Finally bought a 205...now the problems!! - Page 2
Page 2 of 5 First 12345 Last
Results 26 to 50 of 118
Like Tree43Likes
Thread: Finally bought a 205...now the problems!!
  1. #26
    8,483
    All those companies would make them, they are nothing special.
    That is why I said you need to give them some data. If you measure it with some callipers it will be enough to match even over the phone. If you can take it in, even better.
    When you want to pull it apart, just leave it in the sun on a hot day for long enough to expand a little bit and it'll come out easier. Still needs a press though and be careful to support closely and press only against the bearing race you want to pull out and steel shafts/housings, not alloy castings or stuff like that.
    Be thankful you don't have to pull the bearings off a Renault 12/17 diff (one of the bearings is also a "special edition" SNR with undersized inner race too, bloody son of a dorongo).
    phasselhoff likes this.
    ACHTUNG ALLES LOOKENPEEPERS
  2. #27
    Fellow Frogger! moeozz's Avatar
    Jul 2012
    melb
    242
    Diff bearings have been sorted and pressed, ended up with the timken JL69349A/JL69310 as seen here.
    Water Pump + Timing belt also replaced.
    I have a few other questions if anyone can lend a hand.
    Gearbox. I want to use my current 205 BE1 gearbox on the mi16 engine. I just want to know whether it a simple plug and play procedure like I think it is?
    • Keep the mi16 clutch and flywheel
    • Bolt on the 205 gearbox with BE1 release bearing
    • Install TDC sensor onto 205 gearbox (taken from original MI16 gearbox)
    • I can use the original be1 speedo casing and sensor.
    • All links and cables remain unchanged.
    Pics of my 2 gearboxes are here
    I'm just a little confused about the differences in push/pull/BE1/BE3 systems I keep reading on about.
    Also, when bypassing the heater circuit with the 205 water distribution adapter, I'll need to block the other end (pipe which runs behind the engine head) which I believe connects to the thermostat? I read somewhere that you need a 1/2" BSP and bung. Stupid question but where can these be purchase from?
    Finally, what have people done with their mi16 oil-coolers? Standard (water cooled) seems to be the ok overall until it comes to changing the filter due to limited space. The UK guys seem keen on reusing the 205 air setup for some reason but involves some tinkering which I'm yet to understand.
    Below are some pictures I found for the different scenarios.
    "This is with everything fitted. Yellow are 205 hoses, red are mi16 hoses"
    "No oil cooler and the metal pipe on the head is removed. 205 water distributor used instead."
    Once this is sorted I can drop it in and move onto the wiring.
    I did warn in post #1 that I may ask stupid questions and I seem to be doing just that Any help would be greatly appreciated!
    Roland likes this.
    current S1 205 GTI + S3 306 GTI6
    previous s2 306 GTI6
  3. #28
    8,483
    If you have a look at the plastic 205 distribution block that bolts at the back of the engine, you will see the third outlet is moulded but plugged. The plug has an Allen key hex. You can take it out if you want to use the block but looks like you will need a straight piece of hose instead of the 90 deg elbow.
  4. #29
    Jul 2012
    melb
    242
    Sorry Shlitz, I'm now more confused. The 405 came with a 5 port (1 is blocked) plastic distribution block, the 205 is aluminium / 4 port (1 blocked). The plan is to use the 205 distro to bypass the hose going to the thermostat housing. I just need a way of blocking it at the thermostat aswell. Are we talking about the same thing or am I just lost?
    Attached Thumbnails Attached Thumbnails Finally bought a 205...now the problems!!-img_7784.jpg   Finally bought a 205...now the problems!!-img_7785.jpg
  5. #30
    8,483
    Oh, okay, you have an aluminium 205 block. Mine (and I have a few) are all plastic, but pretty much like yours and they don't look like they have a bung you can take out unless you clean them up thoroughly and look in the end.
    I didn't read your post as a clear intention to bypass the thermostat and looking at your diagram above (top one), I thought you needed an extra port in the block and not knowing anything about the 405 block I thought you might not have realised there was another port you could have used on the 205.
  6. #31
    Jul 2012
    melb
    242
    All good. I think the S1 GTIs came with the aluminium blocks. any tips on blocking the other end?
    I installed the Quaife diff last night. As expected the old bearings had clear markings to identify itself. SNR JL69349A cone and JL69310A cup. Luckily I have an equivalent replacement in the Timkens.
  7. #32
    8,483
    You are asking about the thermostat hosing, right? If it is aluminium, I would just have a plate welded there to blank it off, it's the most reliable way rather than stuffing around will all sorts of bodging. And if you want to open it later, a hacksaw should do it.
  8. #33
    7,358
    I think this is what you mean. Sorry for the delay and misinformation. Remove the bypass tube with the aid of some heat from an oxy torch. The hole is the perfect tapping drill size for 1/2" BSP. Screw in a bung and seal with Loctite 549 or similar. Send it to me if necessary. The result is neat and tidy.
