R1190 Project
Page 1 of 3 123 Last
Results 1 to 25 of 72
Like Tree40Likes
Thread: R1190 Project
    Nov 2017
    Toowoomba, QLD
    67
    Default R1190 Project
    G'Day all,
    This is my R1190 Renault 10 Project I have just acquired. Little bit of work in it but it's all there.
    P.S. It does have the rocker cover but I've taken it off to inspect the head
    If you have any Tips on Restoring one of these I'd love to know
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,179
    Ah mate you are going to have fun
    R10's are cool.. R*'s are cool
    LeMansTragic likes this.
    599
    Congratulations - welcome to the fold.
    Good idea to familiarise yourself with websites that can assist with parts.
    One of the key suppliers is Mecaparts from France: Catalogue ALPINE RENAULT
    Ordering in larger quantities as opposed to smaller, will save in postage in the long run.
    There are others, with most o/s.
    4,242
    Don't get it sandblasted or chemically dipped unless you want it back looking like a cheese grater.
    Your best tip would be to consider upgrading to an R12 engine - either 1289 or 1397 (aka 1.4) engine. 1289 is probably the smoothest sweetest choice and the HP difference between it and the 1.4 should not be significant for most road use.
    KB
    Nov 2017
    Toowoomba, QLD
    67
    I was actually looking at sandblasting it back so thanks for that. I believe it has the 1.4 847 engine, at least thats what the previous owner told me.
    4,242
    Can't tell from the pics as we can't expand them. What does the tag on the side of the block say? (near the distributor).
    Also did it have two (688-02 1108cc) or three (R12 engines) nuts holding the rocker cover on?
    The R12 head should also have some (3?) mouldings and threaded holes near #4 plug where the alternator mounts on an R12.
    KB
    Nov 2017
    Toowoomba, QLD
    67
    I'll have to check the plate on the motor but there are 3 studs holding the rocker cover on.
    Oct 2012
    599
    It'll be fun....
    You'll get a good chance to improve your sheet metal work. I had mine blasted, cheese grater indeed. If you can avoid it then if you don't know the rust is there then maybe it isn't.
    An R12 engine is just a start, strengthened gearbox, bigger brakes, 807 or if you are slightly insane like me then a K4M (work in progress)
    Sent from my Nexus 6P using aussiefrogs mobile app
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    19,200
    Quote Originally Posted by LeMansTragic View Post
    In my humble opinion, the best tips can be found here:- R8 upgrade project
    Your mileage may vary.
    LeMansTragic and J-man like this.
    Every day is a good day
    It's how I roll...Brisbane
    32,395
    ...most of that will buff out.
    Simon's Avatar
    6,085
    It really doesn't look like a 1.4 motor. Also work out a budget of what you want to spend, what you can do yourself, and what you want to achieve. A poor(ous) body that requires a lot of rust rectification can be a real money pit. Especially where good condition Renault 10s, whilst not on every corner, will invariably cost a lot less than repairing a rotten body, especially if you are paying someone to do the work.
    Sandblasting can also warp the thin R10 panels.
    Just an addition, I'm not sure how familiar you are with the R10 body, but they literally rust from the inside out - from the roof gutters down, especially in the door pillars (A & C), roof pillars (A & C), chassis rails etc. So a very careful check is required of any small pinpricks of rust as they only get bigger. You want to find them first, not the rego inspector once you have completed everything.
    Yes, I'm painting a bleak picture as a starting point as nothing would be more disappointing than doing a lot of work, only to find the body is no good down the track. Mechanicals are easy to fix, a rotten body not so easy.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Nov 2017
    Toowoomba, QLD
    67
    I was planning on tackling the the body myself, I have family in an engineering firm that can help me with the body. The floor and lower rocker sills are stuffed but The A,B pillars don't look all that bad; no telling what I'll find once I start stripping it back though. I Recall the bloke I bought it from saying something about it being a 'Virage Engine' so a late R12 C1J? Thanks for the advice Simon
    Nov 2017
    Toowoomba, QLD
    67
    Quote Originally Posted by FIVEDOOR View Post
    Cheers, I'll check it out
    Brisbane/Australia
    1,928
    The Virage engine was type 847 and is 1397cc.
    The C1J is also a Sierra 1397cc. This was fitted to various 80's models (R5, R9, R11, R19) but was not sold in Australia.
    "I cannot help but notice that there is no problem between us that cannot be solved by your departure."
    Jun 2011
    Brisbane Qld
    19,200
    On a more serious note, this one shows some of the potential body rust issues:- Christian's R10S
    4,242
    I struggle with this. It really doesn't look like a 1.4 engine as Simon said, and whatever is in there looks like it's been in there for a long long time.
    KB
    Brisbane/Australia
    1,928
    The photographs in post#1 show the motor still has the identification plate so just get the motor type off the plate.
    The head does not look like an R12/Virage so if it is a 1.4 the it's only the bottom end.
    4,242
    The carbie does look a bit odd, but a few more pics of the engine (not in a montage); and the details off the plate would be a start to ID'ing it correctly.
    KB
    Oct 2014
    Windsor 2756 NSW Australia
    505
    Don't stress too much about identification of the engine fellas, he may toss it out and put an 807 or K4M in it. In which case the mystery engine may come up for grabs and you can turn it into garden art.
    4,242
    Not sure I need any more. I have at least three in the garage now, plus one out on loan.
    JohnW likes this.
    KB
    10,270
    I agree. Looks like a 6-port 1100.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    10,270
    G'Day all,
    You'll find a lot of locally-available knowledge and skill in the Renault Car Club of Queensland if you aren't already a member. And our Renault 4CV Register of Australia, covering the rear-engined cars has quite a few members also in RCCQ. PM me if you want contact details.
    Personally, I'm with Simon's comment. I'd do a really thorough look at the body and decide whether it is sensibly restorable first! Might be fine, but......
    Good luck with it.
    Renault 4CV 1951
    Renault R8 1965
    Nov 2017
    Toowoomba, QLD
    67
    Thanks for the Advice everyone. Gonna get a decent look at it this weekend. I'd love to save her; I just hope it's not too bad once I start stripping it. I'll take more photos of the car (in particular the engine) and post them shortly.
    Cheers.
    Nov 2017
    Toowoomba, QLD
    67
    Some quick photo's of the engine. Going to take some panels off and look at body in more detail shortly
    R1190 Project-1512776601015.jpgR1190 Project-1512776609857.jpgR1190 Project-1512776616950.jpgR1190 Project-1512776621983.jpg
    Sent from my GT-I9505 using aussiefrogs mobile app
    My Supermodel 63-1092's Avatar
    somewhere! Pilbara, Bowen Basin, Melbourne?
    10,362
    688 is a 1100, so not the big block R12 1400.
    John
    Александър Кристоф Шанел
