Little Silver 205GTI - Page 5
Page 5 of 5 First 12345
Results 101 to 113 of 113
Like Tree25Likes
Thread: Little Silver 205GTI
  1. #101
    Fellow Frogger! CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    836
    Quote Originally Posted by Richard W View Post
    It's going to be good! It's hard to clean things up once its all assembled again. I'd be using some soft wire brushes on drill and Dremel to clean up the cam cover, inlet manifold and visible parts of the head now before its all reassembled.
    And don't let any of the cognoscenti see that you fitted a Ryco filter instead of a Purflux...
    Thanks Richard, yes I'm figuring it will be a good little goer! Ryco, cognoscenti, pff... care not, they would likely have parted her out and sent her silver pealing french steel to get melted down and made into widgets. I even used cheap oil from supercheap to do an initial short run oil change "crazy!"
    I must say I do enjoy taking dodgy parts off a car and returning it back to how it should be, it's very satisfying. This car has a matching number engine, and all the original missing or modified parts have been sourced except for a one last dash part. With a new paint job this little silver GTI will be a sweet car.
    Richard W likes this.
  2. #102
    7,665
    Quote Originally Posted by CEyssens View Post
    seal done while box out and flywheel off, not interested in doing that twice
    So you've done it already?
    CEyssens likes this.
    ACHTUNG ALLES LOOKENPEEPERS
  3. #103
    1,137
    One last dash part may be a reality, lot better than lots of pieces! One bad break to repair only on end under drivers end. Glovebox is a treat! Lock will come out again to match mine so keep the lock for yours. Now to get it to you. Its a shade of black too, sorry!
  4. #104
    8,305
    Far better to use Purflux filters, better quality, cheaper and you can remove them easily by using the special tool.
  5. #105
    Jan 2016
    Berwick VIC AUS
    836
    Quote Originally Posted by Matthew View Post
    Thanks Matt, sounds like an amazingly generous offer, please send me some photos over email so I can tease the driver! Black, did you paint it as part of your repairs?
  6. #106
    Jan 2016
    Berwick VIC AUS
    836
    that's correct it was replaced along with the gearbox input shaft seal and both driveshaft seals
  7. #107
    Jan 2016
    Berwick VIC AUS
    836
    Thanks Graham, I appreciate the advice, most of my comments are a bit tongue in cheek... I do like the removal tool, although I've never had an issues getting filters off. This filter is only going to be used for a few runs so I'll see about the purflux for the the next oil change. Do you get yours from EAI or ebay?
  8. #108
    1,137
    Yes coloured it, might be removeable. It was out of one of magdicks cars which was a different colour to mine he pinched the winder plugs they were black and the dash and all its contents.
  9. #109
    Jan 2016
    Berwick VIC AUS
    836
    A little tinkering today.
    Removed dodgy wires from previously mentioned possible fuel pressure switch. It was likely a water sensor on aftermarket water separator/filter now also gone.
    Inlet manifold cleaned up a bit, crickey it was covered in crud, a small puddle draining out of the plenum
    Looking a bit more complete
    And the pie was excellent
    PeterT likes this.
  10. #110
    1,137
    Will dig out the central aircon duct fitting today and send it to Melbourne! East Hawthorne? Anything else small?
    Nice work coming together.
  11. #111
    Jan 2016
    Berwick VIC AUS
    836
    Thanks Matt.
    What are you referring to with the central duct?
  12. #112
    1,137
    The central air output you asked for? Air con duct that fits into dash?
  13. #113
    Jan 2016
    Berwick VIC AUS
    836
    Hi Matt, I think Iím a bit confused, could you please send me a photo?
    cheers
