R1190 Project - Page 2
Page 2 of 3 First 123 Last
Results 26 to 50 of 72
Like Tree40Likes
Thread: R1190 Project
  1. #26
    4,242
    The block is definitely originally an 1100, so as someone mentioned previously the only way it could be a 1.4 is if someone machined out the block a long time ago to suit a 1.4 crank and liners. The clutch and flywheel end of the crank would tell you that detail.
    The carbie looks like the original solex however, so can’t see why someone would go to that trouble and leave the original carbie on. The rocker cover may just have been drilled to suit the third stud.
    KB
  2. #27
    4,242
    Ps - to get the rear guards off, don’t forget the three hidden nuts on the C pillar on the inside of the guard. It think they are 15 or 17mm.
    The fronts have a few bolts that can also be hidden by mud or body shutz but they are a bit more obvious. All of those should be 10mm.
    LeMansTragic likes this.
    KB
  3. #28
    Nov 2017
    Toowoomba, QLD
    67
    Thanks. Gaurds are coming off now
    Sent from my GT-I9505 using aussiefrogs mobile app
  4. #29
    10,270
    Yup. Looks like standard neglected R10 1100. Funny about the rocker cover breather butting against the carby heater hose though - the breather spigot is on the correct side of the rocker cover but at the wrong end. R12 rocker cover perhaps? Dunno.
    Expect corrosion in the cooling system...... With luck it won't be too bad.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
  5. #30
    Nov 2017
    Toowoomba, QLD
    67
    RH Rear fender off
    R1190 Project-1512787941257.jpgR1190 Project-1512787947815.jpgR1190 Project-1512787973796.jpg
  6. #31
    Nov 2017
    Toowoomba, QLD
    67
  7. #32
    10,270
    Not too bad really. Nothing fatal for that shell yet?
    Don't lose the securing nuts.....
    LeMansTragic and J-man like this.
    Renault 4CV 1951
    Renault R8 1965
  8. #33
    Nov 2017
    Toowoomba, QLD
    67
    Nah not yet. Will keep chipping away
    JohnW likes this.
  9. #34
    Nov 2017
    Toowoomba, QLD
    67
    Any tips on taking off the hand brake cable the caliper? Its been dragging along the ground....
  10. #35
    10,270
    Yup. It's slightly different from mine, as the end of the cable on yours is in that cubic block, whereas mine is in a smaller, round housing with a slot (see photos). Either way, it is the end of the handbrake cable housing. Maybe the R10s had the big cubic thing as part of the cable assembly, whereas mine slots into the smaller rounded fitting.
    The big nut is the lock nut for the handbrake adjustment (just nip them up by the way, not too tight) and the long threaded rod is the handbrake adjustment. Under the steel cube, not quite visible on your photo, is a 14 mm spanner hexagon - just screw the threaded part it right out of the calliper with lots of WD40 (it is steel into alloy female thread and yours is pretty corroded).
    I imagine the end of that threaded rod is the same as mine, that is the cubic steel block extends as a pin that goes into a hole in the end of the long threaded rod and can rotate. There is a small steel pin driven through the hexagon at the end of the threaded rod - to get the handbrake cable fitting off, you drive out that tiny pin, once you've worked out where the Hell it actually is. You can see the small pin on the hexagon on my second photo.
    I've found you don't need the pin again as the handbrake cable end fitting is pulled INTO the rod by the handbrake action.
    Straightforward once you have done it.
    Have fun.
    Attached Thumbnails Attached Thumbnails R1190 Project-handbrake-cable-mount-separate.jpg   R1190 Project-handbrake-cable-mount-calliper.jpg
    Renault 4CV 1951
    Renault R8 1965
  11. #36
    10,270
    Aha, just checked under my R8. My replacement cable (perhaps 1976!) has that same cubic block, so the cable housing doesn't come out of it at all. You just need to get the block off the long threaded rod by driving the hidden pin out of the hex fitting. Note that the block should rotate around the threaded rod, as the rod turns to adjust the handbrake. If you are going to replace the cable, just cut the thing off with bolt cutters. Get the calliper off the car and work on it in a vice on the bench.
