R1190 Project - Page 3
Page 3 of 3 First 123
Results 51 to 72 of 72
Like Tree40Likes
Thread: R1190 Project
  1. #51
    Simon's Avatar
    6,085
    Pull the whole regulator mechanism out, give it a good clean, as well as the bushes where they bear on the window bracket, then lube everything that moves or slides liberally with zinc based PH grease (rather than silicone spray). It'll be good for another 50 years.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
  2. #52
    10,259
    Perhaps try a silicone spray in the channels for the glass and a bit of spray lube in the axle of the winder first? You might strike lucky! The external rubber seal can generate a lot of friction too, sometimes.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
  3. #53
    Simon's Avatar
    6,085
    Usually the bailey channel causes no problems, unless the glass is skewed from it being worn. If it is tight, I'd be using talcum powder rather than silicone spray. Similar with the outer window scraper, if it exists on the car, it is very likely very hard and brittle rather than pressing on the glass.
    It is usual for the grease to be past its use-by date now, and the winder, its tiny gear, and the sector arm is dry and slides on the glass get sticky and tight. A quick spray is like a sugar hit. Whilst the door trim is off (given the plastic clips, you don't want to remove it a lot :-)), it is opportune to give it a good clean and proper lube. Also it gives an opportunity to check the door cavities out and a preventative spray of fishoil or your fave rust preventative.
    LeMansTragic likes this.
    1963 Renault R4 Van
    1964 Renault R4
  4. #54
    10,259
    Simon's right of course.....
    Renault 4CV 1951
    Renault R8 1965
  5. #55
    Nov 2017
    Toowoomba, QLD
    67
    Gday all, sorry for the silence but I've been on annual leave 👍
    While away I've flushed the brakes and filled the system with DOT4. No leaks (yet) and treated the 10 with an oil change and a new Purflux oil filter (shout out to French car care in Brisbane for supplying the filter). To my next task; Does anyone know how to restore rusty old belt buckles? I'll upload a photo shortly
    Sent from my Pixel 2 using aussiefrogs mobile app
  6. #56
    Simon's Avatar
    6,085
    Quote Originally Posted by LeMansTragic View Post
    It sounds like it might be time to replace them with new. Who knows what the webbing is like, if the buckles are rusted. See the link below, they even have a listing for a Renault 10.
    APV Safety Products - manufacturers of after market seat belts
    1963 Renault R4 Van
    1964 Renault R4
  7. #57
    Nov 2017
    Toowoomba, QLD
    67
    Thanks Simon, they look good but I would love to use the originals if possible.
    I have two of these with this one in the worst condition
  8. #58
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,169
    I have to agree with Simon. Originality is all good, but seat-belts are a disposable item In that they wear out, and that's ok. Repco / Supercheap often stock a lap-sash style belt. I replaced some in my 504 once.
    Either way. If they are like the 12, various grades of sandpaper and silvo polish at the end to make it sparkly.
  9. #59
    Nov 2017
    Toowoomba, QLD
    67
    After a while off the spanners I'm back on the 10 thanks to the good people at Mecaparts. Just fitted sway bar bushes and started on the belt mouldings and the rotton Bailey channels on the rear doors. R1190 Project-1537000003794.jpgR1190 Project-1537000031532.jpgR1190 Project-1537000043223.jpgR1190 Project-1537000077536.jpg
  10. #60
    Nov 2017
    Toowoomba, QLD
    67
    More photos for reference R1190 Project-1537000298944.jpgR1190 Project-1537000310278.jpg
  11. #61
    Nov 2017
    Toowoomba, QLD
    67
    Hey all,
    How do you adjust the handbrake on an R10? also does anyone know where you find new door card clips?
  12. #62
    Ipswich, Queensland.
    1,829
    There is a large lock nut (brass)on the inside of the rear calipers that has a long bolt with a 14mm head with some thread showing through it. The hand brake cable outer stops in the end of this long bolt via a swivel assembly. So undo the lock nut and turn the long bolt inward which pushes a small eccentric on the handbrake lever arm harder onto the brake pad and causes the handbrake lever arm to also angle away from the caliper tightening the cable.
    You will need to keep turning the wheel whilst adjusting so as to check the brake is not dragging, and that both sides are even.
    Hard to explain, easy to do.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
  13. #63
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,527
    Hey all,
    Rare Spares
    Ray geckoeng
    Think Old, But Run Modern !!
  14. #64
    10,259
    Hey all,
    Adding to Alan's description, you'll find workshop manuals fairly easy to find on ebay. I'd buy one if I were you!
    You'll also find a big shifter, not too thick, is needed to loosen the big nuts and I would suggest you don't tighten them much afterwards, just nip them up. You can make a good special spanner out of steel plate too, which will encourage not overtightening the big nuts! The long bolts can seize too, so hopefully yours are fine. I try to tighten both sides exactly the same number of turns, presuming yours were even to start with, which might be optimistic!
    Renault 4CV 1951
    Renault R8 1965
  15. #65
    Nov 2017
    Toowoomba, QLD
    67
    Feeling good today, just got the 10 on the road!
    Alot more work to do yet to get it where I want it but at least now I can move it around
    J-man, JohnW, bowie and 1 others like this.
  16. #66
    Aug 2002
    3,169
    Yaaaaay Awesome!
  17. #67
    Nov 2017
    Toowoomba, QLD
    67
    Hey guys quick question, are the ball joints riveted somehow on the R10? Bought some replacements which looked like I thought, bolt in jobs but on closer inspection I'm thinking they aren't. Any tips for getting them off?
  18. #68
    10,259
    AFAIK factory fitted were rivetted. Replacement kits use small nuts and bolts.
    Renault 4CV 1951
    Renault R8 1965
  19. #69
    4,237
    Yes, they were riveted in at the factory and are bolt in as replacements. Normally they use nyloc nuts on the replacement kits.
    The key is to very carefully grind the rivets down with an angle grinder from the top (balljoint side - on top for the lower arm and bottom for the top arm) so that you grind just before flush, without grinding too much metal off the arm. Then get a sturdy punch and hammer and try to knock the remains of the rivet through. The balljoint will lift out once the rivets are gone
    KB
  20. #70
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,742
    Another way to get the rivets out is to drill them out.
    59 Floride likes this.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
  21. #71
    4,237
    The large nut I’m pretty sure is 32mm. I bought a cheap spanner from supercheap, cut about 1.5- 2” from the length and welded the two ends back together. The logic of that is that it is still long enough to get some leverage, but short enough to be able to loosen the nut whilst the car is still sitting on the ground.
    KB
  22. #72
    It's how I roll...Brisbane
    32,383
    I endorse the drill method, after a carefully centred punch mark is in place.
