Car ID - Page 4
Page 4 of 7 First 1234567 Last
Results 76 to 100 of 174
Like Tree26Likes
Thread: Car ID
  1. #76
    Nov 2016
    NAIROBI, KENYA
    112
    Car ID-1485321968648.jpg I don't know whether its visible from this photo but there is a piece of rubber jutting from the very edge of the hole. Could be some sort of seal attaching to the pump perhaps?
    Sent from my Infinix-X600-LTE using aussiefrogs mobile app
  2. #77
    SWOTR
    3,283
    Looks like it. Does the small hole in the middle of the larger round casting go all the way through or is it water tight? Maybe it matches the water pump impeller shaft?
  3. #78
    Nov 2016
    NAIROBI, KENYA
    112
    It should go through. It would only make sense. The replacement is here Car ID-1485373563942.jpg plus an engine mount replacement for one that we found torn off its base. New control arm bushes will also be going in.
  4. #79
    Nov 2016
    NAIROBI, KENYA
    112
    This is what the business end looks like
  5. #80
    Nov 2016
    NAIROBI, KENYA
    112
    Had the misfortune of losing my grille today. Looks toothless. Worn clips must have had something to do with it. Highway cruising speeds didn't help matters
  6. #81
    Perth Western Australia
    2,633
    Overfinch,
    Once again if you only lived in in the next street......
    I have two grilles hanging on my lockup wall. The plastic clips are a weak point. The retaining screw is a must.
    How goes it with the ignition conversion. What news from Simon?
    The trapezoidal headlights aren't as common on 504's in Aus. I have the twin headlights on mine, cheaper to replace.
    I have found on previous 504's that the "trap" lights aren't very effective. The clever comment was that at anything over 40.mph the 504 would overtake the light beam!
  7. #82
    SWOTR
    3,283
    That's bad luck. Can you get another one easily?
  8. #83
    Nov 2016
    NAIROBI, KENYA
    112
    Overfinch,
    No words mate. Could do with one of those. I am yet to see a 504 with the twin headlights. Overtake the beam? That would be interesting to see. Is it physically possible to overtake light?
  9. #84
    Nov 2016
    NAIROBI, KENYA
    112
    Quote Originally Posted by Peter Chisholm View Post
    It shouldn't be hard to find one at the wreckers. Car looks nude without it
  10. #85
    Nov 2016
    NAIROBI, KENYA
    112
    The car stalled at some point yesterday while I was out and about on the highway. I had had it serviced this week (dead plugs and 'crude' oil). After servicing I did a run with the mechanic and complained to the mechanic about loss of power.
    Anyway, the stalling forced me to veer off the road. Luckily, I was close to a fuel station. Before calling the mechanic, I popped the hood and noticed the carby was dripping some fuel. The smell of fuel was also quite noticeable in the cabin. I then called a mechanic over and after fiddling with the engine for a bit, he pulled out the fuel line to the carburetor at the fuel pump and bled a bit of fuel then asked me to turn on the car and it started. He then reset the car's idle. I didn't have any issues onwards and power was noticeably increased. Can idle setting 'choke' the car? Any theories about what might have happened?
  11. #86
    Nov 2016
    NAIROBI, KENYA
    112
    I had a very helpful exchange with Simon. Unfortunately, he asked me to remove the distributor entirely. Now this posed a problem because my mechanic would not have a clue of what to do if removing the distributor affected timing in any way (does it?). I guess that's where we stalled with that aspect. I will embark on it as soon as I find someone who can confidently remove the dizzy and return it once I have the details I need for Simon.
  12. #87
    SWOTR
    3,283
    In Australia, the twin headlights were part of local content requirements from 1973 (I think) onwards.
  13. #88
    Nov 2016
    NAIROBI, KENYA
    112
    I have seen later models of the 504, including year 2000 model. These still came with the trapezoidal headlights
  14. #89
    Nov 2016
    NAIROBI, KENYA
    112
    Any comment on my questions above Pete?
  15. #90
    2,633
    Overfinch,
    In the absence of Pete ["we don't know where he are"] Allow me to help with the dizzy removal.
    We've established yours to be a Bosch distributor? No matter the same method of removal applies.
    Locate No 1 cylinder on the dist cap, mark with white paint*. Remove cap, rotate engine until the rotor points to that position. If I recall the Bosch will have a small notch indicating this. If not mark with paint also.
    Now on the outside of the dist near the clamp, mark with paint. Make a corresponding mark where the dist enters the engine.
    Remove the small wire at the dist. Loosen the clamp bolt, remove the distributor.
