Little Silver 205GTI - Page 6
Page 6 of 8 First ... 2345678 Last
Results 126 to 150 of 176
Like Tree71Likes
Thread: Little Silver 205GTI
  1. #126
    1000+ Posts CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    1,024
    Hi there CEyssens.
    I'm admiring your work here and your photos are so big and clear.
    Can you tell me how you can put such big photos onto aussiefrogs please. I'm restoring a 1963 Renault R8 and would love to share some pics with other restorers to.
    Phil
    Hi Phil,
    Thanks for your message, it's really good to see an old car get saved and satisfying to see it start to come together.
    I normally load up my images straight from my iphone using the Tapatalk forum phone app. I've used aussiefrogs phone app but had issues with it going off line.
    If I use the pc based web interface for aussiefrogs forum I load up an image with insert while typing a post. Then after I insert the image I normally see a very small version, so I double click on the image and an image settings box opens up, from there I can select a larger resolution format for that image (I usually choose medium or large size).
    Hopefully that helps, I'll look forward to seeing some pictures of your project soon.
    cheers
    Craig.
  2. #127
    Feb 2012
    Vista SA
    983
    Thanks Graig. I'll have a go a bit later, fingers crossed.
    Phil
    Quote Originally Posted by CEyssens View Post
    Hi Phil,
    cheers
    Craig.
    CEyssens likes this.
  3. #128
    Jan 2016
    Berwick VIC AUS
    1,024
    Does any one have a clamp that holds the fuel lines to the firewall, located just below the brake booster?
    Please let me know if you can help me out.
Name:	Fuel Pipe Clamp.jpg
  4. #129
    Apr 2014
    Orange
    358
    Sorry I don't have a spare one. Where is that diagram from it's awesome!
  5. #130
    Jan 2016
    Berwick VIC AUS
    1,024
    Quote Originally Posted by Warus View Post
    Hi Warus,
    I use this web page a lot:
    Peugeot Parts Catalogue
    Excellent for looking up part numbers and seeing how it should be put together. I have lots of pages printed and spiral bound for use while working on the car, especially around all the water, oil and vapor hoses. Results for me were that the engine starting first try and is running smoothly all after having to put back every hose.
  6. #131
    1,496
    Ah well my luck took a turn today, whilst cleaning up in amongst the leftovers pile (what maggot left of my car) guess what I found?
    Cleaned it up and fitted it, hooray. Pipes still very close to those extractors!
    307 HDi wagon
    407 HDi wagon
  7. #132
    Jan 2016
    Berwick VIC AUS
    1,024
    Quote Originally Posted by Matthew View Post
    What you didnít find two?! ha, oh well Iíll keep searching, nice work on finding yours, cheers
    Ps howís the dash in your red car going?
  8. #133
    1,496
    Sadly no, if i had and logically enough I inherited a few bits from others cars, multiple front bumper mounts if they are any use?
    Slowly, top is done just need to get the bottom half fixed. Some more discrete fibreglass required.
    307 HDi wagon
    407 HDi wagon
  9. #134
    Jan 2016
    Berwick VIC AUS
    1,024
    thanks Matt, it was a bit tongue in cheek on asking if you had another... good to hear you found yours. Not sure on the bumper mounts, I'll be refitting mine soon so I'll check.
  10. #135
    Jan 2016
    Berwick VIC AUS
    1,024
    Update!
    Drive shafts torqued up with new torque wrench (happy)
    Door latches out for repair or replace and then sort out possessed central locking
    Now that it starts first go and runs smooth I'll do the timing belt, tensioner, shaft seals, water pump, water wing pipe and RHS hoses.
    After an extremely busy couple of months and more busy ahead I'm changing tack and making the effort to get to the workshop a couple times a week even for just an hour at a time.
Name:	Dr Evil Torque Wrench.jpg
  11. #136
    Jan 2016
    Berwick VIC AUS
    1,024
    Thereís something satisfying about removing a crusty dodgy part and fitting up an excellent condition original replacement onto a project car like this S1 steering wheel
  12. #137
    Jan 2016
    Berwick VIC AUS
    1,024
    Default Little Silver 205GTI
    Some updates
    Some more wheels back on
    The lock puzzle continues, all parts cleaned up, some replaced, some were missing or poor bodged items. Now getting it back together.
    Looks like the aftermarket immobiliser has itís central locking piggybacked onto the factory central locking, just deciding what to do about that. Start will be having all the factory equipment working.