    Renault 4CV 1951
    Renault R8 1965
  12. #37
    Nov 2017
    Toowoomba, QLD
    67
    Had a glimmer of hope when I peeled the rear quarter away but with further inspection towards the front (and this time knowing where to look thanks to some fellow Froggers) there are some trouble spots. In particular the underbody cross-members are essentially no longer there. (they made very scary crunching sounds when I used a jack on them). The bottom of the windscreen is rusty and someone has tried bogging them.
    Not giving up yet but if its gonna be done properly it'll need some work on a rotisserie.
    P.S. sorry for the upside down photos.... trying to fix that.
    R1190 Project-1512802580178.jpgR1190 Project-1512802585273.jpgR1190 Project-1512802592430.jpgR1190 Project-1512802597773.jpg
  13. #38
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    19,200
    Every day is a good day
  14. #39
    Oct 2014
    Windsor 2756 NSW Australia
    505
    It looks pretty bad and will need a lot of work, but it could be saved with enough commitment. There is not much holding it in shape if the crossmembers are rusted through and it is likely to be in need of some chassis alignment. There wont be much left if you dip and sandblast it so you may have to think about swapping all the running gear into another shell as a plan B.
  15. #40
    Ipswich, Queensland.
    1,829
    Quote Originally Posted by LeMansTragic View Post
    The rubber bellow is holding/jamming the cable into the square block. The cable will just pull out leaving the block and adjuster bolt still attached to the caliper.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
  16. #41
    10,270
    Thanks Alan. It's decades since I touched it!
    Renault 4CV 1951
    Renault R8 1965
  17. #42
    10,270
    Quote Originally Posted by Bustamif View Post
    Brave though. There are sound ones around.....
    Renault 4CV 1951
    Renault R8 1965
  18. #43
    Oct 2012
    599
    That'll just buff out. I sent my first shell to scrap after working on it for a year. My second one was also full of rust, I've spent a lot of time fixing it.
    If you can find another shell it may be easier to just send that one to scrap. If you do get rid of it first cut out all the good parts of the shell, I regret not doing that on my first, there are parts I could have used.
    Sent from my Nexus 6P using aussiefrogs mobile app
  19. #44
    Nov 2017
    Toowoomba, QLD
    67
    So the project has taken a major turn; I
    I purchased this 10 from fellow a fellow frogger so my first 10 is now designated as the parts car
    This one runs (big plus) and the chassis still exists so pretty excited to get it on the road!
    Sent from my Pixel 2 using aussiefrogs mobile app
    OnSafari, JohnW, R8 Dream and 4 others like this.
  20. #45
    10,270
    Now that looks like a good starting point! We look forward to news as you get close and personal.
    Better luck - you are well prepared now, at least.
    Renault 4CV 1951
    Renault R8 1965
  21. #46
    Nov 2017
    Toowoomba, QLD
    67
    Well back into it today, any tips on getting the door cards off the 10?
  22. #47
    10,270
    Two big screws for the armrests, a funny wire clip for the window winder handle and the rest are standard steel clips, if I recall correctly, and you just prise them out one by one, carefully as the card is cardboard!
    Renault 4CV 1951
    Renault R8 1965
  23. #48
    4,242
    They could be plastic John.
    Carefully lever them, supporting from behind as best you can.
    Consider if you really need to pull them off. There is a high percentage they will damage.
    KB
  24. #49
    10,270
    Really? Ah...
    They need great care and one of those broad, plastic trim removal tools.
    Thanks Kevin.
    Renault 4CV 1951
    Renault R8 1965
  25. #50
    Nov 2017
    Toowoomba, QLD
    67
    It's not a must but the regulator is stiff to use so wanted to get in there and lube it with silicone spray
