205 Gti to VST Motor Trans Swap
    Nov 2015
    17
    Default 205 Gti to VST Motor Trans Swap
    Hello, I am looking at up specking my 205 Gti as have a donor car a Citroen VST, is there any one that has attempted this in short the electrics is my major concern?
    902
    I assume you mean Citroen VTS (Xsara or C4?)
    I suggest you do a bit more searching, first thing is to figure out which engine and gearbox you're planning to use, XU or EW series, and the variant.
    Once you know which engine, you will find a huge amount of info both here and other forums about the engine swaps into 205's. You can then start a special thread with specific questions. The answer to both your questions so far is: Yes.
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, PeugeotSport Baffled Sump, Oil cooler, Quaife LSD, E85.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    Phillip Island - 1:55.9
    NŁrburgring - 10:23.ish (Fiesta ST)
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    Nov 2015
    17
    It is a Xsara VTS
    Fellow Frogger! 1pugnut's Avatar
    wollongong
    442
    The xsara is a good donner car to use,
    The motor and gearbox to start with, also the front and rear brakes the steering rack the front springs and rear shocks will all fit in the 205.
    The xzara computer is not compatterble, your cheapest option is buy a unlocked ecu out of a 306 gti 6 and a modified 306 gti6/205 gti wiring harness. But you must tell them it's going on to a xsara motor not a 306.
    You will have a lot more hassles than the wiring, you will also have to get rid of the a/c.
    Regards Jamie
    series 2 405 mi16
    205 si
    series 1 205 gti
    series 3 205 with a gti6 motor project
    1970 404 ute 504 ti motor project
    parts cars 2 205 si's 306 sedan
    2004 206 gti180
