1970 Peugeot 404 ute Restoration - Page 3
Page 3 of 3 First 123
Results 51 to 56 of 56
Like Tree56Likes
Thread: 1970 Peugeot 404 ute Restoration
  1. #51
    Dec 2002
    2,507
    Looks fantastic Marty! This is where it starts getting fun
    Dano likes this.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
  2. #52
    Jan 2013
    Geelong
    469
    Hey Marty!
    What did you use for the gasket/collar around the fuel filler neck?
    Mine is stuffed & I was going to use a solid rubber round about 20mm diameter from Clark Rubber.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
  3. #53
    Jan 2012
    Gold Coast
    179
    Hi Geodon The fuel filler collar on mine is a General Motors part that came with the ute ,my guess is that its from a Kingswood station wagon . The 404 sedans have a different system.
    I stripped my dash to paint it the wiring is a mess and missing a lot of numbers so thats the next challenge .
  4. #54
    Jan 2013
    Geelong
    469
    Quote Originally Posted by marty 404 View Post
    Yeah well, good luck with the wiring! My experience:
    * Get a multi-meter & learn to use the Continuity Function.
    * You'll need new spade terminals; use Narva ones- the generics are worse than useless- they just fall off again with only minimal provocation.
    * Make sure you earth the wiper switch- if you don't you wont be able to turn the buggers off!
    *Get ALL the idiot lights working before you install the dash.
    * Install the U-bolt for the steering column BEFORE you install the 10mm mounting bolts for the dash & make sure the M7 studs of the U-bolt are well & truly screwed into the threaded bar. A bit of Loctite wont go astray here.
    * Hook up the speedo cable BEFORE you install the dash. It will save heaps of angst trying to do it with the dash in-situ. Don't hook up at the GB end 1st.
    1949 Citroen Big 6
    1955 MGA1500
  5. #55
    Jan 2013
    Geelong
    469
    One more thing: Stick the speedo cable in the speedo & try to spin the cable. You don't want to find out the speedo is seized after you have every thing installed.
    Like I did!!
    1949 Citroen Big 6
    1955 MGA1500
  6. #56
    Jan 2012
    Gold Coast
    179
    I have been working on all the interior parts the ute never had a fan in the heater box with the switch blanked off I found a sedan fan that works well and is quiet [bonus].
    1970 Peugeot 404 ute Restoration-img_1457.jpg1970 Peugeot 404 ute Restoration-img_1455.jpg
    Next the dashboard ashtray and instrument surround where painted with wrinkle coat
    then I set up the heater core to pressure test the first core leaked so I set up an older looking core which so far is holding water
    1970 Peugeot 404 ute Restoration-img_1468.jpg1970 Peugeot 404 ute Restoration-img_1469.jpg1970 Peugeot 404 ute Restoration-img_1470.jpg
    The instrument cluster needed checking I replaced and checked all the light bulbs and holders then checked the speedo [thanks Geodon]
    of three speedo,s one is seized one is shaky one is ok.
ID:	1107261970 Peugeot 404 ute Restoration-img_1471.jpg1970 Peugeot 404 ute Restoration-img_1474.jpg
    FIVEDOOR, geodon and Dano like this.
