203 Ute restoration
Results 1 to 22 of 22
Like Tree12Likes
  • 2 Post By tok403
  • 2 Post By tok403
  • 3 Post By tok403
  • 1 Post By Flash Car 76
  • 1 Post By treasure1
  • 1 Post By tok403
  • 1 Post By Russell Hall
Thread: 203 Ute restoration
    Member tok403's Avatar
    Oct 2017
    Sapphire Beach
    95
    Default 203 Ute restoration
    First off I know this is a ďbigĒ project but Iím up for it. The rust in the old girl is not to bad a bit at front of chassis near jacking points, floor and a bit near cab and tray. The first task is strip it down to bare body, so I pulled the motor out. The motor is genuine 203 it is seized solid and ill replace it with 403 when I get to that stage. If youíve got a 403 motor sitting under your bench let us know but Iím in no hurry thatís a long way off.
    Good to get a start.
    203 Ute restoration-7ee0b6f7-687d-45f0-9821-5ef9190adcc2.jpg203 Ute restoration-eba44054-d0b4-4ead-95e1-d861b6f79886.jpg203 Ute restoration-13d52e2f-37c0-4d3c-ac9b-9c70519046ea.jpg
    calgooley and Demannu like this.
    NOW: 1960 403 Sedan 1953 203 Ute 1957 203 wagon. Ducati Monster s2r 1000
    Previous Peugeot 1 203 6+ 403 7+ 404. 4 504 4 505. 1 205
    Renault. 3. 12ís. 2. 16ís 1. 25wagon. 1. Floride
    Citroen 1gs
    Jul 2014
    Gladstone Qld
    49
    Quote Originally Posted by tok403 View Post
    First off I know this is a “big” project but I’m up for it. The rust in the old girl is not to bad a bit at front of chassis near jacking points, floor and a bit near cab and tray. The first task is strip it down to bare body, so I pulled the motor out. The motor is genuine 203 it is seized solid and ill replace it with 403 when I get to that stage. If you’ve got a 403 motor sitting under your bench let us know but I’m in no hurry that’s a long way off.
ID:	101695Click image for larger version.
ID:	101696Click image for larger version.
    i have a 403 engine under my bench you are welcome to it but maybe getting it to you might be a problem. Where is Sapphire Beach?
    graham
    Jul 2014
    Gladstone Qld
    49
    Quote Originally Posted by Dangel 1 View Post
    graham
    Near Coffs Harbour?
    i am in Gladstone but I go to Brisbane all the time. I could take it down to Coffs Harbour for you in the New Year. Good excuse to see that part of the country.
    Graham
    Oct 2017
    Sapphire Beach
    95
    Default Thanks
    That be great thanks Graham Iíll pm you.
    Citroen 1gs
    Oct 2017
    Sapphire Beach
    95
    Another productive afternoon, removed diff and gearbox, just got front end and all the little ancillary bits and she’ll be bare body ready for rust work.look at 60 odd year of chunk around end of gearbox.
    203 Ute restoration-2018fc40-29eb-49f7-8149-b766a77f625e.jpg203 Ute restoration-01cf9cc2-4913-4099-8975-683ad5d8aa8b.jpg203 Ute restoration-c30f9eaf-1b0e-47c1-8526-e47acc69b1b7.jpg203 Ute restoration-993fb15d-62ac-47cc-abb2-5757e38f30f7.jpg203 Ute restoration-726874f5-b96e-40f2-8bf5-16b22a1674a3.jpg203 Ute restoration-56e84a32-09bb-4055-ab08-5d853752e4e0.jpg
    59 Floride and calgooley like this.
    Citroen 1gs
    Oct 2003
    canberra
    831
    at least the owner had been greasing the joint!! if only a little too much ,
    utes are surprisingly light when stripped of the heavy bits ,
    have lots a fun
    Oct 2017
    mallee
    22
    Russian winter treads on the back? Take good note of the condition of the uni joint. Nothing worse than to put everything back and have it go. Different types between early and late models. You can get new pillow blocks for the head of the torque tube and back gearbox mount. Have a look on the net, lots of French ute restorations under way.
    Oct 2017
    Sapphire Beach
    95
    Hi I’ve created a webpage for my ute https://peugeot203ute.simdif.com/index.html like the ute its a work in progress. I’d like to know what you think, does it load ok your side etc.
