Finally bought a 205...now the problems!! - Page 4
Page 4 of 5 First 12345 Last
Results 76 to 100 of 118
Like Tree43Likes
Thread: Finally bought a 205...now the problems!!
  1. #76
    Fellow Frogger! moeozz's Avatar
    Jul 2012
    melb
    242
    Quote Originally Posted by Isis View Post
    To get an RWC you will need to cover the intake pod somehow. This of course also stops it from sucking engine bay air.
    Yeh I'll be making something up.
    Does anyone know what's up with the induction outlets above? It probably doesn't seem like much but it's those little things which can catch you out.
    current S1 205 GTI + S3 306 GTI6
    previous s2 306 GTI6
  2. #77
    Jul 2012
    melb
    242
    Can anyone recommend some Coolant for the mi16...or should I get it direct from Peugeot?
    According to Haynes I need an Ethylene glycol based antifreeze between 28-50% but this is a first and I have no idea what's best.
  3. #78
    7,318
    Nulon Ultra Cool. Unless you're going to the snow you don't need anti-freeze.
  4. #79
    Jul 2012
    melb
    242
    Can someone please remind me where hose #11 connects to?
  5. #80
    1000+ Posts gezza's Avatar
    Bunbury
    2,175
    Isn t that just overflow and goes down inner wing
    Wildebeest likes this.
    1990 Renault 5 GT turbo
    ####current rides####
    1994 205 gti 1.9 sorento green
    1988 205 gti 1.9 uk import grey
    2001 clio 172 sport ph1 #44/85
    1998 306 gti6. Blaze yellow
    1992 Honda Fireblade
    2013 Yamaha fzs sho Jetski
    1998 Supra RZ twin turbo white
    1999 Wrx classic gc8 sonic blue
  6. #81
    Jul 2012
    melb
    242
    It's apparently just for "degassing", don't think it connects anywhere
  7. #82
    Jul 2012
    melb
    242
    I'm having troubles getting my Oil Pressure + Temp sensors working. Been at it for a week now to no avail.
    My main concern is the temp sensor at the moment, it looked damaged from transport, so I replaced this with the spare from my old 205 engine. Mi16 wire 30C, connected to 205 wire 30A.
    Still no reading on the instrument cluster. I did the grounding dial trick (pin 7 on the white cluster connector) and the dial does work. This rules out a faulty cluster.
    I've had the engine running for at least 5 minutes on multiple occasions, surely this is enough time for the sensor to start registering? Any tips? Not sure what else I can check tbh and I'm worried about it overheating... Thanks
  8. #83
    Jul 2012
    melb
    242
    Any advice on the above issues?
  9. #84
    8,386
    Does the idiot light work for both? That should help you prevent overheating and oil pressure loss (or at least let you know about it).
    What else have you tried? Checked the wiring?
    Run a wire directly to the cluster from the senders and see what happens. It's quite straight forward, shouldn't be too much effort. I have a pair of wires with small alligator clips for situations like these. This test at least helps diagnose some wiring fault of which I had to find many. I found this was the most productive way.
    ACHTUNG ALLES LOOKENPEEPERS
  10. #85
    Jul 2012
    melb
    242
    No they don't. According to the manual.. the STOP and oil pressure warning lights are meant to activate @ accessory mode, I'm not getting either. I've also replaced the bulbs to no avail.
    Do you have a 205 yourself schlitz? Can you compare your cluster on startup and how long it takes for a oil temp/pressure dial to register?
    I've checked the wiring to the oil temp sensor end-to-end and it looks fine. I did also run a bypass wire straight from the sensor to the cluster, but made no difference.
    The oil pressure sensor's much harder to get to so I'm yet to confirm that, but it was wired up as per PeterT's wiring spreadsheet.
  11. #86
    8,386
    Why ask? I made reference to my car many times in the past.
    If the car still has the original spade connector, it's not that difficult to push it off the oil pressure sender and reach down with an alligator clip. If you want to take the sender off, you will need a short 17mm spanner (you might be able to get on the nut but you won't be able to swing a normal one). I have a rubbish one from a tool set of some car I might have had in the past, it's thin, single end and short.
    My car has all the red lights on accessory, except the coolant level warning (unless the level is low).
    The oil temp gauge takes a couple of minutes to lift off zero. I guess it depends on your driving, I start the car and take off in a huff.
    Some time ago the oil temp sender terminal poking out at the back broke off and I had to turn down on the lathe some of the insulation, solder a pig tail and silicone everything up. No problems since.
  12. #87
    5,889
    Why ask? I made reference to my car many times in the past...
    By that reckoning, I still ride a purple Malvern Star Dragstar.
    2003 PEUGEOT 206 GTi
  13. #88
    7,318
    Found it.
    Attached Thumbnails Attached Thumbnails Finally bought a 205...now the problems!!-dragster.jpg
  14. #89
    8,823
    Yes..
    Quote Originally Posted by gezza View Post
  15. #90
    8,386
    I thought you would know I didn't throw out junk.
  16. #91
    Jul 2012
    melb
    242
    This may be too much to ask, but do you mind taking/uploading a short video of the cluster please, going through each ignition mode (acc > on > start)?
  17. #92
    8,386
    Not a problem except I don't think I've got anything that records video?
    Which might be a problem.
    I'll give it a try. I think I have a super eight camera somewhere.
  18. #93
    18,043
    Most mobile phones record video.
    with apologies to Judy Grahn
  19. #94
    8,386
    Ha! Not mine.
    It can take pictures at a resolution of about three pixels though.
  20. #95
    8,386
    Now the drama begins.
    Hopefully you can see the lights. I had to wait to get home and have some darkness, the camera is so bad.
    How the heck do you upload a video?
    I can't select the .avi file in the attachment window.
  21. #96
    Jul 2012
    melb
    242
    Good question, I don't think you can upload .avi to the forum, but it does accept youtube links.
    If you don't have a youtube account, or don't want to sign up for one, you can upload it directly to here instead (without an account):
    https://uploadfiles.io/
    Once complete, it'll give you a link to share.
  22. #97
    5,889
    That's the one! Ha ha.
    Found it.
    Moeozz, doing a good job there. You can't go wrong with Schlitzy and Peter on the line.
  23. #98
    8,386
    Right.
    Here it is:
    https://ufile.io/b2kd7
    Hope this works. Dang, I thought computers were supposed to make your life easy.
    Screw you, Stuey.
  24. #99
    Jul 2012
    melb
    242
    Thanks Schlitz. Definitely more lights than I'm seeing on mine, back to the drawing board.
    Computers do make it easier, but you'll need to take baby steps. Start by upgrading your phone!
  25. #100
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    19,080
    Quote Originally Posted by moeozz View Post
    He has, the phone wasn't connected by wire to the wall
    Every day is a good day
