Peugeot 404 Utility Project - Page 9
Page 9 of 9 First ... 56789
Results 201 to 213 of 213
Like Tree67Likes
Thread: Peugeot 404 Utility Project
  1. #201
    18,038
    without the cut outs in the tubes that stick up from the rocker cover you will have to use the latter system anyway.
    This is the "system" you can use the Toyota plug boots on. The boot are a snugly fit the plug tubes. And any off the shelf female plug lead connector fits the extender/adapter.
    This makes for very well sealing system, far better than original. Everything is off the shelf. And you can use, well insulated and sturdy 9 mm silicon sheathed plug leads.
    The early bayonet system plug tube, tend to fill up with water and arc over.
    with apologies to Judy Grahn
  2. #202
    Jan 2013
    Geelong
    440
    Default Plumbing Sorted.
    Peugeot 404 Utility Project-img_2281.jpgPeugeot 404 Utility Project-img_2282.jpgPeugeot 404 Utility Project-img_2283.jpg
    I muddled thru. Based on the thermodynamics (cool water drops to the bottom of the radiator) I surmised that subsidiary circuits (manifold, carb, heater) must have a circuit that follows suit so I hooked them up accordingly. e.g the heater connects to the back of the head so the other pipe goes to the lower rad hose.
    The aluminium thing is a radiator header tank as I'm using a 505 radiator
    I had an issue with the clutch master cylinder; the pedal travelled ~30mm before making contact with the piston in the master cylinder causing clutch drag, thus making gear selection notchy & 3rd gear was not available at all. I posted about that in the general Peugeot section as it's more appropriate there.
    Just cables to do now & the last bits of wiring & I can attempt to start the engine & give it a run in the paddock
    I'm using an alternator with a built in regulator so I have to get my head around what to do with the old wires.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
  3. #203
    Jan 2013
    Geelong
    440
    Default We have a runner!
    Peugeot 404 Utility Project-img_2292.jpgPeugeot 404 Utility Project-img_2293.jpg
    A couple of embarrassing hold ups:
    1. I found out the hard way (via coolant pouring out of the exhaust manifold) that 504 inlet manifolds have TWO vacuum ports.
    2. My dog picked up the distributor cap & HT leads off the workshop floor as a trophy & nicked off. There are many hiding places on an acreage, but I found them eventually.
    It drove quite well but I have to wait for an exhaust system to make sure there are no extraneous noises. It changed gears perfectly but the brakes still have air.
    The heater spewed coolant out the tap but I'll just bypass it.
    None of the pilot lights work so I have to remove & suspend the dash AGAIN to sort them out. At least the speedo cable will be easier to connect. I checked with an hand held pilot to make sure it was charging & the oil pressure light went out.
    Next step is to trailer it to the local exhaust gurus then the paint shop.
    1949 Citroen Big 6
    1955 MGA1500
  4. #204
    Jan 2013
    Geelong
    440
    Well, it appears the exhaust supplied is not orig. So they are making one up to suit.
    I've told them the tailpipe exits behind the RH rear wheel.
    Did they have some sort of mudguard behind the rear wheels/
    I've seen all combo's : none, heavy rubber flaps & conventional
    1949 Citroen Big 6
    1955 MGA1500
  5. #205
    Jan 2013
    Geelong
    440
    Default It's Exhausted!
    Peugeot 404 Utility Project-img_2304.jpgPeugeot 404 Utility Project-img_2305.jpgPeugeot 404 Utility Project-img_2306.jpgPeugeot 404 Utility Project-img_2307.jpgPeugeot 404 Utility Project-img_2308.jpg.
    All new from the eng pipe back
    They were perfectly OK re clearances around the eng pipe.
    One single muffler tucked up nice & high before the rear axle
    I told them the tail pipe went on the outside of the jack point but they were adamant that letting it out between the rear cart spring shackle and the jack point was safer & stronger.
    I have to admit it's a much neater result than some of the internet tail pipes I've seen!
