Peugeot 404 Utility Project - Page 5
Page 5 of 9 First 123456789 Last
Results 101 to 125 of 213
Like Tree67Likes
Thread: Peugeot 404 Utility Project
  1. #101
    Fellow Frogger! Dano's Avatar
    Apr 2012
    810
    I would have thought the shorter bottom one would be the one to remove.
    This assumption is purely based on SWAG (Scientific wild arse guess). Being the shortest and the same thickness as the others, it would take greater force to bend it over a shorter distance. Many years ago, when rallying a Mazda with a leaf spring rear end, we took the short bottom leaf off and inverted it, then reinstalled it on top of the largest spring. This gave us the desired effect of lowering and stiffening the rear end. Slightly drastic measure, but we were competing on a shoestring budget.
    Quote Originally Posted by Demannu View Post
    I'm wondering the same thing. Will leaving a leaf or two out actually make it softer, and if so, which end of the stack should I pull it from?
  2. #102
    Jan 2013
    Geelong
    440
    Peugeot 404 Utility Project-img_1618.jpgPeugeot 404 Utility Project-img_1619.jpgPeugeot 404 Utility Project-img_1620.jpgPeugeot 404 Utility Project-img_1621.jpg
    One finished.
    As expected, the boys at the bolt shop were highly amused by my request for M7 hi-tensile bolts so it's M8 all round.
    I made a very long bolt with M8 all thread to pull the leaves together then G clamps to hold them while I threaded the central bolt. Nyloc nuts all round.
    I'm leaving the springs as they are & will see if the ride shakes out any fillings from my teeth.
    I'm leaving the shackle pins loose till the springs are loaded with the car's weight.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
  3. #103
    18,038
    A tidy bench is the sign of a sick mind.
    Dano and Bad Bertie like this.
    with apologies to Judy Grahn
  4. #104
    Jan 2013
    Geelong
    440
    Peugeot 404 Utility Project-img_1622.jpgPeugeot 404 Utility Project-img_1623.jpgPeugeot 404 Utility Project-img_1624.jpgPeugeot 404 Utility Project-img_1625.jpg
    All secondary areas (underside, engine bay, tray) painted & brush coated in self levelling epoxy clear for durability.
    Now to dismount the bugger & put the Dauphine on!
    Dano likes this.
    1949 Citroen Big 6
    1955 MGA1500
  5. #105
    Jan 2013
    Geelong
    440
    Default Dismounted!
    Peugeot 404 Utility Project-img_1626.jpgPeugeot 404 Utility Project-img_1634.jpgPeugeot 404 Utility Project-img_1633.jpgPeugeot 404 Utility Project-img_1632.jpgPeugeot 404 Utility Project-img_1631.jpgPeugeot 404 Utility Project-img_1630.jpgPeugeot 404 Utility Project-img_1629.jpgPeugeot 404 Utility Project-img_1628.jpgPeugeot 404 Utility Project-img_1627.jpgPeugeot 404 Utility Project-img_1635.jpg
    On the ground again.
    Those mobile stands I made are invaluable.
    The oregon beams are supported on both sides by hardwood posts. I beefed up the one over the front of the car with a steel beam as that one can lift a car with the engine as well.
    If any one wants the fittings (free!) PM me. Does NOT include the angle iron clamps as they are generic for the rotisserie.
    1949 Citroen Big 6
    1955 MGA1500
  6. #106
    Jan 2013
    Geelong
    440
    Default Progress!
    Peugeot 404 Utility Project-img_1773-copy-copy.jpgPeugeot 404 Utility Project-img_1774-copy-copy.jpgPeugeot 404 Utility Project-img_1771-copy-copy-copy-copy.jpgPeugeot 404 Utility Project-img_1766-copy-3-copy-copy.jpgPeugeot 404 Utility Project-img_1767-copy-copy-copy-copy.jpgPeugeot 404 Utility Project-img_1768-copy-copy-copy-copy.jpgPeugeot 404 Utility Project-img_1770-copy-copy-copy-copy.jpg
    Front end going on.
    Rear end going on.
    A couple of queries:
    I'm also putting in the spare wheel carrier & can see how it attaches but how the latch locks the wheel in is a bit hazy. Is there a strap or does the latch just bolt to a cross member then, using the "springiness" of the cradle, lock the wheel in?
    I'm going to get a trimmer to do the seat then noticed there is a padded panel in the dash. The seat & door cards are tan but the dash panel is covered in a grey-blue vinyl which, to be honest, seems a bit incongruous.
    I would expect that panel to be tan to match the seats & door cards. Comments?
    Demannu likes this.
    1949 Citroen Big 6
    1955 MGA1500
  7. #107
    Apr 2012
    810
    Looking good.
  8. #108
    Jan 2013
    Geelong
    440
    Default Spare Wheel Cradle
    Peugeot 404 Utility Project-img_1786.jpgPeugeot 404 Utility Project-img_1787.jpgPeugeot 404 Utility Project-img_1788.jpgPeugeot 404 Utility Project-img_1789.jpg
    Thanks Colin H!
    What I thought were 2 solid rivets were 2 swivel points.
