back in the day by Ron Goodman now of Exclusive Body Werks. I don’t have the recipe and doubt he has it on his current system as it was prepared in the early 90’s in consultation with my sponsor BASF.
    I just matched the colour from an old tin I had in the shed, it has a little purple in it compared to a Gordini or A110 blue.
    bowie likes this.
    Oct 2017
    Perth, WA
    287
    It looks superb and really suits the Floride....would probably suit an A110 too!
    Brianbcs likes this.
    1969 Alpine A110
    Oct 2014
    561
    Busy during the Easter break. Front suspension and rebuilt front calipers in, new discs from Bazzamac on, pedals have new bushes, new accelerator cable run to the back. New slightly stiffer and lower springs from Mecaparts and new shocks. Rebuilt rack in with adjustable tie rods and all new bushes in the front and rear suspension.
    Faster Floride - upgrade project-trif2af.jpg Faster Floride - upgrade project-tri1491.jpg
    The tandem A110 master cylinder is a snug fit. Road legal (NSW) stainless steel braided line to front and rear brakes.
    The accelerator cable is morse cable, not bowden. Less drag, can push and pull and they don't break - the advantage of using some current technology.
    The heater is in the front and takes hot water from the front radiator same as in my R8G. The ducting runs the hot air a short distance to the standard air outlet for the footwell and windscreen. The duct from the heater can't be seen, it connects under the firewall, the silver duct in the pic connects to the windscreen demister outlet. The electric water pump makes sure water temp stays at 80 degrees even in very low temps.
    Faster Floride - upgrade project-trib99b.jpg Faster Floride - upgrade project-tri34bf.jpg
    The wiring in the front is for the front radiator fans which are controlled by a temp probe in the radiator, the electric water pump controller does not do the front fans although there is a trigger from it if necessary to switch on the front fans.
    Next jobs involve adding some trim and wiring while it is at a nice height on the rotisserie before getting the motor and transaxle in after I return the borrowed rotisserie.
    bowie, Brianbcs and JohnW like this.
    Oct 2017
    Perth, WA
    287
    Nice work!
    1969 Alpine A110
    4,352
    Agreed, looking very good. I saw your gearbox on Saturday undergoing a rebuild.
    Look forward to seeing the car on the road.
    KB
    KB
    Oct 2014
    561
    Almost finished wiring on the new dashboard, switches and gauges while I have been waiting on minor machining on the uni joint yokes for the big gearbox. The speedo is GPS so I don't have to worry about cable drives and inaccurate speed readings every time I fit a different tyre diameter. The black box on the LH pic is the control unit for the electric water pump which will be under the dash.
    Faster Floride - upgrade project-tri5ecf.jpg Faster Floride - upgrade project-tri3d5.jpg
    Now to sort all the broken and different coloured wire in the steering column. Anyone have a wiring diagram for the indicators etc ?
    And a picture of the big gearbox. Mounts all sorted to allow for the spacer on one side.
    I found a 3.5 ratio crown wheel and pinion during a cleanup of Lotus parts so I am going to build another box for the R8G which has the usual 3.7 diff. The 3.5 will give me better cruising speed with the 13 inch wheels on the R8, it will also give me a better ratio for track days !
    The Floride will be running 14 inch and maybe some 15 inch diameter alloy mags I found in the tyre rack so it should be OK with the 3.7 diff.
    CW&P on the left is the 3.5, the 3.7 on the right.
    It's how I roll...Brisbane
    32,793
    Wiring diagram as requested, unfortunately only in French.
    Attached Thumbnails Attached Thumbnails Faster Floride - upgrade project-scan_0008.jpg   Faster Floride - upgrade project-scan_0009.jpg   Faster Floride - upgrade project-scan_0010.jpg
    Dano likes this.
    Oct 2014
    561
    Wow that was fast, thanks heaps. Guess I have no excuse now so back to the shed for me.
    10,677
    Quote Originally Posted by 59 Floride View Post
    No inbuilt translation errors then....
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Citroën CX Pallas 1980
    Oct 2014
    561
    The big box with the 16TS internals is now fitted and the rear suspension in. Finally on the ground so a trial fit using a spare mock up engine confirms how much additional space in the engine bay compared to an R8.
    Faster Floride - upgrade project-triaf0d.jpg Faster Floride - upgrade project-tri517b.jpg Faster Floride - upgrade project-tri4d69.jpg
    There is 30 mm more space from the face of the Weber to the inner guard when compared to an 8.
    Plenty of room to duct cool air from the side air inlet around the fuel tank straight to the carbs.
    The crank, rods, new pistons, flywheel and clutch are all balanced ready to pick up tomorrow. The crank was 10 thou under on big ends and mains but I managed to get some new bearings from the states. The head is getting a skim and new guides. I have done a little porting and matching of the inlet manifolds, the exhaust will be next.
    bowie, nauli, geckoeng and 1 others like this.