    Attached Thumbnails Attached Thumbnails Finally bought a 205...now the problems!!-bypass-pipe.jpg   Finally bought a 205...now the problems!!-tapping-thermo-housing.jpg
    Roland likes this.
  9. #34
    8,483
    Now I see your problem.
    I would cut off the tubing to a straight length and then extract cold with a tap of convenient size screwed in a few turns or if there is access to the other side with a convenient size washer, a bolt, a spacer and a nut (make a crude but efficient puller). For bunging I would just use a conveniently sized (read slightly oversized to give an interference fit) bit of aluminium driven in cold (use freeze and release) and it's as good as a weld.
    Might be tricky to find something that fits perfectly - I have a lathe and turn these things nicely with a bit of taper and freeze them overnight and then just whack in. You can use Loctite retaining compound, but it's not necessary if the fit is good.
  10. #35
    Jul 2012
    melb
    242
    Thanks guys, will assess the options and have a go.
    I'm still confused on how to plumb the other coolant hoses, especially with the mi16 oil cooler.. I've purchased the baker bm coolant hose kit and I think this assumes that the cooler is bypassed. What have people chosen to do with theirs?
    And can someone please review my gearbox change procedure above, This is the only thing stopping the engine from going in
    Thanks!
  11. #36
    Jul 2012
    melb
    242
    Hi again, I need some help identifying these wires from the mi16 loom and what/where they connect to. I'm unable to tell the numbers on a few and one is completely destroyed which I'll need to re-terminate. Most of them are located around the gearbox area but #8 is on the very end of the loom and #10-11 are near the injectors/coil.
    Even better, is there some sort of table which lists each wire # and it's purpose? The ecu pinout document I have doesn't go to this detail.
    P.S, the other questions above are also pending. Thanks!
    Attached Thumbnails Attached Thumbnails Finally bought a 205...now the problems!!-123.jpg   Finally bought a 205...now the problems!!-456.jpg   Finally bought a 205...now the problems!!-7.jpg   Finally bought a 205...now the problems!!-8.jpg   Finally bought a 205...now the problems!!-9.jpg   Finally bought a 205...now the problems!!-1011.jpg
  12. #37
    7,358
    Don't use the Mi16 oil cooler. Use all 205 bits.
  13. #38
    Jul 2012
    melb
    242
    Please excuse my naivety Peter, can you elaborate on this or link me to a guide for assistance?
    Although past conversions also reference this, some also suggest to remove the mi16 oil sandwhich plate and just bolt the filter straight to the block, bypassing the cooler system altogether. Do you have any experience/suggestions regarding this?
    PS, the car won't be driven daily or tracked if that makes a difference.
  14. #39
    7,358
    Having the Mi16 oil cooler makes it very difficult to do an oil change. It's far easier to use all 205 GTi parts for the oil cooling system. ie remote filter and cooler mounted on the gearbox. If you use an 8V aluminium thermostat outlet, the top radiator hose will bolt up as per usual.
    Many XU engines have the oil filter screwed straight to the block. However, any sort of vigorous driving in summer will see the oil temps sore to 120+.
    I haven't had a chance to study your wiring pics. Do you have a copy of the OEM Mi16 engine wiring diagram?
  15. #40
    7,358
    18, 1, 1A - plugs into the +12V distribution/fuse box. Either use 405, S3 GTi or Si model.
    22, 68 ,7 , 9 - AFM
    33, 91 - Idle control valve
    13, 15B - ECU coolant temp
    15, 2R, 3 - throttle position switch
    96, M96 - oxygen sensor heater element
    10, 141 - oxygen sensor signal (shielded wire)
    Plug 5 could be reverse switch on gearbox? Trace to be sure.
    Item 7 - no idea, bodgy aftermarket wiring, you'll need to trace them back
    Plug 1 - the only pair of red wires I recall are the oil temp sender. The insulation is usually badly cracked & hardened from the exhaust heat.
  16. #41
    Jul 2012
    melb
    242
    Thanks Peter. I've connected the 205 thermostat cover and remote oil filter setup. It was a pain maneuvering around the red oil hose and for the life of me I can't figure where the 2 outlets on the filter plate connect to. Any help here?
    Finally bought a 205...now the problems!!-img_7902.jpgFinally bought a 205...now the problems!!-img_7903.jpg
    In regards to wiring, could you please send me a copy of the mi16 wiring diagram? The ecu is 261200161.
  17. #42
    7,358
    You need a GTi 205 top radiator hose. There are two types.
  18. #43
    Jul 2012
    melb
    242
    I think the 2 types are 1343-C3 and the 1343-E9 (double T style)
    I can't recall how my 8v oil cooling system worked to begin with and I can't find any photos prior to removal. However, my top radiator hose is the single type and so is the one from my bakerbm kit. Unless I'm missing something, the previous owner may of bypassed the system at one stage.
