The Grand GTi Revival.
Page 1 of 3 123 Last
Results 1 to 25 of 68
Like Tree29Likes
Thread: The Grand GTi Revival.
    Fellow Frogger! EvilElmo's Avatar
    Jan 2016
    nsw
    612
    Default The Grand GTi Revival.
    After three months I'm kinda Nearly done,
    Booked in for a blue slip on thursday, might make it...
    (I went wildly off topic in another thread with this, I thought I'd put it somewhere a bit more relevant, My GTi was blowing smoke just like that when I got it. It had low fuel pressure so it would only run with the AFM disconnected, (WOT signal) which causes the sump to fill with fuel, so it had almost seven litres of two stroke mix instead of five litres oil...
    Same thing happened to my Si when the vac line to the MAP sensor busted.)
    So far it's had -
    Fuel pump reducer pipe, fuel filter, drive shaft, timing belt/tensioner, water pump, rust repair, fixed the wipers, re-tracked the AFM, reset the throttle switch, new slave cylinders in the back, new master cylinder, replaced the front brake lines, reconditioned the headlights AND fitted glass!
    Fitted correct slam panel, polished random body panels, repaired the glovebox lid, removed various bits of random wiring, Cleaned all the plugs/connectors under the bonnet, cleaned the broken glass out of the drivers door....
    - And so much more!
    Before...
    (A strange attachment).
    jech likes this.
    1000+ Posts CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    1,045
    Nice 205 Evil!
    Looks like a survivor alright! Great to see another S1 being revived. I'm looking forward to some after pics also
    Jan 2016
    nsw
    612
    Thanks,
    It's a 1987 1.6 english import. I bought it back in april pretty cheap. Last rego'd in 1998 I think.
    So far, I've thrown about another thousand bucks at it.
    The plan is get it to the FCD next week.
    Highlights so far - As new never been used ashtrays, (sounds silly, but have YOU ever seen three in the same car?)
    Lowlights so far - Both nuts and the bolt on the cam belt tensioner only finger tight.
    More random before pics.
    The Grand GTi Revival.-img_7043.jpgThe Grand GTi Revival.-gti4.jpgThe Grand GTi Revival.-img_7046.jpg
    Jan 2016
    Berwick VIC AUS
    1,045
    Nice find, got to be rare here and in the UK! and that interior inc dash looks excellent, you should see the sorry state my S1 dash is in!
    And low km's that's great. I especially like your lhs headlight, is that where the turbo breathes!?!?
    Jan 2016
    nsw
    612
    The dash has a little damage around the glovebox, apart from that it's very nice.
    Both headlights were like that, so twin turbos I think?
    CEyssens and BIGRR like this.
    Jan 2016
    nsw
    612
    Finally got to go for a spin around the block today, happy days!
    Pretty much functioned like a proper car. The engine has a little stumble now and again, but nothing too bad, vaccum leak maybe...
    A different animal to my Si for sure, snappier throttle, shorter gears, heavier and longer steering, and more power!
    I thought it wasn't that quick at first, then I remembered the speedo's in MPH....Oops!
    CEyssens, BIGRR and lozenge like this.
    Jan 2016
    nsw
    612
    Well apparently there is a waiting period if you want the nsw peugeot club to sign off on the classic car rego paperwork.
    And it also needs to go through a committee?? Would have been nice if that was on their website.
    So one less red GTi at the FCD...Dunno if I'll even bother bringing the grey one at this stage..
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,385
    Evil,
    give us the initials of who you spoke with in the Peugeot Car club.
    Robert
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Jan 2016
    nsw
    612
    If I got a decent offer I'd probably sell this little F'er right this moment...
    1,645
    and not regret it later? Surely not.
    307 HDi wagon
    407 HDi wagon
    Member jech's Avatar
    Jan 2013
    113
    In Brisbane there are plenty of multi-make classic car clubs in various areas that have approval to sign off for classic car rego in Queensland, maybe there's one near you? There's also the department of transport 1-day permit scheme which allows the car to be driven to a specified location and back, such as for repairs or an event, I presume NSW has something similar? Cheers, James.
    Jan 2016
    nsw
    612
    There are local "multi-denominational" clubs about, but I'm not really into that kind of cruising scene.
    I'd also like to join a club that might understand my 205 fetish...
    ...Anyways, after a good lie down, a can of beans and a quick chat with a certain big fella, turns out I'm pretty screwed for now as far as club rego goes, need to be a member of PCCONSW for six months first.
    If I pass the blue slip on thursday, (vaguely possible) I might consider full rego and just daily drive the feisty little bugger for a while...
    Fellow Frogger! lozenge's Avatar
    Castlemaine
    493
    hang in there! it's great you've resurrected this beastie, good on you.
    brisbane
    2,882
    Having a UK 1.6 Gti myself i have heaps of spares for it if you need them. [dizzy caps, coils, ign leads ] You will find parts are not as easy to find for it in OZ however some bits are carry overs from the 1.9.
    jr20516v
    Now:
    Exige SC [modded], 205 Si. Opel OPC
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    Jan 2016
    nsw
    612
    Thanks guys, but I think I'm done with this car stuff for a while.
    Jan 2016
    Berwick VIC AUS
    1,045
    Quote Originally Posted by EvilElmo View Post
    NOOOOoooooo.... I was enjoying reading your posts again Evil
    Apr 2014
    Orange
    366
    If you are going to get rid of it by parting out can I have first pick of stuff on it Hope you don't though.
    Jan 2013
    113
    Just put 1 year or 6 months full rego on it and drive it for a bit, that's what I've done with mine. Then you can decide whether to go onto club rego after that.
    BIGRR likes this.
    Jan 2016
    nsw
    612
    So, having gotten over the worlds worst case of the sulks, I've got a blue slip for the GTi. Don't know how, but I've got one.
    And after remembering I don't just own pugs, (48/215 anyone?), I may have found a club that suits my needs.
    I'll know more tomorrow...
    BIGRR, lozenge, CEyssens and 1 others like this.
    Apr 2014
    Orange
    366
    Awesome. Who did you end up with? One of the local clubs? Not sure if Bathurst light car club do club plates?
    Jan 2016
    nsw
    612
    I've been talking to the gnoo blas classic car guys, sounds like it shouldn't be a problem,
    I'll try and get sorted tomorrow, just have to wait and see....
    *I considered selling it for less than a minute I think, I'd just have to go buy another one...
    CEyssens likes this.
    Jan 2016
    Berwick VIC AUS
    1,045
    Glad you're back, the dummy spit was a bit entertaining!! Nice to hear you've found another club to get on the road with
    Jan 2016
    nsw
    612
    Quote Originally Posted by CEyssens View Post
    Nah, you can tell it was only a sulk, no one called the cops,
    Jan 2016
    Berwick VIC AUS
    1,045
    It must be love
    Jan 2016
    nsw
    612
    I've spent all day swapping between my Si and the GTi, "Lovin' It" Seems an appropriate phrase.....