    Citroen 1gs
    Dec 2010
    Bungendore NSW
    490
    Mate that is brilliant. Looking forward to the ongoing story. Love the dead rats you are using as props to the story.
    tok403 likes this.
    Nov 2017
    Benalla victoria
    7
    Great story and web page
    Looking forward to details on how the Holden floors pan out..pardon the pun
    tok403 likes this.
    Oct 2017
    Sapphire Beach
    95
    Hello guys a lot has been going on in my resto project. I have cut out and repaired/replaced all the rust. I’m now going to run 403 mechanicals from engine through to diff, thanks to all the aussiefrogers who helped me Source all the parts. Visit my webpage for all the pictures https://peugeot203ute.simdif.com/sta...he-inside.html. I really looking forward to fitting mechanicals and getting her back on all four.
    robo likes this.
    Citroen 1gs
    Oct 2017
    Sapphire Beach
    95
    Lots been happening. Diff rebuilt and placed in car with rebushed rear end, so good to finally put things back in. Originally tried complete 403 rear end, it bolted up but springs didn’t sit right. I ended up with 403 axle housings and axles 403 diff and 203 springs. I then put in 403 gearbox made a couple of extension bracket for gearbox mounts. I have fitted 203 inner steering column to 403outer column so gear box links are straightforward 403. The front crossmember is in place just waiting for rack boots tie rod end kits and rack bushes and rest of front end will go in place. Have started on the interior now and door trims and all other trims around “a”pillar are coming together well. Seats mmmmm seeing how my bro did his heck I gotta give it a go-watch this space. Speaking of my dear bro I just might get this girl on the road before the 404 lol. That being said I’m no where near a thorough or pedantic as Dan but his will be a class well and truely above all others it’s inspirational to see his progress. I’m happy to make non standard changes hence 403 running gear.
    Citroen 1gs
    Oct 2017
    Sapphire Beach
    95
    Well a sh!t load has been happening since my last post as well as scoring a lovely wagon. All the rear end and Diff and gearbox are in place still mucking around with clutch but thanks to suggestions from here I’ve come up with a workable solution I think. I’ve never sewn anything in my life, but my brothers amazing work spurred me on, now my seats aren’t up to his amazing standard but I’m happy with them. I’ve also done the door trims and hood lining carpets etc rest of interior will be done when bailey channel arrives. I’ve started to paint it and its coming along well but still finding little dents. I’ve started on the rewrite and it’s coming along well. Now that I can sew next is the canopy. Anyone know of any vans about?
    203 Ute restoration-9d8c956f-297f-47cd-983c-728ae3ddd527.jpg203 Ute restoration-08c2c648-565e-43ce-9f02-6010e124923c.jpg203 Ute restoration-a625f74b-cd7f-48f5-b5c1-83a371e873e8.jpg203 Ute restoration-c05fe503-0a11-4515-92cc-fb55cf7ca242.jpg203 Ute restoration-290549f7-2d4b-4e99-a1b8-0947d59466a0.jpeghttps://youtu.be/eVaDTVpRHz4
    Citroen 1gs
    Fellow Frogger! fnqvmuch's Avatar
    port douglas
    911
    might be easier to just make yourself a van - don't even think about it!
    https://www.reezocar.com/en/voiture-...FRA182280.html
    grandC4picasso RHB, [email protected] , EGS6Sp, B58, MY 2012-2013 (?)
    port douglas
    911
    heartfelt congratulations - photos please
    10,705
    There used to be one in Mount Gambier. Well, a "Commerciale". Do you want me to chase it down if I can find the owner's contact details?
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    port douglas
    911
    pedantically, its a "Fourgonette" tok wants.
    10,705
    Quote Originally Posted by fnqvmuch View Post
    Fair enough.
    Renault 4CV 1951
    Renault R8 1965
    port douglas
    911
    you could have pulled me up on the apostrophe
    10,705
    I should have!!
    Renault 4CV 1951
    Renault R8 1965
    anywhere
    1,689
    The van owner at Mt Gambier had a good collection of 203 wrecks as well. Haven't seen him around in it for a while. I'll see if I can find a photo of it in my files which are not orderly.
    tok403 likes this.
    anywhere
    1,689
    Taken twenty years ago in Casterton. All the 203's are alive and well but sadly not all their owners. Van owner doesn't have a current phone listing in the district.
    Attached Thumbnails Attached Thumbnails 203 Ute restoration-casterton%25201998.jpg
    tok403 likes this.
