Gawd, another R8 upgrade - Page 5
Page 5 of 8 First 12345678 Last
Results 101 to 125 of 184
Like Tree133Likes
Thread: Gawd, another R8 upgrade
  1. #101
    4,424
    Just wondering if the trim is going to be replaced on the C-pillar (adding weight :-)), or are the holes going to be filled?
    The outside trim is going back on, and yes there will be some form of trim going on the lower internal bits.
    I'm not going to Bustamif's extremes in weight saving. I haven't weighed the guards as yet.
    KB
  2. #102
    4,424
    So still working on the front suspension before re-installing not the least was searching through all the bits to locate it all. The demolition/rebuild of the garage in between last year didn't help. Mostly everything was bagged and tagged, it was just a case of finding which box they were in.
    I was diverted onto the fuel tank as this needs to go back in before the gearbox. Gave it a degrease, a scrub and it hasn't come up too bad. I pulled the fuel sender out to do two things - measure the resistance; and check the seal.
    I seem to recall someone documenting the rebuilding of their sender float - JohnW, geckoeng? if it was you can you post or email the details please. Also, if someone electrically minded could tell me the proper way to measure the resistance in Ohms of the sender across its' range - COL? The reason I may need to know is that I will more than likely be using an aftermarket gauge hence the need to know.
    Attached Thumbnails Attached Thumbnails Gawd, another R8 upgrade-dscn2944.jpg   Gawd, another R8 upgrade-dscn2943.jpg   Gawd, another R8 upgrade-dscn2947.jpg   Gawd, another R8 upgrade-dscn2945.jpg
    KB
  3. #103
    Oct 2014
    Windsor 2756 NSW Australia
    640
    With regard to the float on the sender, I recall I may have shown you one of my rebuilt sender floats on one of your visits to the shed. I discovered that the brass float from a spare 16TS carb was an exact replacement. Just carefully solder it onto the sender rod. Easy as.
    I am in Wagga at the moment, otherwise I would go out to the shed and take a pic. By the way, I saw a very tidy 2CV parked in the side street beside the Wagga council Headquarters.
  4. #104
    It's how I roll...Brisbane
    33,706
    I seem to remember Frans (I think) soldered a small domestic light globe to the steel rod as a float, I'm sure it worked.
  5. #105
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,290
    Kevin i found this article, it may help you with your after market fuel gauge.
    How To Adjust the Fuel Gauge Sender : How-To Library : The MG Experience
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
  6. #106
    4,424
    Thanks everyone. I just found JohnW's thread which has a fair bit of good advice.
    Now I need to decide if I go the R16 float (which I don't have) or the glass bulb method of Frans.
    JohnW likes this.
    KB
  7. #107
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,740
    KB,
    I took the broken Renault stuff out and fitted VDO in the Gordini, as the Renault gauges are becoming very difficult to get and are all very old, anyway. Senders can be new now days.
    Ray
    Graeme's R8 Gordini Rebuild !!!
    #35
    JohnW likes this.
    Ray geckoeng
    Think Old, But Run Modern !!
  8. #108
    11,213
    KB,
    Ray
    #35
    I'd add, despite living with it, that the original fuel gauges simply aren't very good either! I guess they are adequate for ordinary use, and I've never run out of fuel, but..... All depends what you want from the car, doesn't it.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
  9. #109
    33,706
    This might be of interest, it's out of the mighty Fregate. The float is a light gauge tin can.
  10. #110
    Jul 2013
    southampton Ontario Canada
    89
    Renault 8&10 I have been collecting a few floats along the way to replace the cork originals that are in my cars . I have noticed that most of the newer vehicles run the electrical fuel pumps that are located in the tank > The complete unit is normally a throw away once the pump expires so I have saved several arms with the floats that I intend on tack weld onto the old arms to make them more of a permanent repair with a float that does not get gas logged . It is always nice to find a free recyclable source !
    Manic GT
  11. #111
    1000+ Posts Frans's Avatar
    Auckland
    1,536
    I did the same recently with the Matra sender unit and bought 2 globes (oblong shape/candle light shape) and when I got home I could not solder it because the bases was made out of some sort of aluminium and solder doesn't take on it. I had to go to a few other shops before I could get the ones with a brass base.
    So if you go this way, take note that the silver coloured bases are useless, it has to be brass.
    Frans.
    JohnW likes this.
    Old enough to know better
    Young enough to do it anyway.
  12. #112
    11,213
    Quote Originally Posted by 59 Floride View Post
ID:	94630Click image for larger version.
    That gasket is a bit rough by your standards....
    Interesting that they didn't use cork.
  13. #113
    33,706
  14. #114
    4,424
    Few small jobs done today:
    I made my own sender gasket out of rubber sheet, used the thread saver to start to repair the thread on the stub axles. Pulled out all the bolts and bits to mount the lower control arms to the cross member, but realised I should buy some new bolts if I can get them.
    Then it started raining on and off the rest of the day, so in between showers I drove the R10 up onto ramps, disconnected the battery; then removed the undertrays, pedal Box bits and bobs, removed the steering rack and a few other bits - the R10 has officially retired!
    Various bits are going to be used in the project R8.
    KB
  15. #115
    4,424
    So I bought these new steering arms from Mecaparts back in about 2014 in a bunch of parts with an injection of cash at the time (goodbye Motorcycle!) and they've been in a box until now.
    Has anyone used these, do they just screw into the steering rack in place of the eyelets? (Which I also bought some new ironically in the same purchase)?
