Little Silver 205GTI - Page 7
Page 7 of 8 First ... 345678 Last
Results 151 to 175 of 176
Like Tree71Likes
Thread: Little Silver 205GTI
  1. #151
    1000+ Posts CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    1,024
    Quote Originally Posted by N5GTi6 View Post
    Looks like a crack in the bottom of the mount socket - you need to plate that and weld it up.
    Justin
    Nice pickup Justin!
    I did notice something but hadnít had a chance to get in there with a wire brush to clean it properly yet to check the extent of the damage. Iíll report back on what I find, from the photo I agree.
    The car is having some welding done soon so it will go on the list.
    cheers
    Craig
  2. #152
    1,360
    Quote Originally Posted by CEyssens View Post
    Nice pickup Justin!
    cheers
    Craig
    I had the same issue with the 306 cab. Just weld a plate over the top.
    Sent from my HTC One M9 using Tapatalk
    CEyssens likes this.
  3. #153
    1,496
    Nice big solid washer fits well and is easy to weld to!
    307 HDi wagon
    407 HDi wagon
  4. #154
    Jan 2016
    Berwick VIC AUS
    1,024
    The mount is definitely cracked, I didnít bother cleaning back the whole area as itís clear thereís work to do there.
    Nice new Bosch timing belt in and all the covers going back on. Yet again more bolts and nuts wrong or missing. Iíve spent a considerable amount of time just sorting out wrong or missing parts in this car.
  5. #155
    8,429
    And it looks like someone had a go at welding that crack before.
    I wonder what can possibly crack the body there and how? Looks like a fatigue crack, so possibly repeated flexing, but how, because a flexible rubber mount shouldn't transmit force.
    ACHTUNG ALLES LOOKENPEEPERS
  6. #156
    Jan 2016
    Berwick VIC AUS
    1,024
    I didnít see any old welding. Itís a rubber mount but itís still transferring load. Also once the buffers are worn the load on the bottom area is increased due to increased travel. Its certainly fatigue failure. Considering the strength of the mounts and loads in play that flat plate is in my opinion under designed.
    Also we donít know the history of this car, itís had some type of strut brace in the past and has modified suspension so has likely had harder than average use and acceleration and gear changes etc. all the mounts Iíve touched on the engine/transmission have been shot.
  7. #157
    1000+ Posts N5GTi6's Avatar
    1,087
    All 2 litre 306's will crack there as well. Just a design fault. Later models have MUCH stronger engine to chassis arrangements for that mount.
    Justin
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
  8. #158
    Jan 2016
    Berwick VIC AUS
    1,024
    Justin
    Cheers Justin, thanks for the feedback and input I definitely agree itís a weak point. Luckily an easy fix.
  9. #159
    Jan 2016
    Berwick VIC AUS
    1,024
    Default Little Silver 205GTI
    Another short stop to work on little silver and finally found all my bolts, nuts and washers to assemble the timing covers (some searching and parts nicked from spare engines)
    One thing Iíve been constantly challenged with on this car is finding all the right parts. These two bolts belong on the bottom of the lower timing cover that sit under the crank accessory belt pulley.
    All new belts and idlers (existing were all shot)
    Even the alternator belt tension adjuster was cactus and missing bolts.
    Fuel leaks finally fixed. I had to replace the washers supplied by BakerBM with the new fuel line and banjos as they wouldnít seal. New flat washers worked perfectly first go. Iíll have to email them.
    Car started so easily and ran smooth, nice idle.
    This is all a bit pedestrian Iím sure, however I feel that getting a project car going for some people with busy lives is a bit like this and can sometimes stall for what feels like an eternity. So I thought it good to share.
    Bit by bit Little Silver is coming back to life!
    Richard W, FIVEDOOR and moeozz like this.
  10. #160
    8,429
    You put the A/C belt the wrong way around the idler/tensioner. The lack of grooves in the idler should be a hint which way the belt goes around it.
  11. #161
    Jan 2016
    Berwick VIC AUS
    1,024
    ha, heck yes thanks schlitz good pickup... how did I miss that!?... looks like I may have been a bit tired last night
    phasselhoff likes this.
  12. #162
    Jan 2016
    Berwick VIC AUS
    1,024
    After a stringent review process I decided to revert back to the more ďconventionalĒ method of tensioning the AC belt
    Some other new parts that went in the other day
  13. #163
    Jan 2016
    Berwick VIC AUS
    1,024
    Lots more little items ticked off including the door lock & latch adventure. Filled with incorrect parts, faulty parts, bent and bodged parts, missing parts.
    Like this door handle link rod bent enough that it fouled the mechanism
    Easy fix
    But I only found that one as I had to pull a latch mechanism out as two other link rods were on backward and wouldnít function. Like the door exterior lock which I found didnít work because the plastic arm wasnít there and when I went to fit one I couldnít because the rod it connected to was on backward and badly bent. So many little things
    Even found and fitted lock gaskets!
    End result is all locks and latches are working very nicely. And original central locking fixed on drivers door and tailgate, just need to repair wiring on passenger door and that will be sorted also.
    How do cars get so badly stuffed with?!?!
  14. #164
    8,429
    Retards modifying them.
  15. #165
    Jan 2016
    Berwick VIC AUS
    1,024
    Moving out of the shed under its own power after more than six years of neglect
    Wow just a bit dirty
    Time for a quick shower
    Looks great from a few meters away
  16. #166
    1,087
    Time to get some Gtechniq C4 onto that plastic work.
    Lookin good !
    Justin
    '07 C3 Exclusive
  17. #167
    Jan 2016
    Berwick VIC AUS
    1,024
    Test drive farm style
  18. #168
    Jan 2016
    Berwick VIC AUS
    1,024
    Little Silver 205GTI has parted ways with me ending our journey.
    Off to its new home with a stop off at Grahamís workshop for some suspension work.
    See you on the black top Little Silver
    moeozz likes this.
  19. #169
    Oct 2003
    607
    Nice work! So many people just don't have the patience to repair a car in such detail.
  20. #170
    Jan 2016
    Berwick VIC AUS
    1,024
    Quote Originally Posted by Bluey View Post
    Thanks Bluey! Itís easy to underestimate whatís involved. Iíve done heaps and thereís still quite a bit for the new owner to do. Now Iím excited to get onto my next car in the queue
  21. #171
    Jan 2016
    Berwick VIC AUS
    1,024
    Update from Kosta, little silver is being prepped for paint.
    How good is that?!
    I reckon the pepperpots look great on little silver
  22. #172
    Mar 2005
    311
    How good is that! Those wheels do look great too.
  23. #173
    Jan 2016
    Berwick VIC AUS
    1,024
    Quote Originally Posted by Selekta View Post
    Definitely, I think the pepperpots really suit the silver GTI!
  24. #174
    Jan 2016
    Berwick VIC AUS
    1,024
    And out of the spray booth
    SilverGTi_6 likes this.
  25. #175
    1,496
    Lovely, mine will go in like this one for Vallelunga Red. Without front or rear window mind you.
    Nice work!
    307 HDi wagon
    407 HDi wagon