    After getting the information requested by Simon it should be a simple matter of refitting the dist by observing the paint marks.
    The distributor shaft has a key that will only enter one way so there are are no gear teeth to line up when refitting.
    Refit the ignition wire and the cap. On starting the timing should be as before.
    * I have always marked the No 1 plug wire with a small cable tie.
    Overfinch likes this.
  16. #91
    SWOTR
    3,283
    Quote Originally Posted by Overfinch View Post
    I think the twin headlights were unique to Australia.
  17. #92
    Nov 2016
    NAIROBI, KENYA
    112
    Extremely helpful Sir. That should be a perfect guide. What about the fuel pump overflow issue I was inquiring about? Any leads on that? As below..
    .......................................The car stalled at some point yesterday while I was out and about on the highway. I had had it serviced this week (dead plugs and 'crude' oil). After servicing I did a run with the mechanic and complained to the mechanic about loss of power.
    Anyway, the stalling forced me to veer off the road. Luckily, I was close to a fuel station. Before calling the mechanic, I popped the hood and noticed the carby was dripping some fuel. The smell of fuel was also quite noticeable in the cabin. I then called a mechanic over and after fiddling with the engine for a bit, he pulled out the fuel line to the carburetor at the fuel pump and bled a bit of fuel then asked me to turn on the car and it started. He then reset the car's idle. I didn't have any issues onwards and power was noticeably increased. Can idle setting 'choke' the car? Any theories about what might have happened?........................................
  18. #93
    2,633
    Overfinch,
    Not much to offer re your fuel problem other than a couple of basics.
    The carburetor idle jet may have picked up some dirt likewise the float needle and seat assembly being held open [dirt under seat].
    The latter would have caused 'flooding', fuel around carb. and smell.
    I don't know what your mechanic achieved by removing the fuel line?
    Has your 504 got a fuel filter? Best placed on the tank side [inlet] of the pump. There is a fine gauze strainer at the carb inlet.
    The query re the idle setting 'choking' the engine. Only if it is idling too slow or the idle mixture adjustment is too rich.
    I hope my previous post on setting the distributor wasn't too wordy along with the paint marking.
    If it doesn't work out you could always put it up as an exhibit in the next African Art Show!
  19. #94
    10,270
    Quote Originally Posted by peter chisholm View Post
    i think the twin headlights were unique to australia.
    usa.....
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
  20. #95
    2,633
    usa.....
    Johnno,
    The headlight choice in the "New World" came about because they could not come to grips with the trapezoidal type. Volvo and others had to fit twin headlights to comply.
  21. #96
    10,270
    Johnno,
    Exactly, along with Renault 12, 15, 16, 17 and 20/30, Citroen DS, CX and SM and no doubt others. US safety regulations. The good outcome for me was our Renault Virage (an Australian R12 with the Canadian front if I recall) when I put good Hella lamps in - fabulous lights!!
    Renault 4CV 1951
    Renault R8 1965
  22. #97
    Nov 2016
    NAIROBI, KENYA
    112
    Spotted this beauty somewhere in NairobiCar ID-1487482400028.jpgCar ID-1487482422771.jpg
  23. #98
    Nov 2016
    NAIROBI, KENYA
    112
    Hello good people. I almost fell off the face of the planet there. Its been a while since I brought you up to speed with my side of events. Well, I fitted an Audi exhaust (terrible idea) which had to come off and I got a proper and new gleaming exhaust. I'll post a picture soon. I then had a negative terminal problem that caused starting problems but it got sorted out by a wiring pro. I've been losing coolant a lot of late. So yesterday in the height of idleness, me and my mechanic set about taking off the cylinder head.
    Cylinder Head and block were in a sorry state. However, there are no issues with how the pistons seal.
    Lo and behold! Flooded cylinders. Head went for a grind today. Came back shiny
  24. #99
    2,633
    Overfinch,
    It looks like the head guy removed the minimum from the head, no bad thing.
    It doesn't look like he has done any cleaning after machining. A good blow out of the bolt holes and anywhere that may be hiding grit etc.
    A good strong degreaser accompanied by a wire brush will give the job a professional look to the head.
    I think I may have emphasized the importance of cleaning any assembly before dismantling. I was taken to task because of this.
    Pssst. Make sure you fit the head gasket correctly. An easy mistake to make.
  25. #100
    Nov 2016
    NAIROBI, KENYA
    112
    Overfinch,
    Hello Wildebeest,
    Cleaning was done before reassembly. Haven't heard it rev yet. Can't wait. Are there significant gains (performance or otherwise) I can look forward to as a result of the grind?
