Gawd, another R8 upgrade - Page 7
Page 7 of 8 First ... 345678 Last
Results 151 to 175 of 181
Like Tree132Likes
Thread: Gawd, another R8 upgrade
  1. #151
    4,261
    Nearly 12 months and it seems like nothing has happened!
    I picked the car up today from the panelbeaters. He had welded in a replacement A pillar section where his previous poor repair was preventing mounting the door and LHS Fr guard. The panel fit is not real good, but I'm not sure if thats due to the length of time the fibreglass panels were in storage before mounting to the car, so there is a fair bit of fettling to get them reasonable - I've given up on perfect!
    I've been progressing on brakes, and hope to have the brakes done by the end of the month. I'm also working on the collapsible steering column at the same time. Using a Falcon column like c.lees but may do away with the rag joint and use the falcon uni joint and an intermediate splined shaft.
    I can then pop the engine in and start to consider wiring etc.
    Attached Thumbnails Attached Thumbnails Gawd, another R8 upgrade-img_0173.jpg   Gawd, another R8 upgrade-img_0175.jpg   Gawd, another R8 upgrade-img_0176.jpg   Gawd, another R8 upgrade-img_0177.jpg
    KB
  2. #152
    4,261
    Good progress today. I fabricated and zinc plated a mount for the RHS booster then bolted that in alongside its' partner in crime; then fabricated, plated and installed a plate for the aftermarket handbrake (similar to c.lees). Waiting for the rain to go away so I can spray the insides of the guards and the rear chassis rails where the bumper bar bolts to - as these were where the rotisserie bolts were when the shell was painted. After they're done, I can bolt the engine in and get a bit of workshop space back.
    Attached Thumbnails Attached Thumbnails Gawd, another R8 upgrade-img_0178.jpg   Gawd, another R8 upgrade-img_0180.jpg   Gawd, another R8 upgrade-img_0182.jpg   Gawd, another R8 upgrade-img_0184.jpg
    KB
  3. #153
    4,261
    That looks like an engine mounted in there....
    Also did a bit of spraying of the guards - insides.
    More work continuing on the brakes; then the steering column is next.
    Attached Thumbnails Attached Thumbnails Gawd, another R8 upgrade-img_0185.jpg
    R8 Dream and bowie like this.
    KB
  4. #154
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,258
    Thank goodness you have the restraining chain installed to cope with the horsepower and prevent the engine leaping from it's mounts....
  5. #155
    4,261
    They leap from their mounts fairly regularly, but I’m not sure it’s due to power!
    KB
  6. #156
    1000+ Posts J-man's Avatar
    Littlehampton, S.A.
    22,514
    How good is that yellow looking!
    cheers,
    John
  7. #157
    4,261
    Another piece of the puzzle assembled today.
    I'd had a kangoo 1.9 diesel master cylinder for some time (since early last year) and had one of c.lees aluminium adapters to mount to the std block. Today I picked up some custom machined fluid adapters; blanking plugs and line fittings; and a custom made pushrod (all done using c.lees designs and drawings).
    Just waiting on some braided AN4 hose to go from the twin remote reservoirs to the input adapters and I should be ready to bolt the master cylinder into the car.
    Attached Thumbnails Attached Thumbnails Gawd, another R8 upgrade-img_0186.jpg
    JohnW likes this.
    KB
  8. #158
    610
    I would like to hear how you go as this could also be a worthwhile upgrade to my single cylinder set up with the Gros Brakes.
    Please keep us posted.
  9. #159
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,213
    Yeah wait. 2 x boosters, and 1 x master cylinder. (admittedly with twin circuits)
    I'm confused (not difficult I confess)
    I assumed there was going to be some mad adaptability stuff going on here.
  10. #160
    Littlehampton, S.A.
    22,514
    A remote booster typically has one circuit, hence one booster per circuit
    cheers,
    John
  11. #161
    4,261
    Yes. VH44ís have one in and one out port. It will be as JMan suggests.
  12. #162
    10,367
    Nice work, very nice.....
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
  13. #163
    4,261
    So, I've sort of decided to start at the front and work my way backwards. Today's minor success is a semi-functioning bonnet catch.
    The brakes are just waiting on parts to arrive for the plumbing, so I'm doing bits and pieces while I wait.
    Attached Thumbnails Attached Thumbnails Gawd, another R8 upgrade-img_0192.jpg   Gawd, another R8 upgrade-img_0193.jpg   Gawd, another R8 upgrade-img_0194.jpg
    Brianbcs likes this.
    KB
  14. #164
    It's how I roll...Brisbane
    32,492
    Nice going KB, keep plugging away and do take more pictures.
  15. #165
    4,261
    Over the last couple of nights I've made and run the brake lines at the front - left to right from a distribution block, to be served by the booster; and made and run the line(s) to the back; and installed a proportioning valve.
    Work then ground to a halt. I bought some new grommets and need one for the chassis rail (the oblong one) where the rear brake line runs through the chassis rail and can't recall where i put them. I'll to mount a search then resume another night.
    Attached Thumbnails Attached Thumbnails Gawd, another R8 upgrade-img_0197.jpg   Gawd, another R8 upgrade-img_0198.jpg
    JohnW likes this.
    KB
  16. #166
    Oct 2014
    Windsor 2756 NSW Australia
    514
    Very neat and tidy KB. I never knew there was a grommet there, makes sense. You must have put it in that same "safe place" i put bits and than can't find them. It seems to happen more often as the years roll by.
  17. #167
    4,261
    The grommet is further down the front on the smallest "Chassis rail" - not actually pictured in these pics Bustamif (just in case I confused you). And yes, I am finding that location more and more often lately!
    KB
    KB
  18. #168
    1000+ Posts Frans's Avatar
    Auckland
    1,401
    You're doing a superb job here however, if I may ask why are you installing a proportioning valve? Is this the same as the limiter we all talked about and all removed it as well?
    Regards, Frans.
    Old enough to know better
    Young enough to do it anyway.
  19. #169
    4,261
    Frans, the old limiter has been replaced with a 3 way port BUT, you need to remember this has the Williams clio brakes - ventilated, cross- drilled and slotted on the front; Fiat 132 calipers on the rear plus each circuit boosted with a VH44 so some FR bias adjustment may be necessary.
    KB
  20. #170
    10,367
    I'm looking forward to a ride..... And to experience the brakes! Nice work Kevin.
    Renault 4CV 1951
    Renault R8 1965
  21. #171
    32,492
    Very nice work there Grasshopper, points off though, that ELF drum could be rotated 60 or 70 degrees for maximum presentation.
  22. #172
    4,261
    This is Aussiefrogs, not Instagram Graham!
    KB
  23. #173
    4,261
    Almost to the point where I can sit in it and make Broom Broom noises....
    Attached Thumbnails Attached Thumbnails Gawd, another R8 upgrade-img_0200.jpg   Gawd, another R8 upgrade-img_0201.jpg
    KB
  24. #174
    4,261
    Carbon Fibre is the new black!
    I also played around with fitting the guards and managed to get the guards a little better lined up at the front (without cutting the fibreglass yet Bustamif).
    Attached Thumbnails Attached Thumbnails Gawd, another R8 upgrade-img_0210.jpg   Gawd, another R8 upgrade-img_0205.jpg   Gawd, another R8 upgrade-img_0208.jpg   Gawd, another R8 upgrade-img_0211.jpg
    KB
  25. #175
    10,367
    Better fit than some coming out of the factory I'd suggest! Very nice.
    Renault 4CV 1951
    Renault R8 1965