    Supplied & fitted for $300.
    marty 404 likes this.
    1949 Citroen Big 6
    1955 MGA1500
  6. #206
    Fellow Frogger! Dano's Avatar
    Apr 2012
    810
    Nice one, George.
  7. #207
    Jan 2013
    Geelong
    440
    Default Air Cleaner & Rear Mudguards
    OK!
    I get the feeling ( via the sales brochure) that they left the factory with NO fixtures to stop mud flinging off the back wheels.
    Am I correct?
    I highly doubt that the Holy Fathers of VicRoads will allow that to pass for registration.
    I'm leaning towards a pair of simple things like you see on flat tray utes eg Falcons etc with struts to keep them rigid.
    The 504 air cleaner was obviously not meant for the 404 eng bay.
    Mounted as per the fittings, the oil reservoir makes access to the brake master cyl reservoir next to impossible & it fouls the bonnet hinge/spring.
    I'm thinking of making an adaptor plate from 3mm thick steel to mount on the 4 rubber blocks then drill it to take the oil reservoir forwards & slightly twisted to the right.
    What have others done?
    1949 Citroen Big 6
    1955 MGA1500
  8. #208
    Jan 2012
    Gold Coast
    175
    Hi you can fit a 404 air filter quite easily just cut the rubber base to suit the dual throat carb you may need a 404 rocker cover.
    The rear mud flaps are very basic sheet metal with a single strut I have two pairs both bent beyond use.
  9. #209
    Jan 2013
    Geelong
    440
    Default Onwards!
    Peugeot 404 Utility Project-img_2309.jpgPeugeot 404 Utility Project-img_2310.jpgPeugeot 404 Utility Project-img_2311.jpgPeugeot 404 Utility Project-img_2312.jpgPeugeot 404 Utility Project-img_2313.jpg
    I haven't been able to get a decent brake pedal but I've tracked down the problem: poor quality front flexible hoses.
    I described it in the Technical section as it applies generally.
    I didn't get any 404 air cleaners so I had to preserve with the 504 unit.
    I made a template out of 3 ply & then made an adaptor plate with 2mm steel. (3 would have been overkill!) It's drilled to pick up the 4 rubber blocks on the rocker cover and then I welded in the 3 mounting studs for the oil reservoir.
    As you can see, I had to move the cleaner forward & rotate anti-clockwise a bit to clear the bonnet hinge/springs and allow access to the brake master cylinder reservoir.
    It works well but looks a bit off TBH.
    I'll see if I can live with it. If not, I'll cut it down into 2 much smaller adaptor plates for the front & rear mounts.
    1949 Citroen Big 6
    1955 MGA1500
  10. #210
    Jan 2012
    Gold Coast
    175
    Hi That is a 404 air filter the 504 filter is drum shaped . from memory the 404 filter needs to rotate closer to the fire wall.
    Don't forget to fill filter with oil to the level.
  11. #211
    Dec 2002
    2,502
    Quote Originally Posted by marty 404 View Post
    Marty, Australian 504s used the oil bath air filter also, until the introduction of the twin-carb motor, about 1977.
    Peter Chisholm and marty 404 like this.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
  12. #212
    8,977
    You can plonk a 504 top into the 404 base.
  13. #213
    Jan 2013
    Geelong
    440
    OK!
    This assembly came with the motor (2L 504) so I assumed it was a 504. (Like the engine pipe!) Graham your scenario may be what I've got; one of the 3 hook clamps on the drum seems off and only just grabs the top which is most def for the twin throat carb. So, the problems I had mounting may be due to the incompatibility of the 504 rocker cover for the drum?
    If it went closer to the firewall I couldn't get to the brake master cylinder reservoir & it fouled the bonnet hinge as the bonnet closed.
    I moved it about 25mm forward & rotated it about 20 degrees counterclockwise
    Thanks Marty! I have LONG experience with oil-bath air cleaners. Air cooled VW's use them.
    1949 Citroen Big 6
    1955 MGA1500