    It's a good feeling when reassembling to be able to reach into a box and pull out brand new items when reassembling something like this! but with these I'm not sure they are the right ones. Mecaparts advertising them on their website as being for R8/R8G. I got two arms, two boots and the washers and screws pictured as the "part" purchased. I think I bought the eyelets separate.
    Attached Thumbnails Attached Thumbnails Gawd, another R8 upgrade-dscn2949.jpg   Gawd, another R8 upgrade-dscn2948.jpg
    KB
  16. #116
    Oct 2014
    640
    I used them on the white R8G. They just screw into the rack and you use the crush washers so they don't unscrew and fall off (hopefully).
    Its a couple of years ago but I think it is all pretty easy, even getting the boots on is not too hard.
    The tricky and fiddly bit is making sure the rack is in the centre and the wheels are pointing straight before you do the final alignment with plenty of adjustment and enough thread engagement. Again so the bits don't unscrew and fall off.
    Remember to make sure you do any mods to get your neg camber before doing the final toe alignment.
  17. #117
    4,424
    Thanks Bustamif.
    The cross member was already modified, so I'll just be bolting it back up, but I do plan to leave a lot loose until I'm ready to tighten everything up in one final go down the track.
    The main concern at present is just to get it on wheels and able to be wheeled about for now.
    KB
  18. #118
    11,213
    Gee, they look nice. Needs the big locknut for the male thread that goes into the rack, which you'll have on the eye-fitting from the old system. I really like what looks like a good quality boot on the outer joint. The arm is very slim at the inner end, where it is shiny on the photo, isn't it?
  19. #119
    4,424
    The passengers side ball joint and this joint were both toast on the car when I pulled it apart. At least it explained why James couldn't bolt a wheel on without it rubbing/locking up when he was readying the car for me to pick up - on a car Trailer!
    KB
  20. #120
    Auckland
    1,536
    I don't think you need that big locknut John. I have them on my race car and they look the same. Unless there is a different model, the old arm, male thread and big nut gets replaced as complete set. Those washers on the new arms fit in a "key set" and then when tightened it locks so that they never can undo.
    I love them because now the alignment can be adjusted infinitely and not by 1 or 1/2 turn at a time. the other advantage they have on race cars especially is that there is no noise damping rubbers. So, if they are set the wheels remain in that position and don't alter themselves under hard braking.
    Kevin, are you going to race this car because it is going to look beautiful? Reason I'm asking is that it sounds like you have the extra holes to give you some negative camber drilled in the crossmember. Now I might be too fussy but if you are going to race it then you should actually have solid bushes in the wishbones. It is of no use to get the negative camber and under hard cornering the the upper and lower wishbone bushes compress with the additional forces and the wheels then go over to positive camber. A lot of grip will then be lost as the tyre surface changes from a full area grip to a half area grip.
    If you have done then ignore my post.
    JohnW likes this.
  21. #121
    4,424
    I bought std bushes from Mecaparts and pressed those in. I think there was some pics on here from back in 2015.
    It is not going to be a full on race car. It is a replacement for the white R10, so will be a multi purpose weekend car. It will do a few track events, supersprints etc but probably not open race meets and maybe classic rallies again that I was doing with the R10 previously.
    It will be too pretty for dirt events I suspect! Fulfills an ambition/bucket list to have two R8's - one std; one hotted up in the garage.
    KB
  22. #122
    Oct 2014
    640
    Good point Frans. I put the solid bushes in to get full advantage of the whole set up. I think Meca calls it a dangle kit ?! The car is not harsh on the road, even Sydney goat tracks. I run a bigger profile tyre on the road with slightly lower tyre pressures. When driven normally on the street, it feels about the same as the Alconi, which still has all the rubber joints. With the low profile race tyres the difference is like chalk and cheese.
    You really have to load up the suspension on the track to notice the rubber distortion and delay on turn in. That is not something you don't actually feel on the road. If you go that quick in NSW or Vic you get locked up and the car is impounded.
    Not like the good old days in modified R8's and R10's !
    JohnW likes this.
  23. #123
    658
    Frans made up a set of solid bushes for the my wishbones few years ago. This upgrade uses material called "Nylatrol" and it is a graphite impregnated nylon that is many times better than the Phosphor Bronze bushes available at Mecaparts. It is appear entry used underwater also because there is no grease that can wash away.
    i have yet to used them in anger, but not far away now. Becareful if you order a set to make sure the exact bush openings so Frans makes them to the right size as the wishbones all all slightly different I discovered.
    i also purchased and fitted the steering arms from Mecaparts. They went on easy and have the benefit of being full adjustable.
    I also suggest you look at drilling the offset holes to achieve the camber, as it will improve the stability and handling.
    keep up the good work.
  24. #124
    4,424
    R8dream,
    I'm not sure I want to go through the pain of pressing the bushes out and in again, maybe a future upgrade once it's back on the road.
    I had a Sydney based friend come over and check the cross member out and he believes it had already been drilled out. The previous owner had a bit of suspension work done at Alpine motors in ACT.
    On my R10, Dave Collier did an adjustable setup by slotting the holes, welding a right angled plate and two bolts onto the setup. Looks like it will be hard to remove too!
    KB
  25. #125
    658
    R8dream,
    I wouldn't either if you have already gone down your path, just if hadn't then might be worth considering. The adjustable steering arms are a joy to have and work with.
    any more pictures of your progress?
    Angelo