    Prep for timing belt uncovered broken top engine mount.
    So the hot tip, if you are thinking of fancy mounts and havenít replaced or checked the old ones, maybe just new ones will be a vast improvement. This car has needed every mount changed with this one obviously the worst!
    Coolant pipe in poor shape, very thin in areas around where the hoses go on.
    Good to get a couple of hours in, all the timing gear came out without a drama, so next visit should see some new parts going back in.
    Codman and Matthew like this.
  13. #138
    1000+ Posts Richard W's Avatar
    May 2012
    1,317
    I'm not sure if the phase 1 control box will be the same, but somewhere I have wiring diagram for my phase 2 central locking where I worked out what terminals to use to allow the aftermarket immobiliser to trigger the factory central locking. Will see if I can find it. It works well.
    Sent from my BBB100-1 using Tapatalk
  14. #139
    Jan 2016
    Berwick VIC AUS
    1,024
    Quote Originally Posted by Richard W View Post
    Thanks Richard, that sounds very helpful. Whoever did this to little silver put an additional central locking solenoid in the drivers door piggybacked off the factory one to simulate what happens when you turn the key. It must be out of adjustment or worn and just a bad idea as last time I tried to use it, it kept triggering itself up and down like a yo-yo! now I know why, but at the time it was pretty funny to watch.
  15. #140
    May 2012
    1,317
    Can you post a photo of your control module so I can see if it is the same? If it is, it will be mounted to the underside of the steering column, piggybacked on the lower column mount.
  16. #141
    Jan 2016
    Berwick VIC AUS
    1,024
    Meanwhile over at the tyre shop
    Hankook R-S4 $415 fitted and balanced
    gezza and moeozz like this.
  17. #142
    1000+ Posts gezza's Avatar
    Bunbury
    2,180
    Nice cant beat the 15s on a gti
    1990 Renault 5 GT turbo
    ####current rides####
    1994 205 gti 1.9 sorento green
    1988 205 gti 1.9 uk import grey
    2001 clio 172 sport ph1 #44/85
    1998 306 gti6. Blaze yellow
    1992 Honda Fireblade
    2013 Yamaha fzs sho Jetski
    1998 Supra RZ twin turbo white
    1999 Wrx classic gc8 sonic blue
  18. #143
    May 2012
    1,317
    My notes suggest that wire carrying the "unlock" signal into the central locking controller module from the remote receiver is numbered 203, and the wire carrying the "lock" signal is numbered 204. On my car I removed those wires from the controller down near the steering column and connected up the 'lock' and 'unlock' signals from the immobiliser instead and, hey presto, the remote control on the immobiliser now controls the factory central locking.
    A phase one 205 never had remote central locking in the first place so maybe it won't have those same wires and terminals?
    I've got a spare phase 2 central locking controller box here that does have the right terminals if that would be any use.
    Here's a diagram for the wiring for the controller. I can also scan and sent my translations but it's pretty rough: http://aws-cf.caradisiac.com/prod/me.../boitie101.jpg
  19. #144
    Fellow Frogger! moeozz's Avatar
    Jul 2012
    melb
    242
    Very nice. Have they been refurbed because they look great!
    current S1 205 GTI + S3 306 GTI6
    previous s2 306 GTI6
  20. #145
    Jan 2016
    Berwick VIC AUS
    1,024
    Hi Richard,
    Thanks that is quite helpful, it definitely doesn't have the original remote central locking, I'll have a look and see if I can patch it in without adding the factory remote module as then the imobiliser can be retained. If not maybe I'll be in touch about that spare module you have.
    It's always so helpful to hear other peoples experiences as it can take some time to troubleshoot properly.
    cheers
    Craig
  21. #146
    Jan 2016
    Berwick VIC AUS
    1,024
    Quote Originally Posted by moeozz View Post
    Yes Moe, the new owner of Little Silver had them painted, they look very nice!
  22. #147
    Jan 2016
    Berwick VIC AUS
    1,024
    Lucky the broken mount stud came out easily.
    BIGRR and phasselhoff like this.
  23. #148
    Jan 2016
    Berwick VIC AUS
    1,024
    Top mount buffers definitely due for a freshen up
  24. #149
    1,496
    Use a 306 buffer, one piece and a lot simpler?
    307 HDi wagon
    407 HDi wagon
  25. #150
    1000+ Posts N5GTi6's Avatar
    1,087
    Looks like a crack in the bottom of the mount socket - you need to plate that and weld it up.
    Justin
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
