Peugeot 404 Utility Project - Page 4
Page 4 of 9 First 12345678 ... Last
Results 76 to 100 of 213
Like Tree67Likes
Thread: Peugeot 404 Utility Project
  1. #76
    SWOTR
    3,342
    I have similar memories from the distant past when I had objections raised of the apparent misuse of ovens etc.
  2. #77
    Jan 2013
    Geelong
    440
    Default Experiment
    The rust converter has been on the best part of a week & when I looked carefully I found that while the formerly rusty bits are nice & dry, the painted bits (I just sloshed it everywhere!) felt a bit greasy. I'd guess that where there was no reaction the phosphoric acid just hangs around? Funny thing is I diligently used Prepwash
    So I applied a hot air gun to the suspect bits & they instantly got smooth, clean & dry.
    So I obviously need heat.
    These things are quite effective in a small enclosed space.
    Settle down OHS stalwarts! They are running off my 15A welding power point
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
  3. #78
    Jan 2013
    Geelong
    440
    Default Still no go
    Well the problem continues.
    There appears to be a definite incompatibility in certain patches.
    Next step is rub it back down then use a cold gal rattle can eg Finixa as a "fixer".
    I've NEVER seen that not stick!
    Peugeot 404 Utility Project-img_1582.jpgPeugeot 404 Utility Project-img_1584.jpg
    1949 Citroen Big 6
    1955 MGA1500
  4. #79
    Jan 2012
    Gold Coast
    175
    Hi Geodon your paint problem looks like the solvent based primer eating into the soft original red primer and top coat .I,am using a 2pac epoxy primer on my ute after taking off as much paint as i can get too and using rust convertor with no issues yet. The rust convertor will soften old paints as well.
    Marty
  5. #80
    Jan 2013
    Geelong
    440
    Thnx Marty but I don't have the space suit etc to use epoxy two-pac in a spray situation. It is cyanide based after all!
    However, you are correct: the acrylic primer/GP thinners combo is not co-existing with the existing paint.
    I have a couple of rattle cans of cold gal.
    Let's see how it goes at forming a platform for the acrylic to sit on. Fortunately, it's only a small area that is reacting
    1949 Citroen Big 6
    1955 MGA1500
  6. #81
    18,038
    Buy some ICF free two pack primer.
    You need an undercoat for this product: 620 ICF BARRCRYL
    PPG Industries - Light Industrial Coatings
    These are industrial coatings, that are deigned to sprayed without a booth and heating.
    geodon likes this.
    with apologies to Judy Grahn
  7. #82
    Jan 2013
    Geelong
    440
    Default That did it!
    Peugeot 404 Utility Project-img_1587.jpgPeugeot 404 Utility Project-img_1588.jpg
    The Finaxa was a bit "unkind" but the Ruststop cold gal went on beautifully.
    I only have the tray underside left to do in primer.
    I'll go via repeated light dust-on coats to minimise any adverse effects.
    1949 Citroen Big 6
    1955 MGA1500
  8. #83
    Jan 2013
    Geelong
    440
    Default Wood Panel on the Tray?
    Can anyone enlighten me as to what goes in the centre section of the tray area?
    At a guess, I'd say some sort of timber panel held down by 6mm countersunk set screws/bolts. Was it painted? I'm leaning towards a thick clear epoxy coat
    I measured it at 28mm thick and was planning on using marine ply which I can get in 12 & 15mm thickness so I will glue the two sheets together.
    I can't see it would be one piece. It would have to be at least 2 if not 3 pieces so that there is a successful tuck-in along the longitudinal axes.
    1949 Citroen Big 6
    1955 MGA1500
  9. #84
    18,038
    Quote Originally Posted by geodon View Post
    Don't know what was there originally. But I have seen all varieties of utes with natural timber flooring coated with 2 pack clear.
    And inch 11/4 is is a standard thickness. Probably Jarrah or Red Gum for durability or black butt if want something lighter. Paint both sides, with special attention of end grain sealing.
    And it can be sanded to restore it good looks.
