Little Silver 205GTI - Page 2
Page 2 of 8 First 123456 ... Last
Results 26 to 50 of 177
Like Tree71Likes
Thread: Little Silver 205GTI
  1. #26
    8,698
    You need to be nicer to her, otherwise it will lock you out more often and ultimately you will sleep in the garage.
    Smash a window to show her who's boss, I say.
    ACHTUNG ALLES LOOKENPEEPERS
  2. #27
    1000+ Posts CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    1,042
    I like to think it's her way of showing me what needs fixing
  3. #28
    1000+ Posts Richard W's Avatar
    May 2012
    1,336
    Quote Originally Posted by CEyssens View Post
    Officially "Little Silver 205GTI" has locked me out!
    The central locking is arguing with the door lock and at times doing an up/down dance.
    Does anyone have any advice how I might be able to get in?
    I didn't think that the passenger doors normally had a 'master' switch for the central locking, just a slave - ie, you should be able to turn the key on the passenger side without triggering a central locking fight? If not, can you not unlock the hatch and get in that way? Not very dignified, but do it when no-one is looking.....
  4. #29
    Jan 2016
    Berwick VIC AUS
    1,042
    Quote Originally Posted by Richard W View Post
    Thanks Richard,
    I think it's a bit more sinister, the tail gate lock would only turn to the lock direction and the doors are both only allowing the lock to turn half way open and if I try the drivers door it has a hissy fit.
    I just fiddled a bit with the tailgate and managed to open it. Reached in and same thing with the internal door latches they just go up half way.
    Maybe one is jammed causing the issue????
  5. #30
    Jan 2016
    Berwick VIC AUS
    1,042
    Well I managed to get in so all good for now, but she's definitely giving me a message that the door mechanisms need some TLC.
    Same goes for this highly accurate dipstick!
  6. #31
    Fellow Frogger! EvilElmo's Avatar
    Jan 2016
    nsw
    612
    Have a look at the rubber mounts for the door lock motor. The ones on my si are worn out, which lets everything flex just enough to stop the lock opening...
    And go to the wreckers and get another dipstick!!
  7. #32
    Feb 2013
    Sandringham/Victoria
    462
    Yep, you really need a sealing dispstick for the EFI to run properly so if you get a 2nd handy, by sure it seals properly.
    Quote Originally Posted by EvilElmo View Post
  8. #33
    8,698
    Thanks Richard,
    Knowing these bartstards, I would suggest you check the wiring of the locking system. I wouldn't be surprised if something was amiss trying to keep locks in the lock state. Say a wire shorted or some such. Unplug motors one by one and see if the rest work or just unplug all from the car and connect an independent power supply to the motors directly and see what happens.
  9. #34
    Jan 2016
    Berwick VIC AUS
    1,042
    Thanks for all the advise, I'll have a good look at the door lock solenoids and keep those things in mind.
    And I've ordered two new dipsticks... Two GTIs two stuffed dipsticks....
  10. #35
    Jan 2016
    nsw
    612
    I just replaced the torn up grommets on my passenger door lock actuator with some healthier looking spares and it seems to be working properly for the first time ever!
    However, the true test will be when it has to let my wife in...
    CEyssens likes this.
  11. #36
    Jan 2016
    Berwick VIC AUS
    1,042
    Cleaned up and straightened the fuel filter bracket I sourced all ready to go just need my banjo fittings now
  12. #37
    1,630
    You can have my old top one, no bolt mind you, going to 8mm, onto evilbay you go, 14mm banjo bolt!
    307 HDi wagon
    407 HDi wagon
  13. #38
    Jan 2016
    Berwick VIC AUS
    1,042
    Quote Originally Posted by Matthew View Post
    Hey thanks Matt, I've got some on the way so I'll pass but thanks very much for the generous offer.
    M12 for the top and M14 for the bottom of the filter
  14. #39
    1,630
    no problem, enjoy! How did you get that bracket so clean? Mine of course was nicked and I sourced a replacement.
    307 HDi wagon
    407 HDi wagon
  15. #40
    Jan 2016
    Berwick VIC AUS
    1,042
    I used a vinegar solution, a bit old school you just need to be careful as it can take off the plating and you also need to neutralise it. I just go with a weaker solution and more time so I don't go too far.
  16. #41
    1,630
    Vinegar takes off CAD plating? Need to know if this is true, i have a need for about 1m of it gone.
    307 HDi wagon
    407 HDi wagon
  17. #42
    Jan 2016
    Berwick VIC AUS
    1,042
    Ha, I've never used it to strip coatings but go for it, there's probably oodles on googles about it... maybe some other more aggressive potions out there?!?
  18. #43
    8,698
    What plating is that?
  19. #44
    Jan 2016
    Berwick VIC AUS
    1,042
    I think Matt is referring to cadmium plating
  20. #45
    Jan 2016
    Berwick VIC AUS
    1,042
    Got the right wheel, very nice and ready to go on, I'm definitely happy with that.
    SilverGTi_6 likes this.
  21. #46
    Jan 2016
    Berwick VIC AUS
    1,042
    Default Little Silver 205GTI
    Update, while stripping down and cleaning induction parts, replacing the split air ducts and found that the AFM inlet flange is stuffed, someone has glued it and packed it with a supporting ring. The old repairs are cracked so not far off coming away and venturing into the engine.
    So two cars now and same issue this must be common, over zealous work on the hose clamps! lucky I've got one to replace it.
  22. #47
    Apr 2014
    Orange
    364
    I probably have 1 if you need another.
  23. #48
    Jan 2016
    Berwick VIC AUS
    1,042
    Quote Originally Posted by Warus View Post
    Thanks Warus,
    I have two spares I'll have to check that they are both usable. If not I'll take you up on that.
    cheers
  24. #49
    8,698
    My guess is that people try to tighten the hose clamps down as the rubber falls apart and the plastic starts squashing and eventually cracks. Found the same problem on mine but fixed it with a very thin ring of steel placed inside the plastic. I think by now these plastics are old and start breaking down anyway losing their elasticity so even a good one might end up the same in a short time. Keep an eye out for a suitable aluminium flange for DIY turbo mods available in most parts shops.
  25. #50
    Jan 2016
    Berwick VIC AUS
    1,042
    I agree over tightening and no idea what's breaking inside as you can't see it and maybe the plastic was old or just heavy hands.
    Alloy turbo flange sounds interesting, I'd knock one up, but my time is lean with work and we have two toddlers so I'm going for mainly bolt on repairs at the moment.