    I can either purchase a new double T top radiator hose and delay the project further or bypass the cooling system altogether for the time being and worry about it later.
    EDIT: Can I retain the 205 remote oil filter setup and leave the cooler pipes disconnected for now? Would it behave in the same way as if it were mounted directly to the block with no cooling, or would oil ooze out from the 2 pipes?
    EDIT 2: or instead of leaving the 2 oil cooler pipes disconnected, I just loop them to each other? Again, what are the consequences of doing this?
  19. #44
    Jul 2012
    melb
    242
    Engine is finally in! Such a squeeze. I did leave all the ancillaries attached so I'm partly to blame. Had to angle the gearbox down and under the wheel arch, level the other side, bolt up the battery tray and then bolt the mounts.
    The exhaust pipes aren't lining up properly. Is this meant to be difficult and more importantly, bolt up air tight/flush? I'm using the 205 downpipe with Peter's wedge plate.. Picture below is the closest I could get after a 30 minute struggle
    Finally bought a 205...now the problems!!-img_7946.jpgFinally bought a 205...now the problems!!-img_7944.jpg
  20. #45
    7,358
    The two types are S1/S2 and S3 GTi. Both have the double pipes, but the arrangement differs depending on the outlet directions of the cooler pipes.
    I would cut your exhaust pipe before the cat. Get the down pipe direction & fit correct and then reweld it back together.
  21. #46
    Jul 2012
    melb
    242
    Was hoping to avoid cutting the exhaust but that can wait til the end now.
    I have a new batch of pictures/stupid questions needing explaining please. I honestly thought I took more than enough photos prior to the engine removal and should've been safe, I was wrong
    The mi16 positive battery terminal looks different to that from the 205. The 205 terminal contained a plug which I believe connected to the sensor loom. Is this correct and how would I rejoin the sensor loom without this terminal on the mi16 loom?
    I believe these may of came off the 205 BE1 gearbox, though I can't recall where or find it's spot!
    Where does the hose for this come from?
    I think this hose goes to the fuel filter (top). What is this circled and can it be removed (NA on 205)?
    What goes into this hole on the gearbox? I can't recall if anything was connected prior to removal, but it's open. Surely it's not standard/safe like this?
    Canister purge? One end to the throttle body, the other?
    If any Victorians are reading this and have a 205 mi16 themselves, I'd really love to see your car to get a better understanding. Or even better, I'd love a hand because at this rate I'm just flooding the forum and going nowhere... and I'm not even upto the Wiring!
  22. #47
    7,358
    Quote Originally Posted by moeozz View Post
    Find an Mi16, S3 or Si block. Use battery cables from the same.
    Inspection cover and speedo cable retaining pin.
    Fuel return to tank.
    Leave that off. It's fuel damper.
    Breather hole cap in BE3, lift up reverse cable in BE1.
    Carbon canister under LH front guard.
    Hope that helps.
    Roland and moeozz like this.
  23. #48
    Jul 2012
    melb
    242
    Thanks Peter. Your wiring diagrams are helping make more sense now. Though it looks like I've hit another roadblock!
    I've searched the mi16 loom multiple times over and cannot find the plug for the TDC flywheel sensor pictured at #6. This sensor was previously on the mi16 gearbox but migrated to the 205 be1 which originally didn't have one.
    I'm not sure about the history of this loom, but I can't see any obvious modifications to it either.
    The Large ECU plug does contain the terminals at pins 47+48, the only way of really knowing where they run is to butcher each wire and run a continuity test which I'd like to avoid.
    Would anyone know how far down the loom it sits and what the plug looks like?
    EDIT: FOUND IT! It was connected to the throttle body, mixed up with the other 3 pin plug.
    I won't be trusting the current connections on the engine, will be taking them all off and confirming them from now
    Attached Thumbnails Attached Thumbnails Finally bought a 205...now the problems!!-456.jpg   Finally bought a 205...now the problems!!-tdc-sensor-wiring.png
  24. #49
    Jul 2012
    melb
    242
    Just a few more questions guys :s
    Does anyone have a photo of this distribution/fuse box and explain why I cannot use that from my S1 205?
    Again, does anyone have a photo of the required part? I find it strange that the positive terminal cable I was given with the MI16 is not suitable for the task. Is it non standard? Can I not use the S1 205 GTI positive cable?
    Finally, I can't find the following 205 sensor loom wires which require splicing to the mi16 loom. I don't believe they aren't numbered on a Phase 1 which doesn't help the nontechnical like me.
    • 'White switched power' (connect to 'Wire #2 on the mi16 loom- Black Connector)
    • 'Ignition Coil Wire' (connect to 'Shielded Green on the mi16 loom- Black connector)
    • 'oil pressure gauge' (connect to 'Wire #6 on the mi16 loom- Brown connector)
    Would appreciate any help sorting the above, thanks!
  25. #50
    Jul 2012
    melb
    242
    Is anyone able to assist with the above questions?
