405 mi16 power abs.. how do i bleed ???
Results 1 to 11 of 11
    May 2012
    uk
    13
    Default 405 mi16 power abs.. how do i bleed ???
    any advice on this would be great, thnxs ppl ......
    May 2012
    uk
    13
    its one of them things, i been looking for months, but no luck, only way i did find needed 5 ppl, lol
    1000+ Posts cav91's Avatar
    Sunbury, VIC
    2,267
    A vacuum pump bleeder and bleeding on each caliper always worked for me.
    406 D8 V6 manual
    7,414
    Bendix or Bosch?
    tweed heads
    1,471
    The rear calipers wont bleed unless there is weight on the trailing arm ,so the proportioning valve operated by movement of the suspension is open ,allowing fluid flow .pugs
    Don't remind me!
    16,609
    Bendix or Bosch?
    This is the crux of it! I don't think most here would have encountered the Bendix type ABS. It seems quite similar to that used on some newer 4WD cars though...
    All ABS are fail safe designs, worst case you disconnect the battery, safety wire the limiting valve temporarily open and start bleeding from the wheels up.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    525
    Bendix or Bosch?
    In Australia the early Bendix cars were all recalled and the cars fitted with Bosch ABS under warranty.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    7,414
    Correct, but MI16X4 is in the UK.
    May 2012
    uk
    13
    thnxs, but its the bendix version....
    May 2012
    uk
    13
    it was working fine, but i had to replace the rear brake hoses,for mot, and now the brakes work, but not like they shuld ...
    Don't remind me!
    16,609
    Bleed, bleed, bleed again. Does it have a limiting valve on the rears?