  10. #85
    Jan 2013
    Geelong
    440
    There are 3 rows of captive nuts so has to be 3 pieces max. without drilling more holes in the bearers.
    Those timbers sound nice but I'm doubting I can get them in ~ 250+mm wide lengths without taking out a personal loan hence my pref for marine ply which, mind you, is costly enough!
    1949 Citroen Big 6
    1955 MGA1500
  11. #86
    18,038
    I'd suggest the timber will be but a very small part of the overall restoration cost. When I've needed thick and wide timbers, I've used landscaping sleepers and had them put through a thicknesser.
    Sleepers are often quite well priced, with less choice of timbers 'tho.
    Anyone for an Iron Bark tray ?
  12. #87
    NSW
    616
    I think it was narrower timbers with a metal strip that clamps down using the 3 rows of captive nuts. Timber floor boards tongue and grooved would be my guess
    Adrian Wuillemin
  13. #88
    Jan 2013
    Geelong
    440
    Quote Originally Posted by Adrian Wuillemi View Post
    Thnx Adrian, that makes sense now.
    The strips means the timber does not need drilling and there will be wriggle room when fitting because the strips will hide any gaps.
    However, with 3 lengths of timber, only the middle one is fixed on both sides. The outer ones have only 1 fix point because there are no caged nuts on the extremities under the metal tray. So, I'm guessing the timber thickness is critical so that it's a snug fit under the tray. Perhaps a rubber mallet on the metal tray edge to put a bit of downwards pressure on the outer timbers?
    1949 Citroen Big 6
    1955 MGA1500
  14. #89
    8,211
    The usual timber for warehouse floors and local truck and ute trays was Brush Box, a pink-red NSW hardwood. It is extremely wear and splinter resistant when things get dragged and slid over it. I can't say the same for any paint finish.
    Still available, it is a common street tree in Sydney.
  15. #90
    Jan 2013
    Geelong
    440
ID:	85548Click image for larger version.
    I sought expert guidance & it seems I'm putting acrylic paint over enamel. They are not compatible. The Pug is a 1970 & acrylic paint must have been phased out by then? I'd better check the Dauphine before I get paint!!
    I'm committed now. But, the reaction is only in patches and I'm only doing secondary areas so I should hopefully get away with it. I experimented with other paint on the problem areas & Rustguard Red Oxide seems to be the go to stabilise where there are eruptions.
    Dano likes this.
    1949 Citroen Big 6
    1955 MGA1500
  16. #91
    Dec 2005
    HOBART
    1,265
    My ute has the timber tray and a number of the bearers have rotted out. I think replacing the timbers is the best option as future damage can be rectified by one piece and is easy enough to slot in. Just my 2 bob
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
  17. #92
    Jan 2013
    Geelong
    440
    Default Gear Box Mounts
    Peugeot 404 Utility Project-img_1591.jpgPeugeot 404 Utility Project-img_1592.jpgPeugeot 404 Utility Project-img_1593.jpgPeugeot 404 Utility Project-img_1594.jpg
    I'm in the dark here.
    It looks to me like one of the front (?) GB mounts is missing the bolt & reinforcing bracket.
    Have they come adrift during disassembly?
    Can anyone post a picture of what it looks like intact?
    1949 Citroen Big 6
    1955 MGA1500
  18. #93
    18,038
ID:	85773Click image for larger version.
ID:	85774Click image for larger version.
ID:	85775Click image for larger version.
    In sedans anyway, there are no front GB mounts. The only mounts are on the front block webs supported by a U shaped yoke from the front cross member.
    The rear of the gearbox is supported by a three point mounted meta-elastic mount, going over the rear of the GB, two bolts through the side of the rails and one bolt through the top of the trans tunnel.
    The mount is sandwiched by the TT two piece spherical head "plummer block" system. And thus mounted to the gearbox by the four cap screws.
    The m10 stud with the nut is the pivot for the hand brake equalizer lever, front of which accepts the handbrake lever cable and rear which accepts the wheel cables. The is also an extension spring in th mix somewhere. The equalizer sits under the TT.