    When the clasp (which bolts to the 1st cross member in front of the rear extremity) is unscrewed, the cradle swings down.
    Unfortunately, when I tried to unscrew the clasp, the bolt sheared.
    I welded an M10 nut to the stump & tried to unscrew it but there was too much resistance so I will wait till the Penetrene does its work.
    1949 Citroen Big 6
    1955 MGA1500
  9. #109
    Jan 2013
    Geelong
    440
    Default Rear Brake Shoes
    Peugeot 404 Utility Project-img_1795.jpgPeugeot 404 Utility Project-img_1796.jpgPeugeot 404 Utility Project-img_1798.jpg
    These are held to the backing plate by a coil spring on the shoe which hooks onto an eyelet engaged to the backing plate.
    The manuals I have are no help re engaging & disengaging.
    I made a tool from a medium screwdriver that stretched the spring from above then another screwdriver to push the eyelet and hook it onto the spring.
    *I'm probably like the little boy teaching his grandmother how to suck eggs but there it is anyway!*
    FIVEDOOR and 59 Floride like this.
    1949 Citroen Big 6
    1955 MGA1500
  10. #110
    18,038
    That's different to any car I've seen. They use a U shape spring clip to retain the shoes.
    I have an identical screw driver but I use it to stretch the spring between the shoes.
  11. #111
    Jan 2013
    Geelong
    440
    That's what is on the 404's front brakes & the Dauphine's.
    So, I guess these are unique to 404 utes?
    1949 Citroen Big 6
    1955 MGA1500
  12. #112
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    373
    Same setup is used on my trailer, it has Valiant brakes
    .cheers Pete
    I am gunna get another 403 on the road........one day
  13. #113
    18,038
    Quote Originally Posted by geodon View Post
    And probably station wagons, which are in fact a light truck.
  14. #114
    3,560
ID:	86194Click image for larger version.
ID:	86195Click image for larger version.
ID:	86196Click image for larger version.
    Sage Grey, the colour of my ute!
  15. #115
    Jan 2013
    Geelong
    440
    Default Siezed (?) Brake Adjusters
    Peugeot 404 Utility Project-img_1799.jpgPeugeot 404 Utility Project-img_1800.jpgPeugeot 404 Utility Project-img_1801.jpgPeugeot 404 Utility Project-img_1802.jpgPeugeot 404 Utility Project-img_1803.jpg
    Sincere apologies to the Peugeot Purists but those square section adjusters are a PITA.
    Fine if you've got a REALLY good fitting box spanner but, even then, I doubt you would get enough purchase to overcome seizure. All 8 of mine were impossible to turn with a 10mm OE spanner. All I did was round them off. I rang a few tool shops- dead end. I thought about making a spanner with 4 bits of 10mm square rod fillet welded to make a 10mm square tube or even welding 2 cheap 10mm OE spanners end to end but I couldn't be bothered. There was an easier way that yielded a better result.
    Seriously, if designers are taking the cheap way out & using friction rather than (e.g.) snail ratchets to keep the brakes adjusted, at least give the maintenance guy a chance!
    59 Floride and Dano like this.
    1949 Citroen Big 6
    1955 MGA1500
  16. #116
    Jan 2013
    Geelong
    440
ID:	88786Click image for larger version.
ID:	88787Click image for larger version.
ID:	88788Click image for larger version.
ID:	88789Click image for larger version.
    Peugeot 404 Utility Project-img_1804.jpgPeugeot 404 Utility Project-img_1805.jpgPeugeot 404 Utility Project-img_1806.jpgPeugeot 404 Utility Project-img_1807.jpgPeugeot 404 Utility Project-img_1808.jpgPeugeot 404 Utility Project-img_1809.jpgPeugeot 404 Utility Project-img_1810.jpg
    Well, it wasn't a pang of conscience. I did the rears & had begun to remove the front backing plates when I suddenly remembered I'd been gifted a crapload of spanners. Rummaging thru I found 7 (seven) 3/8 AF R/OE spanners. A totally useless size, hence none get lost. But sadly no 10mm. 3/8 AF is ~9.5mm so out came the angle grinder & the pictures tell the story. I put a bit of a bend in it so it sat nicely over the adjuster & it worked perfectly.
    OK so I have orig brake adjusters in the front & bastardised ones in the back.
    C'est la vie!!
    1949 Citroen Big 6
    1955 MGA1500
  17. #117
    18,038
ID:	88791Click image for larger version.
ID:	88792Click image for larger version.
ID:	88793Click image for larger version.
ID:	88794Click image for larger version.
ID:	88795Click image for larger version.
ID:	88796Click image for larger version.
    C'est la vie!!
    It's a known problem. And the standard fix is to weld a M 10 nut (19 mm spanner) on to the square adjuster. When rounded the nut usually easily slips over the ex square adjuster.
    The added benefit is being able to have "micrometer adjustment and feel" on a 19mm ROE spanner.
    It became almost standard practice for Regans (in Hawthorn Melb.) to do the mod on older 403/ 404.
    marty 404 likes this.
  18. #118
    Jan 2013
    Geelong
    440
Name:	IMG_1773 - Copy - Copy.jpg
ID:	88432Click image for larger version.
