Little Silver 205GTI - Page 4
Page 4 of 7 First 1234567 Last
Results 76 to 100 of 170
Like Tree68Likes
Thread: Little Silver 205GTI
  1. #76
    Fellow Frogger! CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    963
    Itís really good to be back on the tools and making some progress on this car. The unfortunate reality of project cars at times can be lots of idle time due to other life commitments.
    Only a couple of hours today but good progress made
  2. #77
    Jan 2016
    Berwick VIC AUS
    963
    Another couple of hours on Sunday morning.
    wishbones separated from struts, driveshafts out, all items off the gearbox except for the reverse gear selector cable.
    So next spanner time the box will be out.
    I'm happy to not have found any surprises yet.
    Body underneath looks very good except for some minor poor jack use damage.
    Gear oil was very clean.
    Inside inlet manifold and head ports look very clean, and gaskets look fresh, I'm wondering if the head has been done at some stage.
    Radiator looks quite new, front brakes look good, all suspension bushes look good and tight. All boots are in good condition steering, ball joints and driveshafts. steering light as a feather!
  3. #78
    Jan 2016
    Berwick VIC AUS
    963
    Default Little Silver 205GTI
    Box out and turned out that the thrust bearing definitely was the culprit of the loud noise, so very happy to have found that. Checkout the pressure plate fingers!!
    Not so happy with the flywheel tooth missing, but thatís sorted thanks Graham good parts trade
    A good clean up is in order and back together. I have all my bits including machined flywheel so happy days!
  4. #79
    1000+ Posts Isis's Avatar
    1,092
    Good work mate. Perhaps give the engine bay a bit of paint while you have the chance?
  5. #80
    Jan 2016
    Berwick VIC AUS
    963
    Thanks Ash, I'll clean up best I can but unfortunately wont have time to paint the engine bay. Hopefully the car gets a full paint job in the near future. I'll have to put an update up with some more pics
  6. #81
    Jan 2016
    Berwick VIC AUS
    963
    Update on work from Sunday
    Box back in, now to reassemble, fully eliminate the hydraulic clutch and put back all the original spec clutch parts, pedal, cable and linkages... little silver is feeling happier already
    Happy days
  7. #82
    1000+ Posts N5GTi6's Avatar
    1,061
    Wow - that 18YO pressure plate has been waiting a while for it's turn ! Aren't push type clutches wonderful ! The BE3/6 in my GTi6 was a bugger......
    Justin
    '07 C3 Exclusive
    '09 308 XSE Touring
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
  8. #83
    Jan 2016
    Berwick VIC AUS
    963
    Quote Originally Posted by N5GTi6 View Post
    Justin
    Hey Justin, yeah the pressure plate was finished, clutch was fine but check out the thrust bearing, totally stuffed, seized and the inner collar was in a right mess. I donít think it had done much work by the look of the clutch plate. What issues did you have wit the gti6?
  9. #84
    1,061
    Quote Originally Posted by CEyssens View Post
    Hey Justin, yeah the pressure plate was finished, clutch was fine but check out the thrust bearing, totally stuffed, seized and the inner collar was in a right mess. I don’t think it had done much work by the look of the clutch plate. What issues did you have wit the gti6?
    The 'pull' type clutch on the be3/6 is just tricky to engage when you're reinstalling the gearbox because you have to hook the clutch fork in behind the release bearing as you slide the gearbox back onto the engine. Maybe just tricky doing it by myself - might have been easier with another pair of hands.
    Justin
    '07 C3 Exclusive
    '09 308 XSE Touring
  10. #85
    Jan 2016
    Berwick VIC AUS
    963
    Ah the serenity
    SilverGTi_6 and Isis like this.
  11. #86
    Jan 2016
    Berwick VIC AUS
    963
    Lots of small details getting done
    Gearbox back on its (not so rusty anymore) mount
    AFM inlet replaced
    Bent and damaged AFM bracket replaced
    Dodgy clutch pedal that was modified for the hydraulic clutch now replaced
    BE1 missing clutch link arm sorted out inc new bushes
    Lots of old hoses replaced
    Missing ignition lead tray sorted out
    Richard W and Isis like this.
  12. #87
    Apr 2014
    Orange
    349
    Damn she looks so similar to mine. Keep going it might motivate me.
    CEyssens likes this.
  13. #88
    Jan 2016
    Berwick VIC AUS
    963
    Oh and I got this in the mail recently and it even turned up in one piece!
    Now just to find the other S1 dash parts in this condition (I know crazy right?!)
  14. #89
    Jan 2016
    Berwick VIC AUS
    963
    Quote Originally Posted by Warus View Post
    Thanks Warus!
    How is your project coming along? I stopped past the thread but couldnít see the pics.
  15. #90
    Jan 2016
    Berwick VIC AUS
    963
    So I forgot to mark the flywheel TDC before I put the gearbox back on.... oops
    Thanks to Taylor Eng for the helpful diagram
    http://www.taylor-eng.com/xu9j4/finding_tdc.html
    A little tricky when assembled but all sorted now
  16. #91
    Jan 2016
    Berwick VIC AUS
    963
    Fuel Pressure Switch?? Has anyone ever seen a fuel pressure switch on their 205 GTI?
    I'm figuring the answer is no, but thought to ask in case I'm off the money on this.
    I've removed the aftermarket bodged fuel filter and it's got a two wire switch on the bottom, I'd say its a pressure switch, but no idea yet what it connects to.
  17. #92
    8,067
    I think it was the Si that had some sort of safety fuel cutoff if that is what you're asking.
    ACHTUNG ALLES LOOKENPEEPERS
  18. #93
    Jan 2016
    Berwick VIC AUS
    963
    Thanks, I donít think so, itís on a S1 GTI but the car has been subject to some meddling.
  19. #94
    8,067
    Some Euro models had that safety feature as well. You can see it in the wiring diagrams. It was a resettable switch on the inner wing, don't remember which side. I think it killed the pump in the event of a collision.
  20. #95
    Jan 2016
    Berwick VIC AUS
    963
    Snuck in an hour on the tools today
    Dusted off the driveshafts and popped them back in. Finished off the clutch cable and linkages work. Deleted the oil cooler and fitted the new filter in the remote location. And prepped inlet manifold ready to go back in.
  21. #96
    8,067
    Your engine needs a wash.
    BIGRR likes this.
  22. #97
    Jan 2016
    Berwick VIC AUS
    963
    It certainly does... leaky rear main among other leaks and lots of years of not being cleaned.... everything that's touched is getting a freshen up and it will get a big clean once it's running again.
  23. #98
    1000+ Posts Richard W's Avatar
    May 2012
    1,283
    It will get a big clean once it's running again.
    It's going to be good! It's hard to clean things up once its all assembled again. I'd be using some soft wire brushes on drill and Dremel to clean up the cam cover, inlet manifold and visible parts of the head now before its all reassembled.
    And don't let any of the cognoscenti see that you fitted a Ryco filter instead of a Purflux...
  24. #99
    8,067
    It's going to be a pig to change the main rear seal after you put the 'box back in. Why not do it now?
    I would suggest you leave the rest dirty until you have it all assembled and then make sure it starts and runs very well.
    Then use a high pressure washer to take all that grime off then check spark plug tubes (blow water out with compressed air) and dizzy (wipe it dry inside and out or use tons of alcohol sprayed on it), then start the engine and take the car for a drive to dry everything thoroughly in the engine bay.
    Try to avoid washing the connectors, even though Bosch type should be water tight. A light spray won't harm them.
  25. #100
    Jan 2016
    Berwick VIC AUS
    963
    seal done while box out and flywheel off, not interested in doing that twice
