DS21 Safari restoration
Results 1 to 12 of 12
Like Tree14Likes
  • 6 Post By Balki
  • 3 Post By Balki
  • 3 Post By Balki
  • 1 Post By daffyduck
  • 1 Post By Balki
Thread: DS21 Safari restoration
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    614
    Default DS21 Safari restoration
    I thought i better start a thread about the resto of my safari, in my other post i started a discussion on the engine rebuild and modification which is under way and currently still at the machine shop, so i have got in and removed all the flooring and tar based deadener, rust convertered the surface rust and painted the floor with wattly DTM985 which is an awesome product, its bascially a 2 part epoxy high solid surface tolerant paint that even brake fluid wont touch if left submerged for months, i then put resomat from front to back taped the joins and put ezy cool heat insulation on seat box front floor and fire wall, im hoping this should keep me cool, i removed the aircon unit as a friend who does ac systems is going to modify it to take late model oring fittings and a better tx valve, i wil refit it and use a modern compresser with new hoses, over the heat insulation i have some underfelt that has a polyurethane suspended layer in the middle to make the car event quieter, enjoy the pics, i will post more when i get more work done, the pictures of the fuel tank show how much dust there was, under the tank was full with a perfect inprint of the tank in the dust, there was a spot of rust under it which was a relief, oh and the little helper is my daughter Celeste
    DS21 Safari restoration-38.jpgDS21 Safari restoration-40.jpgDS21 Safari restoration-41.jpgDS21 Safari restoration-42.jpgDS21 Safari restoration-35.jpgDS21 Safari restoration-37.jpgDS21 Safari restoration-44.jpgDS21 Safari restoration-45.jpgDS21 Safari restoration-46.jpgDS21 Safari restoration-49.jpgDS21 Safari restoration-51.jpgDS21 Safari restoration-img_0929.jpgDS21 Safari restoration-47.jpgDS21 Safari restoration-48.jpg
    David S, dishaka, JohnW and 3 others like this.
    Los Angeles, CA USA
    1,955
    Yes!!!!!
    16,295
    Nice! You'll be pleased with the heat and sound reduction by insualting it. My '63ID19 without a roof on it is Wwwwwayyyy quiter than the same car in the colour blue with a roof fitted...
    Is that a spray paint, or can you roll/brush it on
    Sheffield/Tasmania
    614
    you can roll it on spray it, or brush it, i brushed it as it flowes nicely and you can put on a thicker coat in one go and push it into all the nooks and crannies
    Fellow Frogger! Lasya's Avatar
    Jan 2015
    A comfy place.
    319
    And the BEST little helper there is!
    Gillian and Chris
    74 D Special, and now a 74 Pallas 23 5 speed with air(maybe). And now a Cactus!
    Oh, and a Holden.
    Lasya, Tibetan goddess of the moon and beauty who carries a mirror.
    Sheffield/Tasmania
    614
    found some pictures on my camera of the work I did on it late last year, this included removing the roof and sorting roof rail rust, paint stripped and repainted roof in two pak, fitted reduction starter, heavy duty battery leads, powder coated air filter housing and battery tray alternator brackets etc, new water pump, new thermostat, new suspention boots all round and new bump stops, rebuilt the steering rack, fabricated stainless exhaust, two paack painted the wheels, rebuilt the spheres, replaced upper and lower ball joint dust boots, fitted grease nipples to all the steering ball joints, 123 ignition, VN commodore alternator with built in reg, refitted roof using sikaflex so now its sealed for life, found the roof wrack fitted perfectly on the xantia to take it in to my work for polishing
    DS21 Safari restoration-88.jpgDS21 Safari restoration-89.jpgDS21 Safari restoration-90.jpgDS21 Safari restoration-91.jpgDS21 Safari restoration-92.jpgDS21 Safari restoration-93.jpgDS21 Safari restoration-98.jpgDS21 Safari restoration-99.jpgDS21 Safari restoration-100.jpgDS21 Safari restoration-101.jpgDS21 Safari restoration-102.jpgDS21 Safari restoration-img_1723.jpgDS21 Safari restoration-img_1725.jpgDS21 Safari restoration-104.jpg
    Dano, JohnW and dishaka like this.
    Sep 2013
    Elphinstone Victoria
    535
    Drool. I'm newly inspired.
    SF
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    330
    Like the photo of stripping the paint off the roof, brings back memories for me. I did the same years ago with paint stripper and lots of elbow grease, it's a huge surface area to prep. Then I went to the local paint shop and said if I bring you my car roof and a couple of other bits that I've prepped will you paint it for me. They thought I was a bit odd, but we agreed a price and I turned up in the Safari with the roof in the back hanging out the tailgate! I then undid the tailgates and left it all with them, they painted it (midnight blue) and we drove around in the fresh air for a few days!
    Sheffield/Tasmania
    614
    making some more progress on the interior while waiting for the machine shop to finish engine parts
    DS21 Safari restoration-56.jpgDS21 Safari restoration-57.jpgDS21 Safari restoration-58.jpgDS21 Safari restoration-59.jpgDS21 Safari restoration-60.jpgDS21 Safari restoration-61.jpgDS21 Safari restoration-62.jpgDS21 Safari restoration-63.jpg
    Lasya, Boyracer and UFO like this.
    Los Angeles, CA USA
    1,955
    Did you happen to find carpet clips? Everybody needs some of those.
    Lasya likes this.
    Sheffield/Tasmania
    614
    you mean the clips sewn onto the carpet, mine were still good so reused them
    Lasya likes this.
    Los Angeles, CA USA
    1,955
    Quote Originally Posted by Balki View Post
    Yes. Most of those are now wasted.