Name:	IMG_1774 - Copy - Copy.jpg
ID:	88433Click image for larger version.
Name:	IMG_1771 - Copy - Copy - Copy - Copy.jpg
ID:	88434Click image for larger version.
Name:	IMG_1766 - Copy (3) - Copy - Copy.jpg
ID:	88435Click image for larger version.
Name:	IMG_1767 - Copy - Copy - Copy - Copy.jpg
ID:	88436Click image for larger version.
Name:	IMG_1768 - Copy - Copy - Copy - Copy.jpg
ID:	88437Click image for larger version.
Name:	IMG_1770 - Copy - Copy - Copy - Copy.jpg
    Front end going on.
    Rear end going on.
    From the Dutch 404 club.
    TBH, I prefer this to the Duck Egg Blue which IMHO looks off.
    1949 Citroen Big 6
    1955 MGA1500
  19. #119
    18,038
    on the sedan there is over center latch arrangement that latches the rear round section of wheel frame and locks closed.
    There is a plastic loop the protrudes through the boot floor, inside boot, behind the number plate. Which is pulled to release the primary latch, the second stage is released by lifting the frame, from under the car.
    I'm a bit hazy of the exact system since it's a couple of years since I have had a 404.
    And then again utes may be a little different.
  20. #120
    Jan 2012
    Gold Coast
    175
    Hi Geodon
    Mine has a large brass threaded knob that you do up to hold the wheel carrier up I will take a photo over the weekend .I collected another wheel carrier that was held up with a turn buckle.
    geodon likes this.
  21. #121
    Jan 2012
    Gold Coast
    175
    HI Geodon
    I have had a look though the 404 parts manual and found this there appears to be a spring clip of some sort as well as the brass knob.
    Peugeot 404 Utility Project-img_1146.jpgPeugeot 404 Utility Project-img_1147.jpg
    I will have to investigate further.
    Marty
  22. #122
    18,038
    Quote Originally Posted by marty 404 View Post
    HI Geodon
ID:	88854Click image for larger version.
    Marty
    That is entirely different to the sedans, so , as you were.
  23. #123
    Jan 2013
    Geelong
    440
    Peugeot 404 Utility Project-img_1818.jpgPeugeot 404 Utility Project-img_1819.jpgPeugeot 404 Utility Project-img_1820.jpgPeugeot 404 Utility Project-img_1821.jpg??
    Mine is a bit different Marty. Can't show you yet. I have worked out how it works but I broke the clasp & it's being fixed off site ( No oxy gas left!)
    Meanwhile, the front end is completely on.
    A bit of a hiccup in the rear: I have new shocks but they won't fit unless I compress the springs. No big deal. I can do that easily with truck size ratchet tiedowns.
    BUT, doesn't that mean that the shock will carry the burden of a full stretch? There are no check straps. I have emailed the supplier (WW Shocks Qld) and am awaiting a reply. There's only 20mm in it.
    ETA: I checked the Land Rover forum. Consensus says check straps were essential for the older oil filled shocks and to prevent those shock mounts being literally torn off. It's hard to imagine the Pug in that motoring scenario! Modern air shocks are built to take the load of a fully extended leaf spring. The point was made that later coil spring models ( e.g. Defenders) have no check straps.
    I'll contact the supplier Monday
    ETA No.2 Supplier assured me they are the same length as the samples I sent. I had 4 more as well still here & I checked they were the same. WW said check straps are only required for extreme conditions ( e.g. off road, hence Land Rovers) & under normal road conditions modern shocks will handle the spring going to full stretch
    1949 Citroen Big 6
    1955 MGA1500
  24. #124
    Jan 2013
    Geelong
    440
    Peugeot 404 Utility Project-img_1822.jpgPeugeot 404 Utility Project-img_1823.jpgPeugeot 404 Utility Project-img_1824.jpgPeugeot 404 Utility Project-img_1825.jpgPeugeot 404 Utility Project-img_1826.jpg
    I'm starting to bolt on body panels to make sure all the fixing points are kosher.
    Between the mudguards, sills and the timber slats on the load deck there are about 50 (fifty) of these M6 caged nuts. Some were not saveable & were replaced with M6 rivnuts & M8 where the hole was just too big.
    Life's too short to clean the thread on each one manually so I welded an M7 nut onto a tapered M6 tap. Then a rattle gun expedited the process
    Dano likes this.
    1949 Citroen Big 6
    1955 MGA1500
  25. #125
    Jan 2013
    Geelong
    440
    Default More of the same.
    Peugeot 404 Utility Project-img_1827.jpgPeugeot 404 Utility Project-img_1830.jpgPeugeot 404 Utility Project-img_1831.jpgPeugeot 404 Utility Project-img_1832.jpg
    The doors are held on by 6xM8 set screws that engage 2 sliding plates with threaded holes deep in the frames.
    The threads were, naturally, quite rusty.
    Cleaning them was a problem till I welded a tapered M8 tap onto the end of a little used tube spanner & then put a socket on the other end.
    Dano and marty 404 like this.
    1949 Citroen Big 6
    1955 MGA1500
