R8 Restoration project
Results 1 to 16 of 16
Like Tree4Likes
  • 3 Post By Brianbcs
  • 1 Post By R8 Dream
Thread: R8 Restoration project
    Traralgon,Victoria
    205
    Default R8 Restoration project
    It's been a while since I updated the progress on the R8 G replica project. The whole gearbox/axle/trunnion seal thing has been done to death on a previous post.The Fiat brake conversion took much longer than anticipated due to sourcing the bits,this is now completed apart from o'hauling the calipers.
    So yesterday,despite a bloody hot day here in Traralgon,with the help from son Damo we managed to marry the transaxle assembly to the body.I know there have been previous posts on how to do this but our method involved jacking /hoisting the body to a height sufficient to clear the shocker towers.. 600mm I think..sliding the transaxle under the body,then simply lowering it down onto the transaxle.We had two Super Cheap hydraulic jacks under the axles and blocks of wood at the front of the box and a combination of jacking and lowering had the entire thing bolted up in 1/2 hour! Very smooth sailing! The "turfer" hoist only really served the purpose as backup as I didn't have a lot of confidence in the shed trusses.The pics will show it all.
    So a very exiting stage as the R8 is on her feet again and the project can only move forward from here!!
    Cheers BrianR8 Restoration project-p1100367.jpgR8 Restoration project-p1100368.jpgR8 Restoration project-p1100369.jpgR8 Restoration project-p1100371.jpg
    R8 Dream, JohnW and J-man like this.
    Fellow Frogger! Paul T's Avatar
    Mar 2012
    Bathurst, NSW.
    263
    Looking good Brian.
    Are you using the Longer R8G axle straps or the shorter A110 ones? I used the shorter A110 ones and one failed at the bolt hole. Getting some longer strap this week.
    Paul.
    Paul Tomlinson
    R1135 Gordini 1968.
    Jaguar XJ-C V12 1975.
    Alpine GTA- ATMO 1987.
    Jaguar X Type 2002.
    Traralgon,Victoria
    205
    That's interesting Paul as mine are the short ones also.They are certainly short...needed a lot of effort to fit up without any weight on the axles! I bought them from Meca.Will be keen to hear how your longer ones work out. Brian
    Fellow Frogger! rubyalpine's Avatar
    Christchurch, New Zealand
    470
    Galvanised chains are sometimes used. If you cut them a bit long, that allows them to be adjustable, and if you insert them in some old bicycle tubing, they won't rattle. Don't forget to cut/drill a couple of small holes in the tubing, at the lowest point, for water to drain out.
    Henry
    When I find my feet,,,,,,,,,,,,,,I'll know where I stand!
    4,352
    I bought some industrial belting offcuts from a place in seven hills and made my own.
    Looks very much the original Gordini ones I've been told - about twice as wide as the R1130/1132 ones.
    I have no idea what the genuine ones look like though.
    KB
    630
    Likewise I used some conveyor belt material cut to 50mm wide. I based mine on the Mecapart lengths.
    Attachment 80561Attachment 80562
    J-man likes this.
    4,352
    Yep, same stuff. Mine might be a little more Orange in colour than yours, or it could just be your flash.
    KB
    10,679
    All looking very nice!
    Does anyone know, to raise an old chestnut, why the weights on the trailing arms are bolted on where they are bolted on? I'd always assumed it was to kill a resonance, noticed and fixed about a week before the car was on sale.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Traralgon,Victoria
    205
    Yeah John,I am in the process of restoring mine and have been careful not to alter the position of the weights for the same reason..not really knowing if it matters!
    Mar 2012
    Bathurst, NSW.
    263
    Quote Originally Posted by Brianbcs View Post
    Hi Brian,
    I also got mine through Meca. They only had the shorter Alpine ones which I fitted and one broke at the bolt hole.
    The Alpine straps are 335mm long and the R8 Gordini, R8 and R10 are 395mm, quite a difference.
    The straps supplied by meca are made from transmission belt and I couldn't get any locally, so I went to our local hydraulic hose business and bought a 5m roll of Conveyor belt the same dimensions for $10.00 and made 2 new ones as in the photo. From what I have been told the conveyor belt is stronger than transmission belt. Got plenty left over if I break any more.
    I also painted the black conveyor belt with beige vinyl paint to match.
    Good luck,
    Paul.
    Paul Tomlinson
    R1135 Gordini 1968.
    Jaguar X Type 2002.
    Traralgon,Victoria
    205
    Thanks Paul, I know I can get conveyor belt locally so will give it a go. Whilst I think of it and on a different topic, does anyone know if the fuel sender unit as fitted to the front tank of an 8G is the same as an R4 unit?
    4,352
    The tank itself is an R4 tank, my guess would be yes.
    KB
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,599
    12 Volts !!!!!!
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Traralgon,Victoria
    205
    12 volts..good point Ray!
    Dec 2015
    Warrawee NSW
    58
    Voltage won't matter.
    The sender unit is a variable resistor so just varies the voltage passed with fuel level.
    The gauge unit is the voltage dependent part.
    Traralgon,Victoria
    205
    Ok, thanks for clarifying that ! It would seem the senders are easy enough to obtain o'seas.