    If you can forgive my "paint" skills this is how it works from memory
    geodon and Dano like this.
  19. #94
    Jan 2013
    Geelong
    440
    Ah!
    That bolt is the hand brake pivot, yes?
    So, nothing is missing as far as you can see?
    I have to know now while I gat easily get at the underside.
    1949 Citroen Big 6
    1955 MGA1500
  20. #95
    18,038
    Ah!
    Nothing seems to be missing and M8 studs sticking out towards the back are for the rear wheel handbrake cable, brass support doovers.
  21. #96
    Jan 2013
    Geelong
    440
    Default Progress!
    Peugeot 404 Utility Project-img_1595.jpgPeugeot 404 Utility Project-img_1596.jpgPeugeot 404 Utility Project-img_1597.jpgPeugeot 404 Utility Project-img_1598.jpgPeugeot 404 Utility Project-img_1599.jpgPeugeot 404 Utility Project-img_1600.jpgPeugeot 404 Utility Project-img_1601.jpgPeugeot 404 Utility Project-img_1602.jpg
    Primer on, "schutz" on and the 1st light coat of colour on.
    I followed the advice of the of the paint retailer & applied colour to the schutz while it was still a bit sticky.
    I turned the air pressure for the paint right down to below 40psi hoping to minimise any incompatibility eruptions & I don't know if it helped but I only got one small area to rub back & re-do.
    After one more coat of colour, I'll brush/roller some self-levelling epoxy clear & then start reassembly.
    To quote Bill Lawry: "It's all happening!"
    Dano likes this.
    1949 Citroen Big 6
    1955 MGA1500
  22. #97
    Jan 2013
    Geelong
    440
    While the coats are drying, I'm ripping into the cart springs.
    My painting technique reminds me of the crankshaft lubrication system on Austin 7's: i.e. "Squirt and Pray". But, the parts I'm doing are not on display. The back is so badly marked by dings, scrapes and remnants of the attachments for a bastardised tray that I've decided to just paint over it. It can proudly display the scars of a hard life under a rubber mat!
    The springs are cleaned painted & coated with copper grease. They will need compression to be bolted together; probably a length of all thread then G-clamps.
    The bolts did not survive & the smaller ones are M7's. May be hard to find but there's enough metal there to take them out to M8 if necessary.
    Peugeot 404 Utility Project-img_1613.jpgPeugeot 404 Utility Project-img_1614.jpgPeugeot 404 Utility Project-img_1615.jpg
    Dano likes this.
    1949 Citroen Big 6
    1955 MGA1500
  23. #98
    Jan 2012
    Gold Coast
    175
    Hi Geodon I had a hard time stripping my spring shackles with the bolts being rusted into the bushes hopefully new bushes and grease will make the springs more supple ,I wonder if it is a good or bad idea to leave out one or two spring leaf,s as I will never carry one ton. Do you have tray sides as there is a fair bit of welding to attach them.
  24. #99
    Dec 2002
    2,502
    Quote Originally Posted by marty 404 View Post
    I'm wondering the same thing. Will leaving a leaf or two out actually make it softer, and if so, which end of the stack should I pull it from?
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
  25. #100
    Jan 2013
    Geelong
    440
    I have the sides & tailgate and I'm leaving that to the body shop to fit. They are a bit bent & they did my single cab Kombi a few years back. It had a similar problem & they got them as straight as a die.
    Yeah, my shackle pins were rusted too but a week in the electrolysis tank loosened them up nicely & they just tapped out.
    As you can see, I've got OVERLOAD springs as well. These must be the three camel option? Or is that normal?? That makes a total of 8 (eight) leaves. That's more than the Land Rover! I'm thinking I will leave these off.
    How many leaves is standard?
    If removing, I'd reckon you start at the bottom.
    Peugeot 404 Utility Project-img_1616.jpgPeugeot 404 Utility Project-img_1617.jpg
    1949 Citroen Big 6
    1955 MGA1500
